> OT: need SQL help, asking the gurus ...
post Jul 22 2004, 12:30 PM
Resident German
ok, here's the problem:
let's say i have a table with 2 rows like the example below. in the second row, i have a integer status value (iStatus). i need a query that allows me to find the value that occurs the most in the table, in the example below, that would be "3". i'm not interested in how many 3s there are, all i need is to find out which iStatus value shows up the most in the table ...
(IMG:style_emoticons/default/pray.gif)
post Jul 22 2004, 12:40 PM
Resident German
QUOTE(lapuwali @ Jul 22 2004, 11:36 AM)
Oracle, MySQL, SQLServer, DB2, etc? It will make a difference. There is no single "SQL".
Just off the top of by non-guru head, I'd say you're looking at using MAX(COUNT(*)), probably with a sub-select, but I can't give you exact syntax w/o knowing which SQL, and I only know MySQL and Oracle (and I don't know Oracle well).
count(*) won't work. as i said, i don't need to know how MANY 3s there are ...
just ANSI SQL, the query should be easy enough to run anywhere, i'm hoping i don't need some crazy syntax for what i want.
Andy
SirAndy   OT: need SQL help   Jul 22 2004, 12:30 PM
lapuwali   Oracle, MySQL, SQLServer, DB2, etc? It will make ...   Jul 22 2004, 12:36 PM
SirAndy   ...   Jul 22 2004, 12:40 PM
Cloudbuster   select top 1 count(iStatus) as StatCount, sDescrip...   Jul 22 2004, 01:18 PM
SirAndy   <...   Jul 22 2004, 02:02 PM
- Lo-Fi Version Time is now: 5th October 2026 - 07:18 PM
