Question:, Best way to remove rear view mirror adhesive |
dcecc1968 |
Oct 2 2013, 02:30 PM
Member Group: Members Posts: 252 Joined: 31-December 12 From: Concord, NC Member No.: 15,313 Region Association: South East States |
I tried heating the glass with a hair dryer and using a razor blade to remove the mirror mounting pad with no luck.
So do I need to get a heat gun or is there better way? Thanks for you input. -Don |
warrenoliver |
Oct 2 2013, 06:09 PM
Member Group: Members Posts: 363 Joined: 11-November 06 From: McFarland, Wisconsin Member No.: 7,199 Region Association: Upper MidWest |
I tried heating the glass with a hair dryer and using a razor blade to remove the mirror mounting pad with no luck. So do I need to get a heat gun or is there better way? Thanks for you input. -Don Nail polish remover/acetone works great. Put a little on a cloth and hold it against the adhesive for a minute or two. Should wipe or scrape off easily. |
noellalew |
Oct 2 2013, 09:14 PM
Newbie Group: Members Posts: 4 Joined: 19-December 10 From: California Member No.: 12,499 Region Association: None |
I tried heating the glass with a hair dryer and using a razor blade to remove the mirror mounting pad with no luck. So do I need to get a heat gun or is there better way? Thanks for you input. -Don Nail polish remover/acetone works great. Put a little on a cloth and hold it against the adhesive for a minute or two. Should wipe or scrape off easily. Use piano wire or heavy fishing line and slide between the windshield glass and the rubber adhesive. Slide it through like cheese |
Lo-Fi Version | Time is now: 10th June 2024 - 05:27 AM |
