> Re-mount stock mirrors?
e_artiles
post Oct 2 2013, 07:50 PM
I need advice. The PO replaced the stock mirrors with Talbot racing mirrors and I want to reinstall the stock mirrors. The problem is that he drilled through the stock backing nuts in the doors to get the mounting u-bolt in! (IMG:style_emoticons/default/headbang.gif)
What would be the best way to re-mount the stock mirrors?
jimkelly
post Oct 7 2013, 09:21 AM
Delaware USA
or - maybe - if you weld, buy this small section of a door and graph it in. plenty of people cutting up 914s.
are you just doing drivers door?
e_artiles   Re-mount stock mirrors?   Oct 2 2013, 07:50 PM
rick 918-S   I need advice. The PO replaced the stock mirrors ...   Oct 2 2013, 09:15 PM
e_artiles   Any suggestions of a source for stainless steel sc...   Oct 3 2013, 10:43 PM
kg6dxn   Any suggestions of a source for stainless steel s...   Oct 4 2013, 06:45 AM
euro911   Do you have a local hardware store that has a ...   Oct 3 2013, 10:51 PM
GeorgeRud   Depending on the size of the drilled holes, you co...   Oct 4 2013, 07:41 AM
jimkelly   pic of stock bolt   Oct 4 2013, 07:44 AM
Garold Shaffer   The stock bolt is the same as the ones used to hol...   Oct 4 2013, 08:16 AM
rick 918-S   The stock bolt is the same as the ones used to ho...   Oct 4 2013, 08:23 AM
ben*james   The stock bolt is the same as the ones used to ho...   Oct 4 2013, 08:50 AM
jfort   Garold is a wealth of knowledge. I've seen his...   Oct 4 2013, 09:13 AM
e_artiles   I don't currently have the stock mirror screws...   Oct 4 2013, 09:30 AM
dangrouche   I don't currently have the stock mirror screw...   Oct 6 2013, 10:56 AM
sfrenck   I found SS screws and nuts at my local Lowes - but...   Oct 4 2013, 10:37 AM
Nine_14   Use cage nuts like shown in the pic.   Oct 4 2013, 11:12 AM
e_artiles   How do the cage nuts work? Do they hold on to the ...   Oct 4 2013, 04:35 PM
Nine_14   How do the cage nuts work? Do they hold on to the...   Oct 6 2013, 10:39 AM
Harpo   I believe it is M8-1.25. Bolt depot is a great sou...   Oct 4 2013, 05:10 PM
yeahmag   What kind of shape are they in? I'm interested...   Oct 7 2013, 09:07 AM
jimkelly   or - maybe - if you weld, buy this small section o...   Oct 7 2013, 09:21 AM
- Lo-Fi Version Time is now: 5th June 2025 - 04:46 AM
