| Matt Romanowski |
Apr 15 2013, 07:11 PM
Senior Member ![]() ![]() ![]() Group: Members Posts: 878 Joined: 4-January 04 From: Manchester, NH Member No.: 1,507 |
For the folks who are rebuilding their own transmissions, what are you using for a backlash measurement? The manual says around .007, but that seems a little tight. We're trying to get some temperature out of the transmission and were thinking about running a little looser. Anyone tried that?
| Dr Evil |
Apr 16 2013, 11:58 AM
Send me your transmission! ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 23,044 Joined: 21-November 03 From: Loveland, OH 45140 Member No.: 1,372 Region Association: MidAtlantic Region
I use the factory tool, or at least a clone of it. The factory states that
To do this correctly, you need the special tool. Varying in or out will not give you much in the form of performance and I do not think it will effect cooling all that much either. One can surmise that the quieter running factory setting is the least amount of friction one can get from the R/P. |
| Jon B |
Oct 7 2013, 10:49 PM
Member ![]() ![]() Group: Members Posts: 73 Joined: 28-September 13 From: Vista, CA Member No.: 16,448 Region Association: None |
| Dr Evil |
Oct 8 2013, 10:34 AM
I use the factory tool, or at least a clone of it. Photo below of factory tool, P258, with all accessories. This tool will only measure pinion depth; other tools are needed to determine ring gear backlash and differential bearing preloads. I'm curious to see the clones being made. Jon B. Vista, CA Mine was made by a machinist and has the same dimensions as the factory tool. I only have to use it when replacing R/P for failure of inspection or traumatic failure. Most of the time, and I have covered this extensively here and in my DVD, I instruct people to measure gaskets and maintain factory set specs. The vib issues is not much of a concern in the small increments we deal with. It is mainly a nuisance. Many other manufacturers do not do the finite test in leu of just matching patters with dykem or other indicator to a visual pattern. In a race box, though, I would keep as much friction and vibe out of your setup as fatigue will be highly magnified. Bearings wear and tolerances are quickly lost. |
| 0396 |
Oct 8 2013, 12:31 PM
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 2,046 Joined: 13-October 03 From: L.A. Calif Member No.: 1,245 Region Association: Southern California |
I use the factory tool, or at least a clone of it. Photo below of factory tool, P258, with all accessories. This tool will only measure pinion depth; other tools are needed to determine ring gear backlash and differential bearing preloads. I'm curious to see the clones being made. Jon B. Vista, CA Mine was made by a machinist and has the same dimensions as the factory tool. I only have to use it when replacing R/P for failure of inspection or traumatic failure. Most of the time, and I have covered this extensively here and in my DVD, I instruct people to measure gaskets and maintain factory set specs. The vib issues is not much of a concern in the small increments we deal with. It is mainly a nuisance. Many other manufacturers do not do the finite test in leu of just matching patters with dykem or other indicator to a visual pattern. In a race box, though, I would keep as much friction and vibe out of your setup as fatigue will be highly magnified. Bearings wear and tolerances are quickly lost. Any pictures of these various copies of the P258?? |
Matt Romanowski Ring and Pinion Backlash Apr 15 2013, 07:11 PM
Mark Henry I wouldn't try that, maybe it's time for a... Apr 15 2013, 08:34 PM
Matt Romanowski
I wouldn't try that, maybe it's time for ... Apr 16 2013, 05:15 AM
Mark Henry I don't race so mine is just stock.
But, I... Apr 16 2013, 08:02 AM
pcar916 :agree: The backlash and contact pattern go work... Apr 16 2013, 08:16 AM
Matt Romanowski You can have good settings and contact and still b... Apr 16 2013, 08:29 AM
Jon B The factory states that .012-.018 is tolerance... ... Oct 6 2013, 10:32 PM
Dr Evil Not using inches, why would you assume so? Decimal... Oct 6 2013, 10:35 PM
Jon B
I didn... Oct 6 2013, 10:57 PM
396
Hi, I... Oct 7 2013, 05:44 PM
Dr Evil Sure, whatever Oct 7 2013, 12:26 AM
Matt Romanowski Jon - Good call.
As an update, we're going to... Oct 7 2013, 06:19 AM
76-914
Jon - Good call.
As an update, we're going t... Oct 7 2013, 08:19 AM
Jon B
As an update, we're going to pull the transmi... Oct 7 2013, 10:00 PM
r_towle Matt, what kind of differential do you use?
Rich Oct 7 2013, 07:56 PM
Matt Romanowski
Rich... Oct 7 2013, 11:32 PM
zambezi
[quote name='Jon B' post='1936884' date='Oct 6 20... Oct 7 2013, 08:18 PM
Dr Evil Ya, in my free time ;) Sorry, I am at my 9a-9p job... Oct 8 2013, 12:41 PM
Dr Evil Search on Pelican as the guy who made them had a t... Oct 8 2013, 12:41 PM
jimkelly see post #43
http://www.914world.com/bbs2/index.p... Oct 8 2013, 12:47 PM
Dr Evil Um, no. That is not it. Oct 8 2013, 12:49 PM
Matt Romanowski Post 21 shows one though. Oct 8 2013, 01:25 PM
sixnotfour http://forums.pelicanparts.com/porsche-911...tml#p... Oct 8 2013, 01:56 PM
Dr Evil
http://forums.pelicanparts.com/porsche-911...tml#... Oct 8 2013, 02:42 PM
r_towle Matt,
Have you considered replacing the diff hous... Oct 8 2013, 07:44 PM
Matt Romanowski
Matt,
Have you considered replacing the diff hou... Oct 8 2013, 08:25 PM
Jon B We have a billet intermediate plate and side plate... Oct 8 2013, 09:35 PM
Matt Romanowski
We have a billet intermediate plate and side plat... Oct 8 2013, 10:46 PM
Jon B Matt,
You realize that's alot of engine and t... Oct 8 2013, 11:32 PM
Matt Romanowski
Matt,
You realize that's alot of engine and ... Oct 9 2013, 06:07 AM
r_towle
Matt,
You realize that's alot of engine and ... Oct 9 2013, 11:19 AM
Jon B Can you replace the ring and pinion with the 8 too... Oct 9 2013, 12:07 PM
John I use the VW tools. Got them to do 915's, but... Oct 8 2013, 07:52 PM
Jon B John,
Those are excellent tools, and Porsche-reco... Oct 8 2013, 09:18 PM
John
John,
Those are excellent tools, and Porsche-rec... Oct 9 2013, 08:18 PM
914forme Okay the magic mystery tool is really not needed. ... Oct 9 2013, 07:17 AM
pcar916
Now Pinion Backlash, I hate doing that, shims, pu... Oct 9 2013, 08:24 AM
Dr Evil Agreed, I hate setting preload. <_< Oct 9 2013, 08:23 AM
Dr Evil Going to more teeth on the pinion of a 901 will ac... Oct 9 2013, 12:10 PM
Jon B Going to more teeth on the pinion of a 901 will ac... Oct 9 2013, 02:08 PM
Dr Evil I disagree. When it comes to the 901 pinion, more ... Oct 9 2013, 02:19 PM
Jon B More teeth increase the gear's load bearing su... Oct 9 2013, 03:01 PM
Dr Evil
We can disagree.
In any case it's really no... Oct 9 2013, 03:08 PM
Dr Evil Late, but none the less relevant. Oct 9 2013, 04:30 PM
Jon B It only began in April, so not quite a resurrectio... Oct 9 2013, 05:13 PM
Dr Evil Yup, relevant, addressed two misplaced decimals, I... Oct 9 2013, 05:31 PM
Jon B John,
I have more than one bar, but keep the smal... Oct 9 2013, 10:00 PM
Jon B 914 Transmission
Measuring differential bearing pr... Oct 11 2013, 03:46 PM
396 Thanks for the indepth education. Now we know who ... Oct 11 2013, 03:54 PM
Setting Ring & Pinion
Factor... Oct 11 2013, 04:03 PM![]() ![]() |
Lo-Fi Version | Time is now: 24th August 2026 - 05:30 PM |
