> Ring and Pinion Backlash, What's everyone doing?
Matt Romanowski
post Apr 15 2013, 07:11 PM
For the folks who are rebuilding their own transmissions, what are you using for a backlash measurement? The manual says around .007, but that seems a little tight. We're trying to get some temperature out of the transmission and were thinking about running a little looser. Anyone tried that?
Dr Evil
post Oct 9 2013, 12:10 PM
Send me your transmission!
Going to more teeth on the pinion of a 901 will actually net you a weaker pinion as the teeth will be smaller/thinner. The 915 is thicker overall in all parts.
Jon B
post Oct 9 2013, 02:08 PM
QUOTE(Dr Evil @ Oct 9 2013, 11:10 AM) *
More teeth increase the gear's load bearing surface and help decrease material fatigue. Gear tooth design can be adjusted if the pinion isn't enlarged, for example, the root circle can be increased, shortening the tooth. It's unlikely that Porsche would've offered a weaker design with no specific advantage, such as significant change in ratio.
The 915 8-tooth pinion was increased in size from previous 7-tooth pinion, with ring gear offset 2mm on differential.
Jon B.
Matt Romanowski   Ring and Pinion Backlash   Apr 15 2013, 07:11 PM
Mark Henry   I wouldn't try that, maybe it's time for a...   Apr 15 2013, 08:34 PM
Matt Romanowski   I wouldn't try that, maybe it's time for ...   Apr 16 2013, 05:15 AM
Mark Henry   I don't race so mine is just stock. But, I...   Apr 16 2013, 08:02 AM
pcar916   :agree: The backlash and contact pattern go work...   Apr 16 2013, 08:16 AM
Matt Romanowski   You can have good settings and contact and still b...   Apr 16 2013, 08:29 AM
Dr Evil   I use the factory tool, or at least a clone of it....   Apr 16 2013, 11:58 AM
Jon B   The factory states that .012-.018 is tolerance... ...   Oct 6 2013, 10:32 PM
Jon B   I use the factory tool, or at least a clone of it...   Oct 7 2013, 10:49 PM
Dr Evil   [quote name='Dr Evil' post='1850919' date='Apr 16...   Oct 8 2013, 10:34 AM
396   [quote name='Dr Evil' post='1850919' date='Apr 1...   Oct 8 2013, 12:31 PM
Dr Evil   Not using inches, why would you assume so? Decimal...   Oct 6 2013, 10:35 PM
Jon B   Not using inches, why would you assume so? I didn...   Oct 6 2013, 10:57 PM
396   Not using inches, why would you assume so? Hi, I...   Oct 7 2013, 05:44 PM
Dr Evil   Sure, whatever   Oct 7 2013, 12:26 AM
Matt Romanowski   Jon - Good call. As an update, we're going to...   Oct 7 2013, 06:19 AM
76-914   Jon - Good call. As an update, we're going t...   Oct 7 2013, 08:19 AM
Jon B   As an update, we're going to pull the transmi...   Oct 7 2013, 10:00 PM
r_towle   Matt, what kind of differential do you use? Rich   Oct 7 2013, 07:56 PM
Matt Romanowski   Matt, what kind of differential do you use? Rich...   Oct 7 2013, 11:32 PM
zambezi   [quote name='Jon B' post='1936884' date='Oct 6 20...   Oct 7 2013, 08:18 PM
Dr Evil   Ya, in my free time ;) Sorry, I am at my 9a-9p job...   Oct 8 2013, 12:41 PM
Dr Evil   Search on Pelican as the guy who made them had a t...   Oct 8 2013, 12:41 PM
jimkelly   see post #43 http://www.914world.com/bbs2/index.p...   Oct 8 2013, 12:47 PM
Dr Evil   Um, no. That is not it.   Oct 8 2013, 12:49 PM
Matt Romanowski   Post 21 shows one though.   Oct 8 2013, 01:25 PM
sixnotfour   http://forums.pelicanparts.com/porsche-911...tml#p...   Oct 8 2013, 01:56 PM
Dr Evil   http://forums.pelicanparts.com/porsche-911...tml#...   Oct 8 2013, 02:42 PM
r_towle   Matt, Have you considered replacing the diff hous...   Oct 8 2013, 07:44 PM
Matt Romanowski   Matt, Have you considered replacing the diff hou...   Oct 8 2013, 08:25 PM
Jon B   We have a billet intermediate plate and side plate...   Oct 8 2013, 09:35 PM
Matt Romanowski   We have a billet intermediate plate and side plat...   Oct 8 2013, 10:46 PM
Jon B   Matt, You realize that's alot of engine and t...   Oct 8 2013, 11:32 PM
Matt Romanowski   Matt, You realize that's alot of engine and ...   Oct 9 2013, 06:07 AM
r_towle   Matt, You realize that's alot of engine and ...   Oct 9 2013, 11:19 AM
Jon B   Can you replace the ring and pinion with the 8 too...   Oct 9 2013, 12:07 PM
John   I use the VW tools. Got them to do 915's, but...   Oct 8 2013, 07:52 PM
Jon B   John, Those are excellent tools, and Porsche-reco...   Oct 8 2013, 09:18 PM
John   John, Those are excellent tools, and Porsche-rec...   Oct 9 2013, 08:18 PM
914forme   Okay the magic mystery tool is really not needed. ...   Oct 9 2013, 07:17 AM
pcar916   Now Pinion Backlash, I hate doing that, shims, pu...   Oct 9 2013, 08:24 AM
Dr Evil   Agreed, I hate setting preload. <_<   Oct 9 2013, 08:23 AM
Dr Evil   Going to more teeth on the pinion of a 901 will ac...   Oct 9 2013, 12:10 PM
Jon B   Going to more teeth on the pinion of a 901 will ac...   Oct 9 2013, 02:08 PM
Dr Evil   I disagree. When it comes to the 901 pinion, more ...   Oct 9 2013, 02:19 PM
Jon B   More teeth increase the gear's load bearing su...   Oct 9 2013, 03:01 PM
Dr Evil   We can disagree. In any case it's really no...   Oct 9 2013, 03:08 PM
Dr Evil   Late, but none the less relevant.   Oct 9 2013, 04:30 PM
Jon B   It only began in April, so not quite a resurrectio...   Oct 9 2013, 05:13 PM
Dr Evil   Yup, relevant, addressed two misplaced decimals, I...   Oct 9 2013, 05:31 PM
Jon B   John, I have more than one bar, but keep the smal...   Oct 9 2013, 10:00 PM
Jon B   914 Transmission Measuring differential bearing pr...   Oct 11 2013, 03:46 PM
396   Thanks for the indepth education. Now we know who ...   Oct 11 2013, 03:54 PM
Jon B   914 Transmission Setting Ring & Pinion Factor...   Oct 11 2013, 04:03 PM
- Lo-Fi Version Time is now: 24th August 2026 - 05:30 PM
