> Possible decel valve problem, Idle likes to drop to zero after warmed up.
boxsterfan
post Oct 9 2013, 02:20 PM
914's are kewl
1974 2.0L D-Jet
Once the engine gets warmed up, my engine RPM likes to drop down to zero when letting off the gas. This is not just a "gauge" bouncing issue but rather you can feel that the motor has dropped to zero (stalling).
Does this sound like a condition that can occur because of a faulty decel valve? Anyone in San Ramon, CA have a known working spare one i could test with?
Part#: U039133551
Referred to affectionately as a decel valve, this factory installed device lets the idle down slowly to more effectively limit the unburned gas exiting the tail pipe and keep the engine from stalling. mounts on the right side of the firewall just above the pressure sensor and just behind the battery and three vacuum lines attach to it.
DRPHIL914
post Oct 10 2013, 08:30 AM
Dr. Phil
QUOTE(r_towle @ Oct 9 2013, 11:09 PM) *
Remove and plug the AAR, decel! and all other vacuum lines! including the vacuum advance to the distributor.
Leave only the MPS plugged into the plenum.
Then troubleshoot.
Do valves, dwell and timing
Check the TPS to verify it's set properly
Check fuel pressure
Check your CHT resistance cold and hot.
Then add only one vacuum system at a time
If the car runs fine without any new vacuum systems, you will find the culprit.
Tune up the car first or you will waste a lot of time.
my 75 used to do this, and one issue was the tps not being set right, and the other was with the MPS, which was not in spec, and was way too rich, and once adjusted is now perfect, 800 should be your warmed up idle, probably should be some where around 1200-1400 cold with the AAR fully open, - maybe your AAR is not opening up properly as well, so i would check that too.
phil
boxsterfan   Possible decel valve problem   Oct 9 2013, 02:20 PM
Java2570   I think typically the decel valve starts leaking a...   Oct 9 2013, 02:28 PM
Java2570   I'd look at fuel pressure, possible fuel deliv...   Oct 9 2013, 02:41 PM
The Cabinetmaker   I agree. Remove the hoses and plug them. Take the ...   Oct 9 2013, 03:38 PM
76-914   What's your idle rpm when it's cold and be...   Oct 9 2013, 03:42 PM
boxsterfan   What's your idle rpm when it's cold and b...   Oct 9 2013, 11:45 PM
r_towle   Remove and plug the AAR, decel! and all other ...   Oct 9 2013, 09:09 PM
boxsterfan   Thanks everyone. I will troubleshoot this weekend....   Oct 9 2013, 10:46 PM
Philip W.   Remove and plug the AAR, decel! and all other...   Oct 10 2013, 08:30 AM
boxsterfan   Remove and plug the AAR, decel! and all othe...   Oct 10 2013, 10:13 AM
worn   How do you adjust the MPS? I know this part is ...   Oct 10 2013, 11:33 AM
Philip W.   How do you adjust the MPS? I know this part is...   Oct 10 2013, 12:29 PM
worn   I guess i like to tinker with these things, and...   Oct 10 2013, 01:21 PM
Philip W.   I guess i like to tinker with these things, an...   Oct 10 2013, 06:45 PM
76-914   :agree:   Oct 10 2013, 09:04 AM
rick 918-S   I just fired up a rebuilt 2.0 I took it for a driv...   Oct 10 2013, 07:05 PM
r_towle   I just fired up a rebuilt 2.0 I took it for a dri...   Oct 10 2013, 08:14 PM
boxsterfan   I just fired up a rebuilt 2.0 I took it for a dri...   Oct 10 2013, 09:17 PM
- Lo-Fi Version Time is now: 2nd April 2026 - 09:47 AM
