| boxsterfan |
Oct 9 2013, 02:20 PM
914's are kewl ![]() ![]() ![]() Group: Members Posts: 1,776 Joined: 6-June 03 From: San Ramon, CA Member No.: 791 Region Association: Northern California |
1974 2.0L D-Jet
Once the engine gets warmed up, my engine RPM likes to drop down to zero when letting off the gas. This is not just a "gauge" bouncing issue but rather you can feel that the motor has dropped to zero (stalling). Does this sound like a condition that can occur because of a faulty decel valve? Anyone in San Ramon, CA have a known working spare one i could test with? Part#: U039133551 Referred to affectionately as a decel valve, this factory installed device lets the idle down slowly to more effectively limit the unburned gas exiting the tail pipe and keep the engine from stalling. mounts on the right side of the firewall just above the pressure sensor and just behind the battery and three vacuum lines attach to it. |
| DRPHIL914 |
Oct 10 2013, 08:30 AM
Dr. Phil ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 5,907 Joined: 9-December 09 From: Kennesaw, GA Member No.: 11,106 Region Association: South East States
Remove and plug the AAR, decel! and all other vacuum lines! including the vacuum advance to the distributor. Leave only the MPS plugged into the plenum. Then troubleshoot. Do valves, dwell and timing Check the TPS to verify it's set properly Check fuel pressure Check your CHT resistance cold and hot. Then add only one vacuum system at a time If the car runs fine without any new vacuum systems, you will find the culprit. Tune up the car first or you will waste a lot of time. (IMG:style_emoticons/default/agree.gif) my 75 used to do this, and one issue was the tps not being set right, and the other was with the MPS, which was not in spec, and was way too rich, and once adjusted is now perfect, 800 should be your warmed up idle, probably should be some where around 1200-1400 cold with the AAR fully open, - maybe your AAR is not opening up properly as well, so i would check that too. phil |
| boxsterfan |
Oct 10 2013, 10:13 AM
Remove and plug the AAR, decel! and all other vacuum lines! including the vacuum advance to the distributor. Leave only the MPS plugged into the plenum. Then troubleshoot. Do valves, dwell and timing Check the TPS to verify it's set properly Check fuel pressure Check your CHT resistance cold and hot. Then add only one vacuum system at a time If the car runs fine without any new vacuum systems, you will find the culprit. Tune up the car first or you will waste a lot of time. (IMG:style_emoticons/default/agree.gif) my 75 used to do this, and one issue was the tps not being set right, and the other was with the MPS, which was not in spec, and was way too rich, and once adjusted is now perfect, 800 should be your warmed up idle, probably should be some where around 1200-1400 cold with the AAR fully open, - maybe your AAR is not opening up properly as well, so i would check that too. phil How do you adjust the MPS? I know this part is not made any more and heard that you can send in for a rebuild to board members (Bowlsby) or have AA rebuild. I don't recall seeing any knobs for adjustment on it, but I didn't look that hard. |
| worn |
Oct 10 2013, 11:33 AM
Winner of the Utah Twisted Joint Award ![]() ![]() ![]() ![]() Group: Members Posts: 3,560 Joined: 3-June 11 From: Madison, WI and North Bend WA Member No.: 13,152 Region Association: Upper MidWest
[/quote]
How do you adjust the MPS? I know this part is not made any more and heard that you can send in for a rebuild to board members (Bowlsby) or have AA rebuild. I don't recall seeing any knobs for adjustment on it, but I didn't look that hard. [/quote] Do the tests, but the car won't run without the MPS so you cannot just unplug it, like you can with some of the other components. And it may be that the diaphragm in the MPS has cracked. You can test this by pulling vacuum on it. Do not adjust the MPS. If you find that it has been adjusted (epoxy plug removed), then a previous owner may have tried to adjust it, causing the problems you have now. I do not recommend trying to adjust it back. That is unless you have everything else tested and tuned, you understand how it works, you have installed a wideband air fuel gauge and are ready for a fairly large headache. A swap with a known good MPS would be better, and buying one is better than trying to adjust the one you have. I have collected and rebuilt several of them, and once you get them out of adjustment it is hard to find your way back IME. |
boxsterfan Possible decel valve problem Oct 9 2013, 02:20 PM
Java2570 I think typically the decel valve starts leaking a... Oct 9 2013, 02:28 PM
Java2570 I'd look at fuel pressure, possible fuel deliv... Oct 9 2013, 02:41 PM
The Cabinetmaker I agree. Remove the hoses and plug them. Take the ... Oct 9 2013, 03:38 PM
76-914 What's your idle rpm when it's cold and be... Oct 9 2013, 03:42 PM
boxsterfan
What's your idle rpm when it's cold and b... Oct 9 2013, 11:45 PM
r_towle Remove and plug the AAR, decel! and all other ... Oct 9 2013, 09:09 PM
boxsterfan Thanks everyone. I will troubleshoot this weekend.... Oct 9 2013, 10:46 PM
Philip W.
How do you adjust the MPS? I know this part is... Oct 10 2013, 12:29 PM
worn
I guess i like to tinker with these things, and... Oct 10 2013, 01:21 PM
Philip W.
I guess i like to tinker with these things, an... Oct 10 2013, 06:45 PM
76-914 :agree: Oct 10 2013, 09:04 AM
rick 918-S I just fired up a rebuilt 2.0 I took it for a driv... Oct 10 2013, 07:05 PM
r_towle
I just fired up a rebuilt 2.0 I took it for a dri... Oct 10 2013, 08:14 PM
boxsterfan
I just fired up a rebuilt 2.0 I took it for a dri... Oct 10 2013, 09:17 PM![]() ![]() |
Lo-Fi Version | Time is now: 2nd April 2026 - 08:10 AM |
