> Possible decel valve problem, Idle likes to drop to zero after warmed up.
boxsterfan
post Oct 9 2013, 02:20 PM
914's are kewl
1974 2.0L D-Jet
Once the engine gets warmed up, my engine RPM likes to drop down to zero when letting off the gas. This is not just a "gauge" bouncing issue but rather you can feel that the motor has dropped to zero (stalling).
Does this sound like a condition that can occur because of a faulty decel valve? Anyone in San Ramon, CA have a known working spare one i could test with?
Part#: U039133551
Referred to affectionately as a decel valve, this factory installed device lets the idle down slowly to more effectively limit the unburned gas exiting the tail pipe and keep the engine from stalling. mounts on the right side of the firewall just above the pressure sensor and just behind the battery and three vacuum lines attach to it.
rick 918-S
post Oct 10 2013, 07:05 PM
Hey nice rack! -Celette
I just fired up a rebuilt 2.0 I took it for a drive and it was doing the exact same thing plus a rich condition. Everything is new. Petronix, cap, rotor, wires, vacuum hoses, etc. I tested the MAPS with my mity vac and it tested good. Next I installed a vacuum gauge. The vacuum was low. Like 5 psi. I loosed the dizzy and turned it until the vacuum rose to 15 ish and stayed steady. The engine now runs nice.
Be sure all your tune up parts are good first then do the basics.
boxsterfan
post Oct 10 2013, 09:17 PM
914's are kewl
QUOTE(rick 918-S @ Oct 10 2013, 06:05 PM) *
Where do you plugin for the vacuum when doing that adjustment?
boxsterfan   Possible decel valve problem   Oct 9 2013, 02:20 PM
Java2570   I think typically the decel valve starts leaking a...   Oct 9 2013, 02:28 PM
Java2570   I'd look at fuel pressure, possible fuel deliv...   Oct 9 2013, 02:41 PM
The Cabinetmaker   I agree. Remove the hoses and plug them. Take the ...   Oct 9 2013, 03:38 PM
76-914   What's your idle rpm when it's cold and be...   Oct 9 2013, 03:42 PM
boxsterfan   What's your idle rpm when it's cold and b...   Oct 9 2013, 11:45 PM
r_towle   Remove and plug the AAR, decel! and all other ...   Oct 9 2013, 09:09 PM
boxsterfan   Thanks everyone. I will troubleshoot this weekend....   Oct 9 2013, 10:46 PM
Philip W.   Remove and plug the AAR, decel! and all other...   Oct 10 2013, 08:30 AM
boxsterfan   Remove and plug the AAR, decel! and all othe...   Oct 10 2013, 10:13 AM
worn   How do you adjust the MPS? I know this part is ...   Oct 10 2013, 11:33 AM
Philip W.   How do you adjust the MPS? I know this part is...   Oct 10 2013, 12:29 PM
worn   I guess i like to tinker with these things, and...   Oct 10 2013, 01:21 PM
Philip W.   I guess i like to tinker with these things, an...   Oct 10 2013, 06:45 PM
76-914   :agree:   Oct 10 2013, 09:04 AM
rick 918-S   I just fired up a rebuilt 2.0 I took it for a driv...   Oct 10 2013, 07:05 PM
r_towle   I just fired up a rebuilt 2.0 I took it for a dri...   Oct 10 2013, 08:14 PM
boxsterfan   I just fired up a rebuilt 2.0 I took it for a dri...   Oct 10 2013, 09:17 PM
- Lo-Fi Version Time is now: 2nd April 2026 - 09:44 AM
