mightyohm |
Advanced Member ![]() ![]() ![]() ![]() Group: Benefactors Posts: 2,277 Joined: 16-January 03 From: Seattle, WA Member No.: 162 Region Association: Pacific Northwest ![]() ![]() |
Hey all,
I'm having a strange engine problem that I'm hoping someone can help me diagnose. When I give the car heavy throttle, I hear an intermittent noise that seems to be coming from the engine compartment. It's like a muffled banging or exhaust sound. When I hear the noise I feel a loss of power. When the car is warm, the sound is always accompanied by a whif of burning oil. Aside from this problem the car is running fine - idle hasn't changed, no obvious misfiring. It's only under load that I have this problem. It seems to happen the most when the engine is in its peak HP range - upwards of 3000 rpm. This started happening about 6 months ago. I drive the car to work every day, so I have been noticing that it is slowly getting worse over time. Initially, it only happened when the car was cold, and completely went away after the car warmed up. Now it happens all the time, but it's still worst before the car has had a chance to warm up. Any ideas? I'm fearing the worst - cyl to head leak? Cracked head?? |
pcar916 |
Is that a Lola? ![]() ![]() ![]() Group: Members Posts: 1,523 Joined: 2-June 05 From: Little Rock, AR Member No.: 4,188 Region Association: None ![]() ![]() |
I always suspect points/fuel pump when this happens. Assuming the electrical stuff checks out...
There was a beautiful 356 outlaw I worked on whose fuel pump appeared to pump the right volume while idling, but would not keep up under load. Simply had to rig an electric pump to find the problem. The engine would burp and backfire from a lean mixture until it got a new pump. Good luck |
Lo-Fi Version | Time is now: 11th July 2025 - 06:52 AM |
