> Subaru Transmission Cable Linkage, Some Photos with a Rule
DBCooper
post Oct 6 2013, 02:21 PM
14's in the 13's with ATTITUDE
I can't find the thread now, but I promised some photos of my Subaru cable linkage, with a rule for dimensions. Seem to be several projects getting to this point, so hopefully it will be helpful. I wrenched my back so it's been slow, sorry, but here are a few.
General layout. The cable going through the center of the photo is anchored on the left at the sheath to the main bracket, then connects to the shift rod bracket on the right, attached to the shift rod coming out of the transmission. That cable is the shift rod in and out. The rotational cable connects to the bottom of that same shift rod bracket, on the right. The main bracket is the important piece, it locates all the cable sheath anchors. This is the best view of the reinforcing gusset that keeps everything stiff.
(IMG:http://www.914world.com/bbs2/uploads_offsite/i379.photobucket.com-2618-1381090895.1.jpg)
Same view from below and a little further back so you an see the cable sheath mount for the rotational cable.
(IMG:http://www.914world.com/bbs2/uploads_offsite/i379.photobucket.com-2618-1381090895.2.jpg)
Same direction of view, but a little around the main bracket so you can see the shift rod bracket. That's the important dimension for full throw of the MR2 shifter, 8.5cm from the center of the shift rod to the cable heim center.
(IMG:http://www.914world.com/bbs2/uploads_offsite/i379.photobucket.com-2618-1381090895.3.jpg)
Another, that same bracket and dimension. This is the best view of now that bracket attached to the transmission shift rod:
(IMG:http://www.914world.com/bbs2/uploads_offsite/i379.photobucket.com-2618-1381090895.4.jpg)
Same components, different view. The main bracket curves out from the transmission mount to put the sheath attachment point out in the same plane as the shift rod. In the photos above you can see the shift rod bracket is bent in toward the rear of the transmission to keep that cable movement in the same plane. You can also see more of the main bracket gusset (that triangular shape). Need that gusset to keep it all stiff, minimize cable shifter "mush".
(IMG:http://www.914world.com/bbs2/uploads_offsite/i379.photobucket.com-2618-1381090895.5.jpg)
Different view, same stuff.
(IMG:http://www.914world.com/bbs2/uploads_offsite/i379.photobucket.com-2618-1381090895.6.jpg)
Shows the main bracket size. This isn't a critical dimension, but it will give some perspective, maybe help. that 5" measurement is from the point where it attaches to the transmission to the cable sheath anchor tab for the rotational cable.
(IMG:http://www.914world.com/bbs2/uploads_offsite/i379.photobucket.com-2618-1381090895.7.jpg)
No, this is NOT Andy's camera, it's my sore back. Not a critical dimension so it's OK. It's 17cm, the distance between the mounting tab for the in-out cable sheath to the middle of the in-out heim joint on the transmission rod bracket.
(IMG:http://www.914world.com/bbs2/uploads_offsite/i379.photobucket.com-2618-1381090895.8.jpg)
Layout (during the build) of the modified MR2 shifter inside the car. That verticall piece of flat stock between the cables from the shifter to the sheath mounting tabs makes the whole thing stiffer, eliminating a lot of the movement and making the feel a lot more precise. Note that there are adjustments everywhere in the system, every cable end. There's also a video of the shifter working in my build thread, ink in the sig, below.
And last but really first, your reward for reading this far, my little hot rodder grandaughter. She just wants to have fun.
(IMG:http://www.914world.com/bbs2/uploads_offsite/i379.photobucket.com-2618-1381090895.9.jpg)
Sorry things are dirty, but this is how things look with 20K miles of road grime. No maintenance done so far other than regular oil changes and a set of tires. If anyone has any questions or you want to see more or different photos just let me know.
effutuo101
post Oct 13 2013, 02:23 PM
Go for it. I think there are an easy 20 sets to sell now. I think my headers will get in the way if I run them straight out of the car to the tranny.
DBCooper   Subaru Transmission Cable Linkage   Oct 6 2013, 02:21 PM
914forme   Thank you for posting these, as it is where I am a...   Oct 6 2013, 02:32 PM
mepstein   Thanks for adding to the subie collective.   Oct 6 2013, 03:06 PM
Chris H.   Awesome DB, thanks. Very timely.   Oct 6 2013, 03:32 PM
jimkelly   two other pics I like of db's car are these. ...   Oct 6 2013, 04:13 PM
DBCooper   Yeah, sorry Jim. I have a pile of receipts but th...   Oct 6 2013, 04:19 PM
jimkelly   pretty sure one of these would be perfect. assumi...   Oct 6 2013, 04:36 PM
Chris H.   Someone posted the name of a company who will make...   Oct 6 2013, 05:03 PM
jimkelly   here is one mention I found. thread: http://www.91...   Oct 6 2013, 05:12 PM
CptTripps   Awesome thread man. Thanks so much. Exactly what I...   Oct 6 2013, 05:15 PM
Chris H.   That's the one Jim. Control Cables...thank yo...   Oct 6 2013, 05:32 PM
BIGKAT_83   Heres where I got my cables from control cables Wh...   Oct 6 2013, 05:33 PM
jd74914   If you are looking for a second source we get Mors...   Oct 6 2013, 06:23 PM
DBCooper   As a community service I'd suggest that when w...   Oct 7 2013, 06:14 AM
mepstein   As a community service I'd suggest that when ...   Oct 7 2013, 07:29 AM
jimkelly   seems that for those using ian's trans hangers...   Oct 7 2013, 07:11 AM
jimkelly   let's see how he makes out with his Teleflex c...   Oct 8 2013, 10:57 AM
CptTripps   I'd love to find someone that could make me a ...   Oct 9 2013, 09:05 PM
DBCooper   If we could get a few people together I think I co...   Oct 10 2013, 06:14 AM
Chris H.   I'll shoot some in the next day or two. My en...   Oct 10 2013, 06:47 AM
Chris H.   DB, do any of these help? I just noticed a couple...   Oct 12 2013, 02:59 PM
DBCooper   DB, do any of these help? I just noticed a coupl...   Oct 13 2013, 07:41 AM
CptTripps   Another possibility is drilling a hole right thro...   Oct 13 2013, 10:31 AM
CptTripps   I think we'd ALL buy MR2 shifters if it made t...   Oct 12 2013, 07:06 PM
mepstein   DBCooper's cable shifter on youtube http://ww...   Oct 12 2013, 08:46 PM
Chris H.   Let me get you a better straight on pic of that ha...   Oct 13 2013, 08:05 AM
effutuo101   I also have a MR2 shifter that I want to use. I do...   Oct 13 2013, 10:07 AM
IM101   This thread is killing me... It would be so easy t...   Oct 13 2013, 02:10 PM
DBCooper   DB do you have a shot of how you run your cables, ...   Oct 13 2013, 04:27 PM
effutuo101   Go for it. I think there are an easy 20 sets to se...   Oct 13 2013, 02:23 PM
jimkelly   pic from db's thread http://www.914world.com/...   Oct 13 2013, 03:26 PM
Chris H.   :trophy: Alright now we're getting somewhere...   Oct 13 2013, 06:28 PM
IM101   DB, Cool, I think that'll be the way I go then...   Oct 13 2013, 10:11 PM
r_towle   DB, Cool, I think that'll be the way I go the...   Oct 14 2013, 05:16 PM
DBCooper   DB, Cool, I think that'll be the way I go the...   Oct 23 2013, 07:50 PM
IM101   DB, Cool, I think that'll be the way I go th...   Oct 24 2013, 09:34 AM
Chris H.   [quote name='DBCooper' post='1945500' date='Oct 2...   Oct 24 2013, 10:05 AM
CptTripps   Can't help you with a job in PNW, but I'm ...   Oct 14 2013, 04:54 PM
CptTripps   ::: Waiting patiently :::: Another thing that...   Oct 24 2013, 09:44 AM
IM101   Well there were some places mentioned earlier in t...   Oct 24 2013, 09:53 AM
CptTripps   Awesome. Keep me in the loop, and make sure I...   Oct 24 2013, 10:00 AM
skeates   That's actually the route I was looking into. ...   Oct 24 2013, 10:10 AM
CptTripps   Do we (collectively) have any idea what control ca...   Nov 8 2013, 02:23 PM
Chris H.   After seeing how much slack the side-to-side one n...   Nov 9 2013, 12:33 PM
DBCooper   Car isn't here now but I'll try to measure...   Nov 9 2013, 03:44 PM
DBCooper   Unfortunately I torqued my back again. It's 9...   Nov 15 2013, 10:15 AM
DBCooper   Unfortunately I torqued my back again. I'll ...   Nov 17 2013, 06:10 PM
76-914   Chris, from what I could see you don't need to...   Nov 15 2013, 10:36 AM
Chris H.   Thanks Kent! I was hoping they didn't hav...   Nov 15 2013, 10:55 AM
d914   mine are 7ft and 9 ft   Nov 15 2013, 03:20 PM
76-914   I think that is pretty much right on but I'm l...   Nov 15 2013, 07:17 PM
Chris H.   I think we're good DB, don't chance anothe...   Nov 17 2013, 06:39 PM
IM101   Hey guys, just wanted to let everyone on this thre...   Nov 26 2013, 04:28 PM
effutuo101   Just let me know. I am ready to buy this and the h...   Nov 26 2013, 05:44 PM
IM101   Im getting settled into the new shop today, planni...   Dec 9 2013, 02:13 PM
Chris H.   Im getting settled into the new shop today, plann...   Dec 9 2013, 02:18 PM
IM101   Im getting settled into the new shop today, plan...   Dec 9 2013, 02:31 PM
Chris H.   OK that works. Reason I ask is I'd actually r...   Dec 9 2013, 02:42 PM
IM101   Makes sense... really it should not matter which f...   Dec 9 2013, 03:12 PM
kevin311   When measuring my shifter cables I just used a lon...   Dec 9 2013, 03:15 PM
IM101   When measuring my shifter cables I just used a lo...   Dec 9 2013, 03:31 PM
CptTripps   This is awesome news. I'm also VERY glad that ...   Dec 9 2013, 03:46 PM
AfricanHijinx   i am in for a set   Dec 9 2013, 03:57 PM
76-914   FYI, your lookng at about 150 for a pair of cables...   Dec 9 2013, 04:39 PM
IM101   FYI, your lookng at about 150 for a pair of cable...   Dec 9 2013, 05:34 PM
CptTripps   So are we talking $200-$250 for the brac...   Dec 9 2013, 05:53 PM
IM101   So are we talking $200-$250 for the bra...   Dec 10 2013, 02:06 PM
76-914   If you use wire as a measuring stick be sure to al...   Dec 10 2013, 11:53 AM
Chris H.   Thanks Kent. :beer2:   Dec 10 2013, 12:04 PM
IM101   Thanks Kent. :beer2: Yes thanks Kent, DBCoope...   Dec 10 2013, 02:08 PM
CptTripps   Awesome. Put me on the list...or even to test some...   Dec 10 2013, 02:31 PM
DBCooper   Ditto on the awesome. Now take a quick look at th...   Dec 24 2013, 11:52 AM
DBCooper   Saw this photo in the FF 818 forum of their rear b...   Dec 24 2013, 01:12 PM
andys   I wonder if someone should tell them the angles ...   Dec 24 2013, 03:39 PM
76-914   Saw this photo in the FF 818 forum of their rear ...   Dec 26 2013, 08:51 AM
DBCooper   That's true to a point. I'm not familiar ...   Dec 24 2013, 04:52 PM
drive-ability   Great info !!!!   Dec 26 2013, 02:27 AM
IM101   Hey guys, I have the first production prototype d...   Dec 26 2013, 01:46 PM
effutuo101   Hi Ian, I am available to test immediately. Trans ...   Dec 26 2013, 01:51 PM
Chris H.   YES! Bring it! Ready whenever they'r...   Dec 26 2013, 02:14 PM
IM101   Just a teaser shot of the production prototype. E...   Jan 14 2014, 05:27 PM
effutuo101   need. need soon! once I have this and the half...   Jan 14 2014, 05:31 PM
Chris H.   Very nice! Was JUST about to bump this.   Jan 14 2014, 05:34 PM
skeates   Ian, that looks awesome! I was planning to do ...   Jan 15 2014, 12:36 PM
CptTripps   Ian, I have no doubt that you'll get this done...   Jan 15 2014, 12:59 PM
jimkelly   the cable connected to the bell crank rotates the ...   Jan 15 2014, 02:26 PM
IM101   Jim has it right, as I said earlier in the thread,...   Jan 15 2014, 02:45 PM
CptTripps   AHHHH!!! I get it now. :doh: Very coo...   Jan 15 2014, 02:59 PM
effutuo101   :beer1: come on Ian!   Jan 15 2014, 03:41 PM
rnellums   Yes. Buying this when finished. :drooley:   Jan 15 2014, 03:42 PM
effutuo101   I think that makes 5 of us he has stacked up here ...   Jan 15 2014, 03:43 PM
IanJ   I think that makes 5 of us he has stacked up here...   Jan 16 2014, 01:18 AM
76-914   Playing the devil's advocate with "0...   Jan 15 2014, 03:54 PM
skeates   Playing the devil's advocate with "0...   Jan 16 2014, 12:48 AM
IM101   Playing the devil's advocate with "0...   Jan 16 2014, 11:31 AM
Chris H.   LOL! It's more than 6 I'm sure.....fe...   Jan 16 2014, 07:18 AM
CptTripps   I'm not going to have my car on the road for a...   Jan 16 2014, 08:43 AM
IM101   Today went Awesome! Have not had so much fabri...   Jan 16 2014, 09:14 PM
CptTripps   Can't wait. This is exciting shit.   Jan 16 2014, 09:28 PM
914forme   Yep, Im here also, standing in line hopping the co...   Jan 16 2014, 09:58 PM
3 Pages V  1 2 3 >
- Lo-Fi Version Time is now: 28th October 2026 - 10:48 PM
