| DBCooper |
Oct 6 2013, 02:21 PM
14's in the 13's with ATTITUDE ![]() ![]() ![]() ![]() Group: Members Posts: 3,079 Joined: 25-August 04 From: Dazed and Confused Member No.: 2,618 Region Association: Northern California |
I can't find the thread now, but I promised some photos of my Subaru cable linkage, with a rule for dimensions. Seem to be several projects getting to this point, so hopefully it will be helpful. I wrenched my back so it's been slow, sorry, but here are a few.
General layout. The cable going through the center of the photo is anchored on the left at the sheath to the main bracket, then connects to the shift rod bracket on the right, attached to the shift rod coming out of the transmission. That cable is the shift rod in and out. The rotational cable connects to the bottom of that same shift rod bracket, on the right. The main bracket is the important piece, it locates all the cable sheath anchors. This is the best view of the reinforcing gusset that keeps everything stiff. (IMG:http://www.914world.com/bbs2/uploads_offsite/i379.photobucket.com-2618-1381090895.1.jpg) Same view from below and a little further back so you an see the cable sheath mount for the rotational cable. (IMG:http://www.914world.com/bbs2/uploads_offsite/i379.photobucket.com-2618-1381090895.2.jpg) Same direction of view, but a little around the main bracket so you can see the shift rod bracket. That's the important dimension for full throw of the MR2 shifter, 8.5cm from the center of the shift rod to the cable heim center. (IMG:http://www.914world.com/bbs2/uploads_offsite/i379.photobucket.com-2618-1381090895.3.jpg) Another, that same bracket and dimension. This is the best view of now that bracket attached to the transmission shift rod: (IMG:http://www.914world.com/bbs2/uploads_offsite/i379.photobucket.com-2618-1381090895.4.jpg) Same components, different view. The main bracket curves out from the transmission mount to put the sheath attachment point out in the same plane as the shift rod. In the photos above you can see the shift rod bracket is bent in toward the rear of the transmission to keep that cable movement in the same plane. You can also see more of the main bracket gusset (that triangular shape). Need that gusset to keep it all stiff, minimize cable shifter "mush". (IMG:http://www.914world.com/bbs2/uploads_offsite/i379.photobucket.com-2618-1381090895.5.jpg) Different view, same stuff. (IMG:http://www.914world.com/bbs2/uploads_offsite/i379.photobucket.com-2618-1381090895.6.jpg) Shows the main bracket size. This isn't a critical dimension, but it will give some perspective, maybe help. that 5" measurement is from the point where it attaches to the transmission to the cable sheath anchor tab for the rotational cable. (IMG:http://www.914world.com/bbs2/uploads_offsite/i379.photobucket.com-2618-1381090895.7.jpg) No, this is NOT Andy's camera, it's my sore back. Not a critical dimension so it's OK. It's 17cm, the distance between the mounting tab for the in-out cable sheath to the middle of the in-out heim joint on the transmission rod bracket. (IMG:http://www.914world.com/bbs2/uploads_offsite/i379.photobucket.com-2618-1381090895.8.jpg) Layout (during the build) of the modified MR2 shifter inside the car. That verticall piece of flat stock between the cables from the shifter to the sheath mounting tabs makes the whole thing stiffer, eliminating a lot of the movement and making the feel a lot more precise. Note that there are adjustments everywhere in the system, every cable end. There's also a video of the shifter working in my build thread, ink in the sig, below. And last but really first, your reward for reading this far, my little hot rodder grandaughter. She just wants to have fun. (IMG:http://www.914world.com/bbs2/uploads_offsite/i379.photobucket.com-2618-1381090895.9.jpg) Sorry things are dirty, but this is how things look with 20K miles of road grime. No maintenance done so far other than regular oil changes and a set of tires. If anyone has any questions or you want to see more or different photos just let me know. |
| IM101 |
Oct 13 2013, 02:10 PM
Member ![]() ![]() Group: Members Posts: 264 Joined: 9-November 10 From: Boise Idaho Member No.: 12,367 Region Association: Pacific Northwest |
This thread is killing me... It would be so easy to get a bracket made if I had all my stuff with me and space to do it... I think I was over thinking it before, had a design for a bell crank style set up just never had time cut/weld a prototype and then get it in cad and send it off to laser. I was trying to make it so both cables were the same length and would run nice and neat parallel to the trans to avoid any binding issues that could arise from having one cable go off to the side. DB do you have a shot of how you run your cables, I take it you don't have any issues with binding...
Well shit, now just when I was getting some cash coming in from the new job, and looking for a shop to open up in they decide to change things up and basically lay me off... Maybe I will just have to make the drive back to Oregon this weekend grab what I need to get it done and see if i can piss off the apartment complex just do it in the parking lot... |
| DBCooper |
Oct 13 2013, 04:27 PM
DB do you have a shot of how you run your cables, I take it you don't have any issues with binding... No, nice curves so no binding (that's my car in Jim's photo, above). Longer cables let you come in to the shift rod at 90 degrees for the rotation, and parallel to the rod for the in-out, which is what you want to keep the mechanism simple. Works great. I don't really want to make these, so if you can that's perfect. What kind of job are you looking for, anyway? Was the major engineering? Any way you could use your job search to turn up a small fab shop that would let you work with them on some projects? Reason I say that is that custom fab shops tend to know who's doing what in town, even when they aren't directly involved. And better, can give great referrals. Or some serious hobbyist you could team up with to make a few parts for a cut? A Craigslist ad? |
DBCooper Subaru Transmission Cable Linkage Oct 6 2013, 02:21 PM
914forme Thank you for posting these, as it is where I am a... Oct 6 2013, 02:32 PM
mepstein Thanks for adding to the subie collective. Oct 6 2013, 03:06 PM
Chris H. Awesome DB, thanks. Very timely. Oct 6 2013, 03:32 PM
jimkelly two other pics I like of db's car are these. ... Oct 6 2013, 04:13 PM
DBCooper Yeah, sorry Jim. I have a pile of receipts but th... Oct 6 2013, 04:19 PM
jimkelly pretty sure one of these would be perfect.
assumi... Oct 6 2013, 04:36 PM
Chris H. Someone posted the name of a company who will make... Oct 6 2013, 05:03 PM
jimkelly here is one mention I found.
thread: http://www.91... Oct 6 2013, 05:12 PM
CptTripps Awesome thread man. Thanks so much. Exactly what I... Oct 6 2013, 05:15 PM
Chris H. That's the one Jim. Control Cables...thank yo... Oct 6 2013, 05:32 PM
BIGKAT_83 Heres where I got my cables from control cables
Wh... Oct 6 2013, 05:33 PM
jd74914 If you are looking for a second source we get Mors... Oct 6 2013, 06:23 PM
DBCooper As a community service I'd suggest that when w... Oct 7 2013, 06:14 AM
As a community service I'd suggest that when ... Oct 7 2013, 07:29 AM
jimkelly seems that for those using ian's trans hangers... Oct 7 2013, 07:11 AM
jimkelly let's see how he makes out with his Teleflex c... Oct 8 2013, 10:57 AM
CptTripps I'd love to find someone that could make me a ... Oct 9 2013, 09:05 PM
DBCooper If we could get a few people together I think I co... Oct 10 2013, 06:14 AM
Chris H. I'll shoot some in the next day or two. My en... Oct 10 2013, 06:47 AM
Chris H. DB, do any of these help? I just noticed a couple... Oct 12 2013, 02:59 PM
DBCooper
DB, do any of these help? I just noticed a coupl... Oct 13 2013, 07:41 AM
CptTripps
Another possibility is drilling a hole right thro... Oct 13 2013, 10:31 AM
CptTripps I think we'd ALL buy MR2 shifters if it made t... Oct 12 2013, 07:06 PM
mepstein DBCooper's cable shifter on youtube
http://ww... Oct 12 2013, 08:46 PM
Chris H. Let me get you a better straight on pic of that ha... Oct 13 2013, 08:05 AM
effutuo101 I also have a MR2 shifter that I want to use. I do... Oct 13 2013, 10:07 AM
effutuo101 Go for it. I think there are an easy 20 sets to se... Oct 13 2013, 02:23 PM
jimkelly pic from db's thread
http://www.914world.com/... Oct 13 2013, 03:26 PM
Chris H. :trophy: Alright now we're getting somewhere... Oct 13 2013, 06:28 PM
IM101 DB,
Cool, I think that'll be the way I go then... Oct 13 2013, 10:11 PM
r_towle
DB,
Cool, I think that'll be the way I go the... Oct 14 2013, 05:16 PM
DBCooper
DB,
Cool, I think that'll be the way I go the... Oct 23 2013, 07:50 PM
IM101
DB,
Cool, I think that'll be the way I go th... Oct 24 2013, 09:34 AM
Chris H.
[quote name='DBCooper' post='1945500' date='Oct 2... Oct 24 2013, 10:05 AM
CptTripps Can't help you with a job in PNW, but I'm ... Oct 14 2013, 04:54 PM
CptTripps ::: Waiting patiently ::::
Another thing that... Oct 24 2013, 09:44 AM
IM101 Well there were some places mentioned earlier in t... Oct 24 2013, 09:53 AM
CptTripps Awesome. Keep me in the loop, and make sure I... Oct 24 2013, 10:00 AM
skeates That's actually the route I was looking into. ... Oct 24 2013, 10:10 AM
CptTripps Do we (collectively) have any idea what control ca... Nov 8 2013, 02:23 PM
Chris H. After seeing how much slack the side-to-side one n... Nov 9 2013, 12:33 PM
DBCooper Car isn't here now but I'll try to measure... Nov 9 2013, 03:44 PM
DBCooper Unfortunately I torqued my back again. It's 9... Nov 15 2013, 10:15 AM
DBCooper
Unfortunately I torqued my back again. I'll ... Nov 17 2013, 06:10 PM
76-914 Chris, from what I could see you don't need to... Nov 15 2013, 10:36 AM
Chris H. Thanks Kent! I was hoping they didn't hav... Nov 15 2013, 10:55 AM
d914 mine are 7ft and 9 ft Nov 15 2013, 03:20 PM
76-914 I think that is pretty much right on but I'm l... Nov 15 2013, 07:17 PM
Chris H. I think we're good DB, don't chance anothe... Nov 17 2013, 06:39 PM
IM101 Hey guys, just wanted to let everyone on this thre... Nov 26 2013, 04:28 PM
effutuo101 Just let me know. I am ready to buy this and the h... Nov 26 2013, 05:44 PM
IM101 Im getting settled into the new shop today, planni... Dec 9 2013, 02:13 PM
Chris H.
Im getting settled into the new shop today, plann... Dec 9 2013, 02:18 PM
IM101
Im getting settled into the new shop today, plan... Dec 9 2013, 02:31 PM
Chris H. OK that works. Reason I ask is I'd actually r... Dec 9 2013, 02:42 PM
IM101 Makes sense... really it should not matter which f... Dec 9 2013, 03:12 PM
kevin311 When measuring my shifter cables I just used a lon... Dec 9 2013, 03:15 PM
IM101
When measuring my shifter cables I just used a lo... Dec 9 2013, 03:31 PM
CptTripps This is awesome news. I'm also VERY glad that ... Dec 9 2013, 03:46 PM
AfricanHijinx i am in for a set Dec 9 2013, 03:57 PM
76-914 FYI, your lookng at about 150 for a pair of cables... Dec 9 2013, 04:39 PM
IM101
FYI, your lookng at about 150 for a pair of cable... Dec 9 2013, 05:34 PM
CptTripps So are we talking $200-$250 for the brac... Dec 9 2013, 05:53 PM
IM101
So are we talking $200-$250 for the bra... Dec 10 2013, 02:06 PM
76-914 If you use wire as a measuring stick be sure to al... Dec 10 2013, 11:53 AM
Chris H. Thanks Kent. :beer2: Dec 10 2013, 12:04 PM
IM101
Yes thanks Kent, DBCoope... Dec 10 2013, 02:08 PM
CptTripps Awesome. Put me on the list...or even to test some... Dec 10 2013, 02:31 PM
DBCooper Ditto on the awesome. Now take a quick look at th... Dec 24 2013, 11:52 AM
DBCooper Saw this photo in the FF 818 forum of their rear b... Dec 24 2013, 01:12 PM
andys
I wonder if someone should tell them the angles ... Dec 24 2013, 03:39 PM
76-914
Saw this photo in the FF 818 forum of their rear ... Dec 26 2013, 08:51 AM
DBCooper That's true to a point. I'm not familiar ... Dec 24 2013, 04:52 PM
drive-ability Great info !!!! Dec 26 2013, 02:27 AM
IM101 Hey guys,
I have the first production prototype d... Dec 26 2013, 01:46 PM
effutuo101 Hi Ian, I am available to test immediately. Trans ... Dec 26 2013, 01:51 PM
Chris H. YES! Bring it! Ready whenever they'r... Dec 26 2013, 02:14 PM
IM101 Just a teaser shot of the production prototype. E... Jan 14 2014, 05:27 PM
effutuo101 need. need soon! once I have this and the half... Jan 14 2014, 05:31 PM
Chris H. Very nice! Was JUST about to bump this. Jan 14 2014, 05:34 PM
skeates Ian, that looks awesome! I was planning to do ... Jan 15 2014, 12:36 PM
CptTripps Ian, I have no doubt that you'll get this done... Jan 15 2014, 12:59 PM
jimkelly the cable connected to the bell crank rotates the ... Jan 15 2014, 02:26 PM
IM101 Jim has it right, as I said earlier in the thread,... Jan 15 2014, 02:45 PM
CptTripps AHHHH!!! I get it now. :doh:
Very coo... Jan 15 2014, 02:59 PM
effutuo101 :beer1:
come on Ian! Jan 15 2014, 03:41 PM
rnellums Yes. Buying this when finished. :drooley: Jan 15 2014, 03:42 PM
effutuo101 I think that makes 5 of us he has stacked up here ... Jan 15 2014, 03:43 PM
IanJ
I think that makes 5 of us he has stacked up here... Jan 16 2014, 01:18 AM
76-914 Playing the devil's advocate with "0... Jan 15 2014, 03:54 PM
skeates
Playing the devil's advocate with "0... Jan 16 2014, 12:48 AM
IM101
Playing the devil's advocate with "0... Jan 16 2014, 11:31 AM
Chris H. LOL! It's more than 6 I'm sure.....fe... Jan 16 2014, 07:18 AM
CptTripps I'm not going to have my car on the road for a... Jan 16 2014, 08:43 AM
IM101 Today went Awesome! Have not had so much fabri... Jan 16 2014, 09:14 PM
CptTripps Can't wait. This is exciting shit. Jan 16 2014, 09:28 PM
914forme Yep, Im here also, standing in line hopping the co... Jan 16 2014, 09:58 PM![]() ![]() |
Lo-Fi Version | Time is now: 28th October 2026 - 10:49 PM |
