yeahmag |
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 2,424 Joined: 18-April 05 From: Pasadena, CA Member No.: 3,946 Region Association: Southern California ![]() ![]() |
I'm running the CB performance dry sump pump and am attempting to get a bit more pressure at hot idle. I'm considering addressing two potential issues:
Primary Concern: I used Loctite 518 AND the gasket between the cover and the pressure side of the pump. 518 is a gasket replacement and NOT a gasket enhancer. Anybody care to guess if I managed to increase the cover to gear clearance a bit by using 518 and the gasket on the front cover? Secondary Concern: The last 3 feet of my supply line necks down from -12AN to a T and then -10AN. Not likely in my mind to cause a hot idle issue (cold idle is 40PSI), but thought I'd mention it. Idle pressure is almost exactly 10PSI at 185F and 1000RPM. I'm using Brad Penn 20w-50. BTW - both motors appear to have water vapor coming out of the breathers with Brad Penn. I've heard others having this "issue" too. Is it an issue? I'm considering trying Jake's "Snake Oil"... |
r_towle |
Custom Member ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 24,594 Joined: 9-January 03 From: Taxachusetts Member No.: 124 Region Association: North East States ![]() ![]() |
I have a treuhaft pump, looks like it's about 2 inches out of the case.
The motor had a 911 cooling shroud, so space was not as much of an issue. You could measure the clearance you have now from the cover to the shroud. Clay on the lid, bolt the shroud back down. Remove and measure the clay. The shroud could be shimmed out about 5mm and still work as designed. You could make a shim plate of 5mm to go between the cover and the pump body Then get taller gears. I just touched on that this process was done, so it can work easy enough. Rich |
Lo-Fi Version | Time is now: 17th June 2024 - 05:21 AM |
