tornik550 |
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,248 Joined: 29-January 07 From: Ohio Member No.: 7,486 Region Association: None ![]() |
Due to a new baby, I haven't been driving my car much. I have found that if I let my car sit for three days or so, the battery voltage will be so low that the starter will not turn. The alternator cranks out 14 volts when running.
I made several changes prior to noticing this. I suppose there could be something which could be causing battery drain or my battery could just be going bad. I suspect this may have been going on for a while however I drove the car frequently so I didn't notice. If I change the battery with an external charger while it is still hooked to the car- it will charge to around 13volts then by morning it will read around 12.33 volts. I obviously do not really understand batteries. Is there a way to determine if I have a battery problem or a drain problem. |
Trekkor |
I do things... ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 7,809 Joined: 2-December 03 From: Napa, Ca Member No.: 1,413 Region Association: Northern California ![]() |
I disconnected my in-dash clock. Problem solved.
KT |
Lo-Fi Version | Time is now: 15th July 2025 - 05:59 PM |
