tornik550 |
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,248 Joined: 29-January 07 From: Ohio Member No.: 7,486 Region Association: None ![]() |
Due to a new baby, I haven't been driving my car much. I have found that if I let my car sit for three days or so, the battery voltage will be so low that the starter will not turn. The alternator cranks out 14 volts when running.
I made several changes prior to noticing this. I suppose there could be something which could be causing battery drain or my battery could just be going bad. I suspect this may have been going on for a while however I drove the car frequently so I didn't notice. If I change the battery with an external charger while it is still hooked to the car- it will charge to around 13volts then by morning it will read around 12.33 volts. I obviously do not really understand batteries. Is there a way to determine if I have a battery problem or a drain problem. |
pcar916 |
Is that a Lola? ![]() ![]() ![]() Group: Members Posts: 1,523 Joined: 2-June 05 From: Little Rock, AR Member No.: 4,188 Region Association: None ![]() ![]() |
(IMG:style_emoticons/default/agree.gif) on the battery tender charger. If the battery is an AGM type, make sure the charger can do those properly.
Lo-Fi Version | Time is now: 15th July 2025 - 06:10 PM |
