| jmalone |
May 22 2013, 09:53 PM
Member ![]() ![]() Group: Members Posts: 119 Joined: 3-July 09 From: reno,NV Member No.: 10,529 Region Association: Northern California
Can anyone confirm the torque figures for the heat exchanger to head nuts? I have initial torque at 7.3 ft/lb and final torque at 24.5 ft/lb.
| Dave_Darling |
Oct 23 2013, 08:54 AM
914 Idiot ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 15,335 Joined: 9-January 03 From: Silicon Valley / Kailua-Kona Member No.: 121 Region Association: Northern California
Annealing makes the copper "dead soft". In theory, that allows it to conform to the area that it is sealing better. I'm not sure how much good it does in practice, but it's a pretty simple extra step that shouldn't do any harm...
--DD |
jmalone Heat Exchanger to head nut torque May 22 2013, 09:53 PM
bandjoey Too late tonight to look it up and someone will ge... May 22 2013, 11:41 PM
Jeff Bowlsby The torque value is not printed anywhere. Use onl... May 23 2013, 05:01 AM
jmalone
The torque value is not printed anywhere. Use on... May 23 2013, 09:17 AM
CG-914
The torque value is not printed anywhere. Use on... May 25 2013, 10:45 PM
nathansnathan For a bus they give it 16 (oops, 14 )foot lbs. The... May 23 2013, 09:19 AM
nathansnathan dbl posted May 23 2013, 09:19 AM
stugray I just went through this entire process:
1 - repl... May 23 2013, 09:40 AM
nathansnathan
1 - rep... May 23 2013, 11:17 AM
Tom By using anti-seize on the threads, you have now m... May 23 2013, 12:12 PM
cary
By using anti-seize on the threads, you have now ... May 24 2013, 06:05 AM
Marty Yeoman Last time I did this I used McMark's patented ... May 23 2013, 01:13 PM
Kraftwerk
Last time I did this I used McMark's patented... May 23 2013, 02:02 PM
The Cabinetmaker
Last time I did this I used McMark's patente... Oct 23 2013, 02:14 PM
porsche913b_sp
Last time I did this I used McMark's patented... May 23 2013, 11:08 PM
euro911 Last time I did this I used McMark's patented ... Oct 22 2013, 11:13 PM
Haudiosolutions Thought I'd toss in a find, I too just went th... May 24 2013, 06:45 PM
CG-914 :popcorn: May 24 2013, 11:01 PM
Bob L. I did find this...
http://www.tunacan.net/t4/refer... May 25 2013, 11:24 PM
bandjoey Why do you anneal? What does Annealing do to the ... Oct 23 2013, 08:31 AM
jimkelly I've seen a thread where the guy took a long f... Oct 23 2013, 03:16 PM
rhodyguy light, even dressing with a big bastard file is pr... Oct 24 2013, 06:10 AM
nathansnathan Also, you have to take off a much from the tops of... Oct 24 2013, 06:39 AM
rhodyguy usually the first pass with the file shows how muc... Oct 24 2013, 06:51 AM![]() ![]() |
Lo-Fi Version | Time is now: 2nd April 2026 - 05:35 PM |
