skline |
Born to Drive ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 7,910 Joined: 26-December 02 From: Costa Mesa, CA Member No.: 17 Region Association: Southern California ![]() |
914 with 2.6 liter big 4, 1971 914. Just installed the engine back in the car after redoing the heads on it. The oil cooler was mounted under the trunk above the heat exchangers. I didnt feel that was really a good location for it since the heat from the exchangers rises directly up to the oil cooler. I have decided to mount it in front of the cooling fan on the front of the engine, has anyone ever done this before? I know the air being drawn in to the engine will pull cool air through the cooler thereby giving it plenty of air flow. Do you think this will work? I know the 911's have a cooler mounted on the engine lid above the engine so I was thinking this would work the same way. The other option would be to try to mount it to the engine lid in a similar fashion. I just wanted to get some feedback on this and see if anyone else thinks this will work. I have not mounted it yet and was hoping for some input before I do it later this morning.
skline |
So without running new lines all the way to the front, what is another option for this cooler location? I am running out of time and options. What if I mount it higher in the engine compartment? Up by the engine lid vent? The hoses are the expensive steel braided from Earls plumbing and use AN fittings, he spent like $250.00 just on the fittings and hoses and they are not long enough to go to the front. Any suggestions?
Lo-Fi Version | Time is now: 8th July 2025 - 08:50 PM |
