| Shindog1961 |
Oct 27 2013, 11:46 PM
Member ![]() ![]() Group: Members Posts: 196 Joined: 10-November 12 From: Santa Fe New Mexico Member No.: 15,133 Region Association: Southwest Region |
The new Panorama has a story on a Karman Ghia body being fit to a Boxster, it got me thinking. I have seen Suby swaps, Chevy swaps what about a Boxster engine in a 914? Would it be cost prohibitive? Anyone done the swap?
| pcar916 |
Oct 28 2013, 07:41 AM
Is that a Lola? ![]() ![]() ![]() Group: Members Posts: 1,524 Joined: 2-June 05 From: Little Rock, AR Member No.: 4,188 Region Association: None
According to other threads here and there, that engine is considerably wider, so it won't go easily in between the suspension points. I haven't done the measurements personally so...
Now, if you want to cut off the body immediately behind the cockpit, you could bolt on a tube-frame rear end and put anything you want back there. Perhaps a 12 cylinder 917 engine! Then you get to choose a competitive rear suspension as well. |
Shindog1961 Boxster engine swap? Oct 27 2013, 11:46 PM
BIGKAT_83 Here you go. Boxster swap
Looks pretty good. Oct 28 2013, 08:30 AM
SirAndy Looks pretty good.
:confused: Oct 28 2013, 10:17 AM
shuie
Looks pretty good.
... Oct 28 2013, 10:48 AM
r_towle looks like it fits, but in reading the thread it s... Oct 28 2013, 10:44 AM
Woody This gives me so many bad ideas. Cams, rods, bette... Oct 28 2013, 12:10 PM
r_towle
This gives me so many bad ideas. Cams, rods, bett... Oct 28 2013, 05:44 PM
Woody
This gives me so many bad ideas. Cams, rods, bet... Oct 29 2013, 06:29 AM
r_towle
[quote name='r_towle' post='1948190' date='Oct 28... Oct 29 2013, 01:43 PM
Woody
[quote name='r_towle' post='1948190' date='Oct 2... Oct 29 2013, 02:22 PM
Jake Raby Its all good... Till you lose an IMS Bearing, or g... Oct 28 2013, 05:42 PM
skeates
Its all good... Till you lose an IMS Bearing, or ... Oct 28 2013, 05:52 PM
Woody
Its all good... Till you lose an IMS Bearing, or... Oct 29 2013, 06:31 AM
veltror Much Better,
http://www.build-threads.com/build-t... Oct 28 2013, 06:00 PM
kg6dxn
Much Better,
http://www.build-threads.com/build-... Oct 28 2013, 08:32 PM
Jon H.
These guys, Wicked Garage, are building one now.... Oct 29 2013, 02:57 PM
dfelz
Much Better,
http://www.build-threads.com/build-... Oct 29 2013, 12:50 PM
BIGKAT_83 I have a 3.4L out of a 996 and plan to give it a t... Oct 29 2013, 03:24 PM
Woody
I have a 3.4L out of a 996 and plan to give it a ... Oct 29 2013, 03:42 PM![]() ![]() |
Lo-Fi Version | Time is now: 2nd April 2026 - 10:03 AM |
