> Alternator Light Can you Use an LED, Replacing the alternator light with an LED bulb
LotusJoe
post Oct 29 2013, 02:13 PM
Europa Twink Driver
Can you replace the alternator bulb in the dash with an LED? Will the circuit still operate correctly? (IMG:style_emoticons/default/confused24.gif)
timothy_nd28
post Oct 29 2013, 03:01 PM
Yes you could add a resistor to simulate the same load, but then again why? I understand adding LED lamps to better help illuminate the backlighting, but there is no issue with the incandescent bulbs for the indicator ports. These port tubes direct the light to the filter lens, and is bright enough. I just don't understand what is gained from using LED's for indicators (IMG:style_emoticons/default/confused24.gif)
- Lo-Fi Version Time is now: 2nd April 2026 - 01:10 PM
