| LotusJoe |
Oct 29 2013, 02:13 PM
Europa Twink Driver ![]() ![]() Group: Members Posts: 406 Joined: 30-November 09 From: Southern California Member No.: 11,085 Region Association: Southern California |
Can you replace the alternator bulb in the dash with an LED? Will the circuit still operate correctly? (IMG:style_emoticons/default/confused24.gif)
| Mikey914 |
Oct 29 2013, 03:05 PM
The rubber man ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 12,772 Joined: 27-December 04 From: Hillsboro, OR Member No.: 3,348 Region Association: None
I just use a reg bulb for the charging circut. Also, An LED on the Oil light can illuminate at a lower voltage so it will be more sensitive.
LotusJoe Alternator Light Can you Use an LED Oct 29 2013, 02:13 PM
timothy_nd28 No, the LED will cause your car to stop charging. Oct 29 2013, 02:17 PM
LotusJoe
No, the LED will cause your car to stop charging.... Oct 29 2013, 02:53 PM
timothy_nd28 Yes you could add a resistor to simulate the same ... Oct 29 2013, 03:01 PM
LotusJoe
Yes you could add a resistor to simulate the same... Oct 29 2013, 03:25 PM
Mikey914 Correct me if I'm wrong, but as I understand t... Oct 29 2013, 03:07 PM
nathansnathan The problem, as I understand it, is that the indic... Oct 29 2013, 03:10 PM
timothy_nd28 quick and easy fix "I think", keep the L... Oct 29 2013, 03:33 PM
LotusJoe
quick and easy fix "I think", keep the ... Oct 29 2013, 03:44 PM
stugray
Actually that is close. The LED only flows a few... Oct 29 2013, 04:02 PM
LotusJoe
Actually that is close. The LED only flows a fe... Oct 29 2013, 04:11 PM
stugray
yes, as a matter of fact you can just use the bul... Oct 29 2013, 05:04 PM
LotusJoe
yes, as a matter of fact you can just use the bu... Oct 29 2013, 05:32 PM![]() ![]() |
Lo-Fi Version | Time is now: 2nd April 2026 - 01:05 PM |
