| LotusJoe |
Oct 29 2013, 02:13 PM
Europa Twink Driver ![]() ![]() Group: Members Posts: 406 Joined: 30-November 09 From: Southern California Member No.: 11,085 Region Association: Southern California |
Can you replace the alternator bulb in the dash with an LED? Will the circuit still operate correctly? (IMG:style_emoticons/default/confused24.gif)
| timothy_nd28 |
Oct 29 2013, 03:33 PM
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 2,299 Joined: 25-September 07 From: IN Member No.: 8,154 Region Association: Upper MidWest
quick and easy fix "I think", keep the LED installed, but wire the incandescent lamp in parallel. Use some heat shrink around the bulb to kill the light.
LotusJoe Alternator Light Can you Use an LED Oct 29 2013, 02:13 PM
timothy_nd28 No, the LED will cause your car to stop charging. Oct 29 2013, 02:17 PM
LotusJoe
No, the LED will cause your car to stop charging.... Oct 29 2013, 02:53 PM
timothy_nd28 Yes you could add a resistor to simulate the same ... Oct 29 2013, 03:01 PM
LotusJoe
Yes you could add a resistor to simulate the same... Oct 29 2013, 03:25 PM
Mikey914 I just use a reg bulb for the charging circut. Als... Oct 29 2013, 03:05 PM
Mikey914 Correct me if I'm wrong, but as I understand t... Oct 29 2013, 03:07 PM
nathansnathan The problem, as I understand it, is that the indic... Oct 29 2013, 03:10 PM
LotusJoe
quick and easy fix "I think", keep the ... Oct 29 2013, 03:44 PM
stugray
Actually that is close. The LED only flows a few... Oct 29 2013, 04:02 PM
LotusJoe
Actually that is close. The LED only flows a fe... Oct 29 2013, 04:11 PM
stugray
yes, as a matter of fact you can just use the bul... Oct 29 2013, 05:04 PM
LotusJoe
yes, as a matter of fact you can just use the bu... Oct 29 2013, 05:32 PM![]() ![]() |
Lo-Fi Version | Time is now: 2nd April 2026 - 02:57 PM |
