> for some reason, when i pull hazard switch, my fuel pump goes on (flashes on off), - carbed v8
jimkelly
post Oct 31 2013, 10:38 AM
Delaware USA
my fuel pump also goes on when hazard switch is not pulled but key is turned.
the circuits have got to be connected somehow???
could this be a faulty relay board?
or could it be that I put a wire on the wrong spot on the fuse box?
my engine is a carbed sbc v8.
i'm using the 2 harness wires to power my fuel pump.
thanks
jim
jimkelly
post Oct 31 2013, 12:50 PM
Delaware USA
seems my 14 pin plug has power at 12 and 14 pins with key off.
with ignition key turned, 12, 14, and 8 and 3, have power.
I was expecting one pin to flash with the hazards but none did. but I guess without plug connected to relay panel, that was an ill conceived expectation.
pins 11 and 6 are empty.
its got to be how I wired my fuse box???
jimkelly   for some reason, when i pull hazard switch, my fuel pump goes on (flashes on off)   Oct 31 2013, 10:38 AM
Dave_Darling   Since it isn't stock, the first thing to do is...   Oct 31 2013, 10:51 AM
ConeDodger   Ha! The old Bumblebee Racer used that as a the...   Oct 31 2013, 10:53 AM
mepstein   Ha! The old Bumblebee Racer used that as a th...   Oct 31 2013, 08:16 PM
rhodyguy   stock pump harness with new pump end connections?   Oct 31 2013, 10:54 AM
jimkelly   yes - fuel pump connected to stock harness, like i...   Oct 31 2013, 11:00 AM
jimkelly   seems my 14 pin plug has power at 12 and 14 pins w...   Oct 31 2013, 12:50 PM
Spoke   seems my 14 pin plug has power at 12 and 14 pins ...   Oct 31 2013, 09:03 PM
r_towle   seems my 14 pin plug has power at 12 and 14 pins ...   Nov 1 2013, 02:47 PM
r_towle   go back to the fuse panel and find the black/red s...   Oct 31 2013, 01:30 PM
jimkelly   there is a black/red wire at the fuse box but it d...   Oct 31 2013, 02:25 PM
Dave_Darling   Do you even have an ECU? With a carb'ed V8, I...   Oct 31 2013, 05:13 PM
jimkelly   nope, no ecu. this car ran before, wired like i...   Oct 31 2013, 05:37 PM
HalfMoon   I also have a dark one (v-8 converted) and experie...   Oct 31 2013, 06:20 PM
Spoke   The use of the relay on the relay board to turn th...   Oct 31 2013, 07:17 PM
jimkelly   nope - pump did not work with coiled wire (which a...   Oct 31 2013, 07:42 PM
Spoke   nope - pump did not work with coiled wire (which a...   Oct 31 2013, 08:09 PM
jimkelly   jim: nope - pump did not work with coiled wire (wh...   Oct 31 2013, 08:25 PM
Spoke   JIM: WITH KEY OFF AND HAZARDS PULLED, LIGHTS BLINK...   Oct 31 2013, 08:47 PM
jimkelly   I need to figure out which of my 4 relays are for ...   Oct 31 2013, 07:18 PM
Spoke   I need to figure out which of my 4 relays are for...   Oct 31 2013, 08:01 PM
jimkelly   also, do I need the volt regulator (I thought my G...   Oct 31 2013, 07:51 PM
Rand   .   Oct 31 2013, 08:05 PM
jimkelly   spoke Q: With key off and flashers on: pin 8 volta...   Nov 1 2013, 05:12 AM
Spoke   spoke Q: With key off and flashers on: pin 8 volt...   Nov 1 2013, 05:20 AM
jimkelly   I have been using a headlight and some long wires ...   Nov 1 2013, 07:53 AM
Spoke   I am getting surging power at pin 8 on the 14 pin...   Nov 1 2013, 10:30 AM
rhodyguy   what happens when you disconnect the flasher relay...   Nov 1 2013, 08:29 AM
jimkelly   where is flasher relay? is that the one under the...   Nov 1 2013, 08:50 AM
rhodyguy   looking in aa catalog for the #, not sure of the a...   Nov 1 2013, 08:57 AM
rhodyguy   and prob feel the click while activated.   Nov 1 2013, 10:38 AM
jimkelly   I will trace the black wire. I tried to feel clic...   Nov 1 2013, 10:50 AM
rhodyguy   if you haven't found the hazard system in the ...   Nov 1 2013, 11:35 AM
jimkelly   but where does it cross over into my fuel pump har...   Nov 1 2013, 11:36 AM
jimkelly   all 4 relays out - and hazards still work and FP s...   Nov 1 2013, 11:42 AM
rhodyguy   don't have the computer skills to point to som...   Nov 1 2013, 11:47 AM
rhodyguy   hot wire the pump? switched fuse (cig lighter?), l...   Nov 1 2013, 11:53 AM
jimkelly   yes - good eye. I noticed two weak female connecto...   Nov 1 2013, 12:04 PM
rhodyguy   ok, brown/ground. what does the fuse it goes to co...   Nov 1 2013, 12:18 PM
jimkelly   the wire went to this fuse. this is the other sid...   Nov 1 2013, 12:33 PM
Dave_Darling   Brown should never connect to a fuse. Ever. The ...   Nov 1 2013, 12:43 PM
jimkelly   thanks dave. the wire looks very brown in the abo...   Nov 1 2013, 01:11 PM
Jeff Bowlsby   If I had to guess, you've somehow midwired the...   Nov 1 2013, 03:43 PM
jimkelly   it makes some sense but so hard to believe. here ...   Nov 1 2013, 04:33 PM
Spoke   There is a wire misconnected somewhere. Here's...   Nov 1 2013, 05:19 PM
jimkelly   something is wrong for sure as my horn and wipers ...   Nov 1 2013, 05:36 PM
jimkelly   ok, I tried it. but before I did, due to looking ...   Nov 1 2013, 05:48 PM
r_towle   This is awesome Jim....sorry for you but it's ...   Nov 1 2013, 06:06 PM
jimkelly   I feel a little better now. I am gonna put some g...   Nov 1 2013, 06:13 PM
rhodyguy   whew…that's a load off huh? good work.   Nov 1 2013, 07:14 PM
jimkelly   and they say that british cars have wiring issues....   Nov 1 2013, 07:49 PM
- Lo-Fi Version Time is now: 12th August 2026 - 05:12 AM
