| jimkelly |
Oct 31 2013, 10:38 AM
Delaware USA ![]() ![]() ![]() ![]() Group: Members Posts: 4,969 Joined: 5-August 04 From: Delaware, USA Member No.: 2,460 Region Association: MidAtlantic Region |
my fuel pump also goes on when hazard switch is not pulled but key is turned.
the circuits have got to be connected somehow??? could this be a faulty relay board? or could it be that I put a wire on the wrong spot on the fuse box? my engine is a carbed sbc v8. i'm using the 2 harness wires to power my fuel pump. thanks jim Attached image(s)
| Dave_Darling |
Oct 31 2013, 05:13 PM
914 Idiot ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 15,356 Joined: 9-January 03 From: Silicon Valley / Kailua-Kona Member No.: 121 Region Association: Northern California
Do you even have an ECU? With a carb'ed V8, I sincerely doubt it.
Trace the wires. Seriously--trace them. Start at the pump, look at the wire color, trace that back through the wiring harness to wherever it goes. If it goes to the relay board, look at a relay board diagram to see if it connects to anything else in there. (Some do, some don't.) Keep tracing the wire until you get to one or another of the switches. Someone did the conversion to V8. That means the stock fuel injection doesn't work. So the pump control circuitry had to be changed. You need to figure out how it was changed, so you can start troubleshooting. --DD |
jimkelly for some reason, when i pull hazard switch, my fuel pump goes on (flashes on off) Oct 31 2013, 10:38 AM
Dave_Darling Since it isn't stock, the first thing to do is... Oct 31 2013, 10:51 AM
ConeDodger Ha! The old Bumblebee Racer used that as a the... Oct 31 2013, 10:53 AM
Ha! The old Bumblebee Racer used that as a th... Oct 31 2013, 08:16 PM
rhodyguy stock pump harness with new pump end connections? Oct 31 2013, 10:54 AM
jimkelly yes - fuel pump connected to stock harness, like i... Oct 31 2013, 11:00 AM
jimkelly seems my 14 pin plug has power at 12 and 14 pins w... Oct 31 2013, 12:50 PM
Spoke
seems my 14 pin plug has power at 12 and 14 pins ... Oct 31 2013, 09:03 PM
r_towle
seems my 14 pin plug has power at 12 and 14 pins ... Nov 1 2013, 02:47 PM
r_towle go back to the fuse panel and find the black/red s... Oct 31 2013, 01:30 PM
jimkelly there is a black/red wire at the fuse box but it d... Oct 31 2013, 02:25 PM
jimkelly nope, no ecu.
this car ran before, wired like i... Oct 31 2013, 05:37 PM
HalfMoon I also have a dark one (v-8 converted) and experie... Oct 31 2013, 06:20 PM
Spoke The use of the relay on the relay board to turn th... Oct 31 2013, 07:17 PM
jimkelly nope - pump did not work with coiled wire (which a... Oct 31 2013, 07:42 PM
Spoke nope - pump did not work with coiled wire (which a... Oct 31 2013, 08:09 PM
jimkelly jim: nope - pump did not work with coiled wire (wh... Oct 31 2013, 08:25 PM
Spoke JIM: WITH KEY OFF AND HAZARDS PULLED, LIGHTS BLINK... Oct 31 2013, 08:47 PM
jimkelly I need to figure out which of my 4 relays are for ... Oct 31 2013, 07:18 PM
Spoke
I need to figure out which of my 4 relays are for... Oct 31 2013, 08:01 PM
jimkelly also, do I need the volt regulator (I thought my G... Oct 31 2013, 07:51 PM
Rand . Oct 31 2013, 08:05 PM
jimkelly spoke Q: With key off and flashers on: pin 8 volta... Nov 1 2013, 05:12 AM
Spoke
spoke Q: With key off and flashers on: pin 8 volt... Nov 1 2013, 05:20 AM
jimkelly I have been using a headlight and some long wires ... Nov 1 2013, 07:53 AM
Spoke
I am getting surging power at pin 8 on the 14 pin... Nov 1 2013, 10:30 AM
rhodyguy what happens when you disconnect the flasher relay... Nov 1 2013, 08:29 AM
jimkelly where is flasher relay? is that the one under the... Nov 1 2013, 08:50 AM
rhodyguy looking in aa catalog for the #, not sure of the a... Nov 1 2013, 08:57 AM
rhodyguy and prob feel the click while activated. Nov 1 2013, 10:38 AM
jimkelly I will trace the black wire. I tried to feel clic... Nov 1 2013, 10:50 AM
rhodyguy if you haven't found the hazard system in the ... Nov 1 2013, 11:35 AM
jimkelly but where does it cross over into my fuel pump har... Nov 1 2013, 11:36 AM
jimkelly all 4 relays out - and hazards still work and FP s... Nov 1 2013, 11:42 AM
rhodyguy don't have the computer skills to point to som... Nov 1 2013, 11:47 AM
rhodyguy hot wire the pump? switched fuse (cig lighter?), l... Nov 1 2013, 11:53 AM
jimkelly yes - good eye. I noticed two weak female connecto... Nov 1 2013, 12:04 PM
rhodyguy ok, brown/ground. what does the fuse it goes to co... Nov 1 2013, 12:18 PM
jimkelly the wire went to this fuse. this is the other sid... Nov 1 2013, 12:33 PM
Dave_Darling Brown should never connect to a fuse. Ever.
The ... Nov 1 2013, 12:43 PM
jimkelly thanks dave.
the wire looks very brown in the abo... Nov 1 2013, 01:11 PM
Jeff Bowlsby If I had to guess, you've somehow midwired the... Nov 1 2013, 03:43 PM
jimkelly it makes some sense but so hard to believe.
here ... Nov 1 2013, 04:33 PM
Spoke There is a wire misconnected somewhere. Here's... Nov 1 2013, 05:19 PM
jimkelly something is wrong for sure as my horn and wipers ... Nov 1 2013, 05:36 PM
jimkelly ok, I tried it.
but before I did, due to looking ... Nov 1 2013, 05:48 PM
r_towle This is awesome Jim....sorry for you but it's ... Nov 1 2013, 06:06 PM
jimkelly I feel a little better now.
I am gonna put some g... Nov 1 2013, 06:13 PM
rhodyguy whew…that's a load off huh? good work. Nov 1 2013, 07:14 PM
jimkelly and they say that british cars have wiring issues.... Nov 1 2013, 07:49 PM![]() ![]() |
Lo-Fi Version | Time is now: 12th August 2026 - 05:12 AM |
