> for some reason, when i pull hazard switch, my fuel pump goes on (flashes on off), - carbed v8
jimkelly
post Oct 31 2013, 10:38 AM
Delaware USA
my fuel pump also goes on when hazard switch is not pulled but key is turned.
the circuits have got to be connected somehow???
could this be a faulty relay board?
or could it be that I put a wire on the wrong spot on the fuse box?
my engine is a carbed sbc v8.
i'm using the 2 harness wires to power my fuel pump.
thanks
jim
Spoke
post Oct 31 2013, 07:17 PM
Jerry
The use of the relay on the relay board to turn the FP on is a good idea. The FP may draw a lot of current which is why you wouldn't want to run this current through the key via a switched positive.
Like Dave said, trace the wiring to/from the fuel pump.
Try this test: turn on the flashers on (which I think turns the pump on), then disconnect the coiled red wire from the relay board. The FP may stay running. If it does, then something besides the relay is powering the FP.
jimkelly
post Oct 31 2013, 07:42 PM
Delaware USA
nope - pump did not work with coiled wire (which acts as ground) disconnected from relay board.
though if I leave this wire connected, but run positive wire from fuel pump directly to battery positive, it runs fine.
so the ground thru the relay board is not the problem, the fuel pump harness positive seems to be the problem.
though I did try to get positive from my fuel pump from this spade (pic below) and ground to body, and same problem.
seems to me that these 4 spades on the relay board for fuel injection harness has an issue?
(IMG:http://www.914world.com/bbs2/uploads/post-7407-1320344447.jpg)
jim
QUOTE(Spoke @ Oct 31 2013, 06:17 PM) *
Spoke
post Oct 31 2013, 08:09 PM
Jerry
Spoke: This is expected with the key on. Please explain what else was happening here. Key on/off? Flasher on/off?
Spoke: What you did here was power the FP from the battery. FP has 2 contacts. One is ground, the other powered to 12V through the relay board relay. You bypassed the relay and powered directly from the battery.
Spoke: Try this, key off, flasher on. I think you said the FP runs, correct? Remove the 2nd relay looking from the rear of the car. Counting relay sockets here. Does the FP still run? Trying to see if you have a short in wiring to the FP. Also is the FP in the front of the car?
Spoke: Not necessarily a problem. You only need the front left spade to be ground like you had. This turns on the FP relay. Normally the FI would ground this to run the FP.
jimkelly
post Oct 31 2013, 08:25 PM
Delaware USA
jim: nope - pump did not work with coiled wire (which acts as ground) disconnected from relay board.
JIM: WITH KEY OFF AND HAZARDS PULLED, LIGHTS BLINK AS THEY SHOULD AND FUEL PUMP GOES ON AND OFF WITH LIGHTS. WITH HAZARDS NOT PULLED, BUT IGN KEY ON, FUEL PUMP RUNS STEADY. I HESITATE TO SEE WHAT HAPPENS WITH KEY TURNED AND HAZARD SWITCH PULLED.
JIM: OH.
JIM: DID THIS AND FUEL PUMP DID NOT RUN.
>> 2 FRESH PICS <<
jimkelly   for some reason, when i pull hazard switch, my fuel pump goes on (flashes on off)   Oct 31 2013, 10:38 AM
Dave_Darling   Since it isn't stock, the first thing to do is...   Oct 31 2013, 10:51 AM
ConeDodger   Ha! The old Bumblebee Racer used that as a the...   Oct 31 2013, 10:53 AM
mepstein   Ha! The old Bumblebee Racer used that as a th...   Oct 31 2013, 08:16 PM
rhodyguy   stock pump harness with new pump end connections?   Oct 31 2013, 10:54 AM
jimkelly   yes - fuel pump connected to stock harness, like i...   Oct 31 2013, 11:00 AM
jimkelly   seems my 14 pin plug has power at 12 and 14 pins w...   Oct 31 2013, 12:50 PM
Spoke   seems my 14 pin plug has power at 12 and 14 pins ...   Oct 31 2013, 09:03 PM
r_towle   seems my 14 pin plug has power at 12 and 14 pins ...   Nov 1 2013, 02:47 PM
r_towle   go back to the fuse panel and find the black/red s...   Oct 31 2013, 01:30 PM
jimkelly   there is a black/red wire at the fuse box but it d...   Oct 31 2013, 02:25 PM
Dave_Darling   Do you even have an ECU? With a carb'ed V8, I...   Oct 31 2013, 05:13 PM
jimkelly   nope, no ecu. this car ran before, wired like i...   Oct 31 2013, 05:37 PM
HalfMoon   I also have a dark one (v-8 converted) and experie...   Oct 31 2013, 06:20 PM
Spoke   The use of the relay on the relay board to turn th...   Oct 31 2013, 07:17 PM
jimkelly   nope - pump did not work with coiled wire (which a...   Oct 31 2013, 07:42 PM
Spoke   nope - pump did not work with coiled wire (which a...   Oct 31 2013, 08:09 PM
jimkelly   jim: nope - pump did not work with coiled wire (wh...   Oct 31 2013, 08:25 PM
Spoke   JIM: WITH KEY OFF AND HAZARDS PULLED, LIGHTS BLINK...   Oct 31 2013, 08:47 PM
jimkelly   I need to figure out which of my 4 relays are for ...   Oct 31 2013, 07:18 PM
Spoke   I need to figure out which of my 4 relays are for...   Oct 31 2013, 08:01 PM
jimkelly   also, do I need the volt regulator (I thought my G...   Oct 31 2013, 07:51 PM
Rand   .   Oct 31 2013, 08:05 PM
jimkelly   spoke Q: With key off and flashers on: pin 8 volta...   Nov 1 2013, 05:12 AM
Spoke   spoke Q: With key off and flashers on: pin 8 volt...   Nov 1 2013, 05:20 AM
jimkelly   I have been using a headlight and some long wires ...   Nov 1 2013, 07:53 AM
Spoke   I am getting surging power at pin 8 on the 14 pin...   Nov 1 2013, 10:30 AM
rhodyguy   what happens when you disconnect the flasher relay...   Nov 1 2013, 08:29 AM
jimkelly   where is flasher relay? is that the one under the...   Nov 1 2013, 08:50 AM
rhodyguy   looking in aa catalog for the #, not sure of the a...   Nov 1 2013, 08:57 AM
rhodyguy   and prob feel the click while activated.   Nov 1 2013, 10:38 AM
jimkelly   I will trace the black wire. I tried to feel clic...   Nov 1 2013, 10:50 AM
rhodyguy   if you haven't found the hazard system in the ...   Nov 1 2013, 11:35 AM
jimkelly   but where does it cross over into my fuel pump har...   Nov 1 2013, 11:36 AM
jimkelly   all 4 relays out - and hazards still work and FP s...   Nov 1 2013, 11:42 AM
rhodyguy   don't have the computer skills to point to som...   Nov 1 2013, 11:47 AM
rhodyguy   hot wire the pump? switched fuse (cig lighter?), l...   Nov 1 2013, 11:53 AM
jimkelly   yes - good eye. I noticed two weak female connecto...   Nov 1 2013, 12:04 PM
rhodyguy   ok, brown/ground. what does the fuse it goes to co...   Nov 1 2013, 12:18 PM
jimkelly   the wire went to this fuse. this is the other sid...   Nov 1 2013, 12:33 PM
Dave_Darling   Brown should never connect to a fuse. Ever. The ...   Nov 1 2013, 12:43 PM
jimkelly   thanks dave. the wire looks very brown in the abo...   Nov 1 2013, 01:11 PM
Jeff Bowlsby   If I had to guess, you've somehow midwired the...   Nov 1 2013, 03:43 PM
jimkelly   it makes some sense but so hard to believe. here ...   Nov 1 2013, 04:33 PM
Spoke   There is a wire misconnected somewhere. Here's...   Nov 1 2013, 05:19 PM
jimkelly   something is wrong for sure as my horn and wipers ...   Nov 1 2013, 05:36 PM
jimkelly   ok, I tried it. but before I did, due to looking ...   Nov 1 2013, 05:48 PM
r_towle   This is awesome Jim....sorry for you but it's ...   Nov 1 2013, 06:06 PM
jimkelly   I feel a little better now. I am gonna put some g...   Nov 1 2013, 06:13 PM
rhodyguy   whew…that's a load off huh? good work.   Nov 1 2013, 07:14 PM
jimkelly   and they say that british cars have wiring issues....   Nov 1 2013, 07:49 PM
- Lo-Fi Version Time is now: 12th August 2026 - 05:13 AM
