I hate my Carbs Much Less, Chris Foley is a God! |
Mblizzard |
Oct 30 2013, 12:13 PM
Advanced Member Group: Members Posts: 3,033 Joined: 28-January 13 From: Knoxville Tn Member No.: 15,438 Region Association: South East States |
Well after much playing and changing I have to say I hate my carbs. I have done every jet size and I can't really get it to run well on anything but 70 idle jets and that is way to rich. With 60s it runs not quite as rich but the hesitation on the initial throttle is huge.
Have played with the adjustments and I think I have it running well but it never performs well. 2056 just built, 44 IDFs, 60 idle jets, 28 vents, 135 mains, F-11 emulsion tubs, 175 air correction jets. Timing at 27 to 30. SVDA Dizzy with electronic ignition. Valves recent set and rechecked. Synced at idle and 1500 rpm. Runs well at higher rev and pulls strong but I can't get rid of that hesitation. I know there will always be some but at times from a dead stop it almost stalls. What am I missing? (IMG:style_emoticons/default/headbang.gif) (IMG:style_emoticons/default/headbang.gif) Gone through all of the Weber tech trouble shooting steps and I can't find anything that says I have something wrong. Is there an adjustment on the accelerator pump? Or do I need to up the accelerator jet? I will be going back to FI at some point but these carbs should work better than they do. Taking it to Eurohaus tomorrow maybe they will have better luck. Suggestions? |
rhodyguy |
Nov 1 2013, 08:47 AM
Chimp Sanctuary NW. Check it out. Group: Members Posts: 22,093 Joined: 2-March 03 From: Orion's Bell. The BELL! Member No.: 378 Region Association: Galt's Gulch |
that's why i ask folks to back off one of the throttle stop/idle speed adj screws and use the other one to increase the engine speed to a nice stable idle. not the gas pedal. while the vacuum may read the same at idle with the screws in contact, as you tip the throttle in things can change. this takes about 5 minutes, will tell you if the linkage is set properly when off idle and the progression ports are being uncovered at the same rate.
Lo-Fi Version | Time is now: 11th June 2024 - 09:26 AM |
