> for some reason, when i pull hazard switch, my fuel pump goes on (flashes on off), - carbed v8
jimkelly
post Oct 31 2013, 10:38 AM
Delaware USA
my fuel pump also goes on when hazard switch is not pulled but key is turned.
the circuits have got to be connected somehow???
could this be a faulty relay board?
or could it be that I put a wire on the wrong spot on the fuse box?
my engine is a carbed sbc v8.
i'm using the 2 harness wires to power my fuel pump.
thanks
jim
jimkelly
post Oct 31 2013, 12:50 PM
Delaware USA
seems my 14 pin plug has power at 12 and 14 pins with key off.
with ignition key turned, 12, 14, and 8 and 3, have power.
I was expecting one pin to flash with the hazards but none did. but I guess without plug connected to relay panel, that was an ill conceived expectation.
pins 11 and 6 are empty.
its got to be how I wired my fuse box???
r_towle
post Nov 1 2013, 02:47 PM
Custom Member
QUOTE(jimkelly @ Oct 31 2013, 02:50 PM) *
What magic color is the wire on pin number 13? From the post above, hand drawn diagram on page one of this thread.
No meter needed to follow this wire...just unwrap tape and find it all the way back to a power source...you need to physically see where the wire is getting its power from.
Someone may have changed color of wire along the way...so look for the area that may have been patched.
trace that wire through the relay board (meter), through the tunnel...(eyeballs)
find it when it comes out of the tunnel harness and heads up towards the fuse panel.
Eyeballs again.
Follow it to power (eyeballs and meter)...it may be fed by the wrong side of the flasher relay and your flasher relay is broken, or just wired wrong.
I recall you stated that the area above the fuse panel had a meltown or fire....so who knows what they did when putting it back together.
Rich
jimkelly   for some reason, when i pull hazard switch, my fuel pump goes on (flashes on off)   Oct 31 2013, 10:38 AM
Dave_Darling   Since it isn't stock, the first thing to do is...   Oct 31 2013, 10:51 AM
ConeDodger   Ha! The old Bumblebee Racer used that as a the...   Oct 31 2013, 10:53 AM
mepstein   Ha! The old Bumblebee Racer used that as a th...   Oct 31 2013, 08:16 PM
rhodyguy   stock pump harness with new pump end connections?   Oct 31 2013, 10:54 AM
jimkelly   yes - fuel pump connected to stock harness, like i...   Oct 31 2013, 11:00 AM
jimkelly   seems my 14 pin plug has power at 12 and 14 pins w...   Oct 31 2013, 12:50 PM
Spoke   seems my 14 pin plug has power at 12 and 14 pins ...   Oct 31 2013, 09:03 PM
r_towle   seems my 14 pin plug has power at 12 and 14 pins ...   Nov 1 2013, 02:47 PM
r_towle   go back to the fuse panel and find the black/red s...   Oct 31 2013, 01:30 PM
jimkelly   there is a black/red wire at the fuse box but it d...   Oct 31 2013, 02:25 PM
Dave_Darling   Do you even have an ECU? With a carb'ed V8, I...   Oct 31 2013, 05:13 PM
jimkelly   nope, no ecu. this car ran before, wired like i...   Oct 31 2013, 05:37 PM
HalfMoon   I also have a dark one (v-8 converted) and experie...   Oct 31 2013, 06:20 PM
Spoke   The use of the relay on the relay board to turn th...   Oct 31 2013, 07:17 PM
jimkelly   nope - pump did not work with coiled wire (which a...   Oct 31 2013, 07:42 PM
Spoke   nope - pump did not work with coiled wire (which a...   Oct 31 2013, 08:09 PM
jimkelly   jim: nope - pump did not work with coiled wire (wh...   Oct 31 2013, 08:25 PM
Spoke   JIM: WITH KEY OFF AND HAZARDS PULLED, LIGHTS BLINK...   Oct 31 2013, 08:47 PM
jimkelly   I need to figure out which of my 4 relays are for ...   Oct 31 2013, 07:18 PM
Spoke   I need to figure out which of my 4 relays are for...   Oct 31 2013, 08:01 PM
jimkelly   also, do I need the volt regulator (I thought my G...   Oct 31 2013, 07:51 PM
Rand   .   Oct 31 2013, 08:05 PM
jimkelly   spoke Q: With key off and flashers on: pin 8 volta...   Nov 1 2013, 05:12 AM
Spoke   spoke Q: With key off and flashers on: pin 8 volt...   Nov 1 2013, 05:20 AM
jimkelly   I have been using a headlight and some long wires ...   Nov 1 2013, 07:53 AM
Spoke   I am getting surging power at pin 8 on the 14 pin...   Nov 1 2013, 10:30 AM
rhodyguy   what happens when you disconnect the flasher relay...   Nov 1 2013, 08:29 AM
jimkelly   where is flasher relay? is that the one under the...   Nov 1 2013, 08:50 AM
rhodyguy   looking in aa catalog for the #, not sure of the a...   Nov 1 2013, 08:57 AM
rhodyguy   and prob feel the click while activated.   Nov 1 2013, 10:38 AM
jimkelly   I will trace the black wire. I tried to feel clic...   Nov 1 2013, 10:50 AM
rhodyguy   if you haven't found the hazard system in the ...   Nov 1 2013, 11:35 AM
jimkelly   but where does it cross over into my fuel pump har...   Nov 1 2013, 11:36 AM
jimkelly   all 4 relays out - and hazards still work and FP s...   Nov 1 2013, 11:42 AM
rhodyguy   don't have the computer skills to point to som...   Nov 1 2013, 11:47 AM
rhodyguy   hot wire the pump? switched fuse (cig lighter?), l...   Nov 1 2013, 11:53 AM
jimkelly   yes - good eye. I noticed two weak female connecto...   Nov 1 2013, 12:04 PM
rhodyguy   ok, brown/ground. what does the fuse it goes to co...   Nov 1 2013, 12:18 PM
jimkelly   the wire went to this fuse. this is the other sid...   Nov 1 2013, 12:33 PM
Dave_Darling   Brown should never connect to a fuse. Ever. The ...   Nov 1 2013, 12:43 PM
jimkelly   thanks dave. the wire looks very brown in the abo...   Nov 1 2013, 01:11 PM
Jeff Bowlsby   If I had to guess, you've somehow midwired the...   Nov 1 2013, 03:43 PM
jimkelly   it makes some sense but so hard to believe. here ...   Nov 1 2013, 04:33 PM
Spoke   There is a wire misconnected somewhere. Here's...   Nov 1 2013, 05:19 PM
jimkelly   something is wrong for sure as my horn and wipers ...   Nov 1 2013, 05:36 PM
jimkelly   ok, I tried it. but before I did, due to looking ...   Nov 1 2013, 05:48 PM
r_towle   This is awesome Jim....sorry for you but it's ...   Nov 1 2013, 06:06 PM
jimkelly   I feel a little better now. I am gonna put some g...   Nov 1 2013, 06:13 PM
rhodyguy   whew…that's a load off huh? good work.   Nov 1 2013, 07:14 PM
jimkelly   and they say that british cars have wiring issues....   Nov 1 2013, 07:49 PM
- Lo-Fi Version Time is now: 12th August 2026 - 05:13 AM
