| worn |
Nov 5 2013, 08:55 AM
Winner of the Utah Twisted Joint Award ![]() ![]() ![]() ![]() Group: Members Posts: 3,658 Joined: 3-June 11 From: Madison, WI and North Bend WA Member No.: 13,152 Region Association: Upper MidWest
It seems that a lot of the triple gauge business involves making new holes in the back of the can. I figured I could do that. Especially after watching the threads here over and over. Thanks to all.
My problem was the gauge face. I di not want a simple cut out for the gauges. I wanted it embossed in like stock. So here is what I came up with. ![]() The dies fit in my old cast iron hydraulic press. You can see the bottom plate in the photo. I am having some tears, but generally they are about at the cut out line (IMG:style_emoticons/default/biggrin.gif) so maybe they are OK. I found that even with some silversmithing under my belt, I cannot do this by hand. The press makes it flat and even. A coat of high build primer, sanding for flat and trimming and a coat of satin black and I am done I think. Then I need to do some wiring. BTW, I am looking for some balled up otherwise useless harness wires so I can match the wire colors. |
| billh1963 |
Nov 5 2013, 10:11 AM
Car Hoarder! ![]() ![]() ![]() ![]() Group: Members Posts: 3,443 Joined: 28-March 11 From: North Carolina Member No.: 12,871 Region Association: South East States |
Will these be available for purchase?
| worn |
Nov 5 2013, 11:09 AM
Will these be available for purchase? I have to see if the quality is OK, etc. My initial idea was show and tell because this is within range for most of us with a little time provided you have a press. Also I have been looking around for press-on letters. Once the staple of architecture and advertising, now very hard to find. I have a sort of OK font and size, but not a perfect match. My design has larger holes for oil temp and pressure than fuel, but the largest spacing is actually at the top, where the oil gauges meet. The holes in the can are evenly spaced, but the sweeps are a bit different. E-bay donors. |
worn I figured on a triple gauge Take-2 see the end. Nov 5 2013, 08:55 AM
timothy_nd28 Awesome, this is the exact way these should be don... Nov 5 2013, 09:03 AM
timothy_nd28 Is there enough material to fold some tabs over?
Nov 5 2013, 09:09 AM
worn
... Nov 5 2013, 09:58 AM
Mark Henry
Yes, I was... Nov 5 2013, 10:33 AM
peteyd have you tried annealing the aluminum first? It sh... Nov 5 2013, 11:16 AM
914forme Way to improve on our original design. :headbang... Nov 5 2013, 11:18 AM
Mblizzard Are you using any lubricant while pressing. That ... Nov 5 2013, 11:26 AM
rdauenhauer Ive got a big ole box of old hacked harnesses LMK ... Nov 5 2013, 09:19 PM
nsr-jamie We use very thin vinly plastic in the presses here... Nov 5 2013, 09:50 PM
John Those are interesting indeed. Once upon a time I ... Nov 5 2013, 10:13 PM
CptTripps GREAT project. Bravo.
...I have nothing to add p... Nov 6 2013, 08:02 AM
arcadeforever beautiful job!! Nov 6 2013, 08:42 AM
r_towle quad gauge please
temp
pressure
fuel
volts Nov 6 2013, 04:14 PM
worn
quad gauge please
temp
pressure
fuel
volts
Tha... Nov 6 2013, 04:22 PM
timothy_nd28 I could order you a furnace, and then have you pic... Nov 6 2013, 04:30 PM
worn OK, triple gauge: take two for Warren
I decided t... Jul 30 2015, 11:08 AM
914forme Oh nice and great job :first: I'll take one,... Jul 30 2015, 11:52 AM
worn
Oh nice and great job :first: I'll take one... Jul 30 2015, 12:00 PM
worn
[quote name='914forme' post='2216774' date='Jul 3... Aug 5 2015, 02:04 PM
914forme
[quote name='914forme' post='2216774' date='Jul 3... Aug 5 2015, 06:52 PM
[quote name='914forme' post='2216774' date='Jul ... Aug 5 2015, 07:31 PM
914forme
[quote name='914forme' post='2219318' date='Aug 5... Aug 6 2015, 04:43 AM
worn
[quote name='914forme' post='2216774' date='Jul ... Aug 6 2015, 02:30 PM
mepstein I'd like one. Jul 30 2015, 12:14 PM
billh1963 Yep...if you decide to sell these put me on a list... Jul 30 2015, 12:20 PM
Valy Wow! Great job! Jul 30 2015, 01:39 PM
'73-914kid Please put me down for a piece as well. Been runni... Jul 30 2015, 01:50 PM
mepstein Put me on your list. I have the 911 gauges ready t... Aug 5 2015, 03:44 PM![]() ![]() |
Lo-Fi Version | Time is now: 28th October 2026 - 08:03 PM |
