> how relay works ?
jimkelly
post Nov 6 2013, 06:02 AM
Delaware USA
and can some describe how a relay works?
is it that HIGH AMPERAGE thru 85 and 86 operate a switch, and when switched send LOW AMPERAGE thru 30 and 87? what is 87A's purpose?
Tom
post Nov 6 2013, 01:09 PM
Relays use a small current to control a much larger current. The round relays in our cars draw about 150 mili Amps, or 0.150 amps. Their contacts can control upwards of 30 Amps. Relay contacts are made out of an alloy that resists arcing when being switched/un-switched, unlike our other switches used in the car. Other switches can have their contacts damaged by switching high current. That is why it is better to have a low current thru your switch and higher current thru the relay.
Tom
jimkelly   how relay works ?   Nov 6 2013, 06:02 AM
914itis   How relay works Have fun   Nov 6 2013, 06:29 AM
arcadeforever   wow, thats a great document! How relay works H...   Nov 6 2013, 06:54 AM
JStroud   How relay works Have fun Nice link, where did y...   Nov 6 2013, 08:44 AM
914itis   [quote name='914itis' post='1952680' date='Nov 6 ...   Nov 6 2013, 10:32 AM
arcadeforever   from what I can see.... oddly enough it appears 87...   Nov 6 2013, 06:49 AM
arcadeforever   Shows how much of a newb I am, lol, I just saw in ...   Nov 6 2013, 07:21 AM
pcar916   To answer in short... When the circuit is comple...   Nov 6 2013, 07:57 AM
pcar916   Bowlsby has a lot of information on his site. htt...   Nov 6 2013, 09:54 AM
Dave_Darling   I also have a write-up, about halfway down in this...   Nov 6 2013, 10:02 AM
pcar916   Forgot about this! That's a great write-up...   Nov 6 2013, 10:07 AM
jimkelly   freakin ingenious. since our cars are run from a...   Nov 6 2013, 10:50 AM
Spoke   freakin ingenious. since our cars are run from ...   Nov 6 2013, 11:53 AM
pcar916   ... i think image is correct? 30 is always a pe...   Nov 7 2013, 03:19 AM
underdog   ... i think image is correct? 30 is always a p...   Nov 7 2013, 07:52 AM
Dave_Darling   30 is always a permanent ground. No, 30 should be...   Nov 7 2013, 09:43 AM
Mike Bellis   Current is limited by the fuse size and to some ex...   Nov 6 2013, 11:41 AM
Mike Bellis   By the way current is stupid and don't know sh...   Nov 6 2013, 11:47 AM
Tom   Relays use a small current to control a much large...   Nov 6 2013, 01:09 PM
r_towle   Current or load is always dictated by the device c...   Nov 6 2013, 05:32 PM
Mike Bellis   Read this...   Nov 6 2013, 08:00 PM
jimkelly   I believe pin 30 is always connected to either 87 ...   Nov 7 2013, 08:41 AM
Spoke   I believe pin 30 is always connected to either 87...   Nov 7 2013, 09:25 AM
Mike Bellis   Relay nomenclature: 30: Common 87: Nomally Open 87...   Nov 7 2013, 09:56 AM
- Lo-Fi Version Time is now: 2nd April 2026 - 11:09 AM
