> how relay works ?
jimkelly
post Nov 6 2013, 06:02 AM
Delaware USA
and can some describe how a relay works?
is it that HIGH AMPERAGE thru 85 and 86 operate a switch, and when switched send LOW AMPERAGE thru 30 and 87? what is 87A's purpose?
r_towle
post Nov 6 2013, 05:32 PM
Custom Member
Current or load is always dictated by the device calling for the power.
Sizing the circuit (wire, fuse, relay) is always dependent upon the device being driven by the power.
Power is not pushed, power is pulled by the device.
Starter motor is a very simple example.
The motor needs 600 CCA (cold cranking amps) so there is no fuse, just a fat wire directly connected to the battery.
The relay for that motor (starter solenoid) needs 20 amps to flip the switch.
So trigger amps requirements are fairly small, while the device amp requirements could be huge.
All electricity is this way...
jimkelly   how relay works ?   Nov 6 2013, 06:02 AM
914itis   How relay works Have fun   Nov 6 2013, 06:29 AM
arcadeforever   wow, thats a great document! How relay works H...   Nov 6 2013, 06:54 AM
JStroud   How relay works Have fun Nice link, where did y...   Nov 6 2013, 08:44 AM
914itis   [quote name='914itis' post='1952680' date='Nov 6 ...   Nov 6 2013, 10:32 AM
arcadeforever   from what I can see.... oddly enough it appears 87...   Nov 6 2013, 06:49 AM
arcadeforever   Shows how much of a newb I am, lol, I just saw in ...   Nov 6 2013, 07:21 AM
pcar916   To answer in short... When the circuit is comple...   Nov 6 2013, 07:57 AM
pcar916   Bowlsby has a lot of information on his site. htt...   Nov 6 2013, 09:54 AM
Dave_Darling   I also have a write-up, about halfway down in this...   Nov 6 2013, 10:02 AM
pcar916   Forgot about this! That's a great write-up...   Nov 6 2013, 10:07 AM
jimkelly   freakin ingenious. since our cars are run from a...   Nov 6 2013, 10:50 AM
Spoke   freakin ingenious. since our cars are run from ...   Nov 6 2013, 11:53 AM
pcar916   ... i think image is correct? 30 is always a pe...   Nov 7 2013, 03:19 AM
underdog   ... i think image is correct? 30 is always a p...   Nov 7 2013, 07:52 AM
Dave_Darling   30 is always a permanent ground. No, 30 should be...   Nov 7 2013, 09:43 AM
Mike Bellis   Current is limited by the fuse size and to some ex...   Nov 6 2013, 11:41 AM
Mike Bellis   By the way current is stupid and don't know sh...   Nov 6 2013, 11:47 AM
Tom   Relays use a small current to control a much large...   Nov 6 2013, 01:09 PM
r_towle   Current or load is always dictated by the device c...   Nov 6 2013, 05:32 PM
Mike Bellis   Read this...   Nov 6 2013, 08:00 PM
jimkelly   I believe pin 30 is always connected to either 87 ...   Nov 7 2013, 08:41 AM
Spoke   I believe pin 30 is always connected to either 87...   Nov 7 2013, 09:25 AM
Mike Bellis   Relay nomenclature: 30: Common 87: Nomally Open 87...   Nov 7 2013, 09:56 AM
- Lo-Fi Version Time is now: 2nd April 2026 - 12:46 PM
