> how relay works ?
jimkelly
post Nov 6 2013, 06:02 AM
Delaware USA
and can some describe how a relay works?
is it that HIGH AMPERAGE thru 85 and 86 operate a switch, and when switched send LOW AMPERAGE thru 30 and 87? what is 87A's purpose?
jimkelly
post Nov 6 2013, 10:50 AM
Delaware USA
freakin ingenious.
since our cars are run from a 12v battery, how does current know to be high or low, simply by the diameter of the wire it passes thru, or the draw of the item being run?
I assume running a circuit with a relay is cheaper than running a circuit thru a switch that can handle more current because of the cost of a better switch and the cost of running more heavy wire throughout the car?
I think I am beigining to understand the purpose of a relay, visually.
thanks guys (IMG:style_emoticons/default/idea.gif)
i think image is correct?
pcar916
post Nov 7 2013, 03:19 AM
Is that a Lola?
QUOTE(jimkelly @ Nov 6 2013, 10:50 AM) *
30 is always a permanent ground. You can check it with an ohmmeter to a chassis ground point.
jimkelly   how relay works ?   Nov 6 2013, 06:02 AM
914itis   How relay works Have fun   Nov 6 2013, 06:29 AM
arcadeforever   wow, thats a great document! How relay works H...   Nov 6 2013, 06:54 AM
JStroud   How relay works Have fun Nice link, where did y...   Nov 6 2013, 08:44 AM
914itis   [quote name='914itis' post='1952680' date='Nov 6 ...   Nov 6 2013, 10:32 AM
arcadeforever   from what I can see.... oddly enough it appears 87...   Nov 6 2013, 06:49 AM
arcadeforever   Shows how much of a newb I am, lol, I just saw in ...   Nov 6 2013, 07:21 AM
pcar916   To answer in short... When the circuit is comple...   Nov 6 2013, 07:57 AM
pcar916   Bowlsby has a lot of information on his site. htt...   Nov 6 2013, 09:54 AM
Dave_Darling   I also have a write-up, about halfway down in this...   Nov 6 2013, 10:02 AM
pcar916   Forgot about this! That's a great write-up...   Nov 6 2013, 10:07 AM
jimkelly   freakin ingenious. since our cars are run from a...   Nov 6 2013, 10:50 AM
Spoke   freakin ingenious. since our cars are run from ...   Nov 6 2013, 11:53 AM
pcar916   ... i think image is correct? 30 is always a pe...   Nov 7 2013, 03:19 AM
underdog   ... i think image is correct? 30 is always a p...   Nov 7 2013, 07:52 AM
Dave_Darling   30 is always a permanent ground. No, 30 should be...   Nov 7 2013, 09:43 AM
Mike Bellis   Current is limited by the fuse size and to some ex...   Nov 6 2013, 11:41 AM
Mike Bellis   By the way current is stupid and don't know sh...   Nov 6 2013, 11:47 AM
Tom   Relays use a small current to control a much large...   Nov 6 2013, 01:09 PM
r_towle   Current or load is always dictated by the device c...   Nov 6 2013, 05:32 PM
Mike Bellis   Read this...   Nov 6 2013, 08:00 PM
jimkelly   I believe pin 30 is always connected to either 87 ...   Nov 7 2013, 08:41 AM
Spoke   I believe pin 30 is always connected to either 87...   Nov 7 2013, 09:25 AM
Mike Bellis   Relay nomenclature: 30: Common 87: Nomally Open 87...   Nov 7 2013, 09:56 AM
- Lo-Fi Version Time is now: 2nd April 2026 - 11:30 AM
