| colingreene |
Oct 31 2013, 12:23 PM
Senior Member ![]() ![]() ![]() Group: Members Posts: 755 Joined: 17-October 13 From: Southern California Member No.: 16,526 Region Association: Southern California |
Thought I would introduce myself here, My name is Colin.
This is one of the first and most informitive 914 forums i found. Having grown up with the automotive forum culture i figured i would show you all what i bought. I just picked up a 1976 914 2.0 for 500$ seriously. Problem is as you can see in this picture. (IMG:http://www.914world.com/bbs2/uploads_offsite/i821.photobucket.com-16526-1383243790.1.jpg) It needs a bit of work. the previous owner used this car as a daily driver till the clutch delaminated. he then removed the motor took the trans appart and well, lost interest. his mess is now my problem However it could be worse, its a clean straight car and its got most if not all of its paint on it. While the trans was apart i took it to my local and trusted trans shop but came back with a bill for 1725 to replace all the bearings and synchros. Ouch. (IMG:http://www.914world.com/bbs2/uploads_offsite/i821.photobucket.com-16526-1383243790.2.jpg) then started tearing the motor down to clean the tin and probably powder coat it. this car will bankrupt me. The previous owner said that it ran great and had no leaks. Right. (IMG:http://www.914world.com/bbs2/uploads_offsite/i821.photobucket.com-16526-1383243790.3.jpg) (IMG:http://www.914world.com/bbs2/uploads_offsite/i821.photobucket.com-16526-1383243790.4.jpg) (IMG:http://www.914world.com/bbs2/uploads_offsite/i821.photobucket.com-16526-1383243790.5.jpg) Also came with these wheels (IMG:http://www.914world.com/bbs2/uploads_offsite/i821.photobucket.com-16526-1383243791.6.jpg) My friend bought one also (A 71) for 500$ heres the two of them together (IMG:http://www.914world.com/bbs2/uploads_offsite/i821.photobucket.com-16526-1383243791.7.jpg) Ive read so many threads to inspire me to get off my ass and do something with my car so hopefully i can take the things i have learned here and really apply it. I only have a few questions i cant find the answers to so ill just throw it out there. Should i bother keeping the stock fuel injection if i want to have some sembalance of performance. and will the stock fuel injection take to being modified say, headers maybe a mild cam? How will the car perform stock ish, while the motor is out is there any must do jobs? Ive been looking at re enforcing the trailing arms and potentially the brackets for them. as well as adding the J west shifter stuff. the shocks and such will need to be replaced, any recommendations for a road car that id like to just handle well, I have one car on race suspension (Ast) and i don't know that i want another one. And what material is the fan housing, is it aluminum or magnesium, can i get it anodized to protect it? The car has been sitting for 10 years so the brakes are slightly borked, worth it to keep the stock calipers or do they need an upgrade. other than that the car only has mild rust here and there ( the hell hole is good the battery tray is mediocre) and it appears that i might have wound up with a decent car. Thanks for all the help in advance i look forward to getting this poor car back on the road. |
| rhodyguy |
Nov 11 2013, 08:30 AM
Chimp Sanctuary NW. Check it out. ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 22,252 Joined: 2-March 03 From: Orion's Bell. The BELL! Member No.: 378 Region Association: Galt's Gulch |
read this a few time and still not sure the route you want to take.
you're looking at a 2270? with a 78mm crank you'll encounter the issue(s) dave mentioned and i believe there are case clearance needs as well. plan on decking and prob align boring the case. the rest are iirc, you'll need some sort of aftermarket exhaust/header system. i don't think stock heat exchangers will get the job done. bring money. lots of it. figure out NOW how you plan on feeding the engine. carbs? individual FI throttle bodies and aftermarket fi management(bring another big $ pile)? stockish djet wont get the job done. at a minimum a set of carbs will need to be redone and all components sized correctly for your engine's EXACT needs. that is going to run you $700 + after the dust settles. perhaps additional oil cooling. head requirements. more $$$$. lots more tricks for sure. not for the faint of heart. going BIG is going to require a substantial investment. more like the equivalent of the new suspension you're going to want, brake renew, rust repair and paint, tranny work and all that's required to get the power to the asphalt. things most if not all roller projects have in their future. |
colingreene 1976 914 2.0 Oct 31 2013, 12:23 PM
Brian Mifsud Welcome to the site. Great people here. You will... Oct 31 2013, 12:43 PM
walterolin Welcome, it is a great site.
Get in touch with Dr... Oct 31 2013, 12:55 PM
7TPorsh Welcome...what part of SoCal? Oct 31 2013, 12:59 PM
914itis :wttc:
If you didn't let the mechanic do the... Oct 31 2013, 01:12 PM
pt_700 welcome to the madness!
besides what's al... Oct 31 2013, 01:29 PM
dcheek If you need specific pictures as to what goes wher... Oct 31 2013, 01:42 PM
Cupomeat :wttc:
And from what I've seen you got a stea... Oct 31 2013, 01:51 PM
76-914 Toluene is your friend come smog time. Oct 31 2013, 03:19 PM
Brian Mifsud
Toluene... Oct 31 2013, 04:11 PM
SLITS
How much do you add?
10% by volume .. alcohol w... Oct 31 2013, 04:31 PM
SLITS He should come to the G&R and be insulted! Oct 31 2013, 03:47 PM
colingreene what part of the longs do you want to see?
I can t... Oct 31 2013, 09:21 PM
Brian Mifsud
I should have all the smog stuff to keep it leg... Nov 1 2013, 02:22 PM
euro911 Your transaxle may not need all new parts, and som... Oct 31 2013, 10:25 PM
rhodyguy look on the rear of the wheels. if there is a fox ... Nov 1 2013, 08:22 AM
colingreene Ill get some pictures when i go up to see my car t... Nov 1 2013, 11:37 AM
Cupomeat
Ill get some pictures when i go up to see my car ... Nov 1 2013, 11:59 AM
Dave_Darling They are indeed the real thing. But the real whee... Nov 1 2013, 12:47 PM
arcadeforever Welcome Colin, your car looks to be in amazing con... Nov 1 2013, 05:48 PM
colingreene This is my current problem with my wheels.
I took ... Nov 2 2013, 02:28 AM
carr914 :wttc: Nov 2 2013, 07:59 AM
colingreene Got a chance to work on the car some today, Took q... Nov 2 2013, 08:02 PM
euro911 Hell hole looks pretty good, actually :)
Remove ... Nov 2 2013, 09:28 PM
rick 918-S :wttc: Nov 2 2013, 11:36 PM
Dr Evil I am surprised that no one noticed.....those trans... Nov 2 2013, 11:45 PM
Dr Evil Did your shop note what type of tranz those are?
... Nov 2 2013, 11:53 PM
euro911 Maybe I should have said, $1700 is outrageous... Nov 3 2013, 12:22 AM
Dr Evil
Maybe I should have said, $1700 is outrageou... Nov 3 2013, 08:41 AM
colingreene I know that they have Vw trans in that picture. Th... Nov 3 2013, 12:53 AM
euro911 I know that they have Vw trans in that picture. Th... Nov 3 2013, 04:05 AM
colingreene As I said in my first post the Previous owner had ... Nov 4 2013, 12:38 PM
colingreene Took my motor apart.
Its bad news folks.
I found a... Nov 9 2013, 07:05 PM
euro911 A good machine shop can bore stock 94mm (2.0L) Mah... Nov 9 2013, 08:28 PM
colingreene Lets just say, im not too worried about the emissi... Nov 10 2013, 02:04 AM
euro911 Lets just say, im not too worried about the emissi... Nov 10 2013, 08:16 AM
rhodyguy fwiw, CMUs, also known as concrete blocks aren... Nov 10 2013, 06:54 AM
billh1963
fwiw, CMUs, also known as concrete blocks aren... Nov 10 2013, 07:07 AM
colingreene Third try now.
If the KS stock Cyls are good qual... Nov 10 2013, 04:39 PM
Kirmizi Bumper back-dating instructions right here: :D
h... Nov 10 2013, 08:03 PM
Dave_Darling Going to a 78mm crank is a more complicated thing ... Nov 10 2013, 08:40 PM
colingreene Ah, so much for that.
If its dealing with a reduce... Nov 10 2013, 10:03 PM
euro911 Tuna Can is another good T4 reference site. Here... Nov 10 2013, 10:51 PM
colingreene Thanks for raising those points.
I know I'll ... Nov 11 2013, 10:14 AM
rhodyguy a local guy (dave h) tried the stock plenum, a ope... Nov 11 2013, 10:30 AM
colingreene I emailed Raby, asking if he sold part, he just em... Nov 11 2013, 05:12 PM
Bleyseng The simplest engine upgrade is the 2056 using Djet... Nov 12 2013, 09:44 AM
SirAndy The simplest engine upgrade is the 2056 using Djet... Dec 7 2013, 05:55 PM
colingreene After the swap meet I had that thought. Just stick... Nov 12 2013, 09:56 AM
colingreene PM me about the smog thing.
I took my motor appar... Dec 7 2013, 05:34 PM
brant all of these 2.0 heads (at least many) have cracks... Dec 7 2013, 05:50 PM
euro911 :agree:... Me too
I have a set of '75 2.0L h... Dec 7 2013, 07:10 PM
colingreene The quote to repair the heads was just over 2400
i... Dec 8 2013, 10:30 AM
colingreene Euro, Any word on those heads or should i Pm you? Dec 15 2013, 12:16 PM
euro911 Euro, Any word on those heads or should i Pm you?I... Dec 15 2013, 07:00 PM
Java2570 Call Len Hoffman - http://www.hamincgroup.com/typ... Dec 15 2013, 12:48 PM
colingreene It was a consideration.
I did look at the bill for... Dec 15 2013, 05:38 PM
PancakePorsche I live in So.Cal. and have a 76' I daily drive... Dec 21 2013, 03:02 AM
Bob L. http://www.914world.com/bbs2/index.php?sho...=2037... Dec 21 2013, 04:56 PM
r_towle Who wants to charge you 2400 in machine work on a ... Dec 21 2013, 11:09 PM
colingreene Local shop in california known well for its type 4... Dec 22 2013, 03:38 AM
colingreene What do you guys think of a full carrera front end... Jan 15 2014, 06:00 PM
euro911 That's a good deal Colin Jan 15 2014, 06:12 PM
colingreene Thanks, I guess ill get on that.
I am starting to ... Jan 16 2014, 08:41 PM
Dave_Darling IIRC, the rods to the case is not usually a proble... Jan 17 2014, 10:21 AM
colingreene Understood,
I am waiting on my cam to come from W... Jan 18 2014, 12:01 AM
colingreene http://www.914world.com/bbs2/uploads_offsite/i821.... Feb 28 2014, 09:11 PM
colingreene So since my last update i decided to ditch the sto... Jun 18 2014, 09:31 PM
Bleyseng Straight cut cam gears? Jun 19 2014, 10:09 AM
914_teener :blink: Jun 19 2014, 11:56 AM
colingreene Yes its a straight cut cam gear, I also have dual ... Jun 19 2014, 05:00 PM
zambezi It'll be loud. Straight cut gears whine. Jun 19 2014, 09:36 PM
colingreene Im aware, I am not super worried about it. I proba... Jun 19 2014, 09:42 PM
euro911 Im aware, I am not super worried about it. I proba... Jun 19 2014, 11:53 PM
colingreene Thats seriously bad ass.
Sorry about the skunk pro... Jun 20 2014, 10:59 AM
colingreene http://www.914world.com/bbs2/uploads_offsite/i821.... Jul 26 2014, 11:43 PM
colingreene So some updates, Motor is nearly done and ready to... Sep 2 2014, 05:44 PM
76-914 Nice build but I must warn you that HP is highly a... Sep 2 2014, 07:10 PM
colingreene Its always been a thought but In order to do that ... Sep 2 2014, 10:15 PM
Larmo63 Looking good, Colin. Maybe sell one of your thirty... Sep 2 2014, 10:51 PM
colingreene http://www.914world.com/bbs2/uploads_offsite/i821.... Sep 8 2014, 04:08 PM
euro911 Original MCs were ATE with a 17mm bore. Getting a ... Sep 11 2014, 09:32 AM
colingreene I was told this was a 19? I dont know for sure tho... Sep 11 2014, 09:48 AM
Dave_Darling Look around on it for numbers. There should be a ... Sep 11 2014, 04:20 PM
colingreene Ah neat thanks, ill have a look at it tomorrow. Sep 11 2014, 10:21 PM
colingreene http://www.914world.com/bbs2/uploads_offsite/i821.... Oct 21 2014, 12:12 PM
sb914 Your just about one year in.looking good :popcorn: Oct 22 2014, 06:23 AM
colingreene Oh i know! I bought the car at the end of Octo... Oct 22 2014, 05:34 PM
ClayPerrine FYI.. pop rivets won't hold the battery tray, ... Oct 23 2014, 12:13 PM
colingreene Did your friend use a .250 thou pop rivet? with 72... Oct 23 2014, 12:22 PM
colingreene Took the Sills off the other day, Found the only r... Mar 31 2015, 12:28 AM
colingreene http://www.914world.com/bbs2/uploads_offsite/i821.... Mar 31 2015, 12:30 AM
euro911 Nice progress :headbanger:
http://www.914world.... Mar 31 2015, 03:16 AM
maf914 Pelican Parts had the bronze shift coupler bushing... Mar 31 2015, 06:57 AM
colingreene Oh Bruce/Glen helped me find all new parts for the... Mar 31 2015, 09:27 AM
euro911 :thumbsup: Mar 31 2015, 11:04 AM
colingreene Over the last few years, I have done a few more th... Jul 28 2020, 02:37 PM
Cairo94507 Your car is looking good. That's a lot of wor... Jul 29 2020, 06:34 AM
colingreene After running the car around a bunch and never bei... Jan 28 2021, 05:53 PM![]() ![]() |
Lo-Fi Version | Time is now: 6th June 2026 - 06:22 AM |
