> Check your CV bolts, Mine came off a few minutes ago
ChrisReale
post Jul 12 2004, 10:41 PM
Sleazy
Luckily I was one block from my apartment, but it still sucked having to hold the flashlight with my knees while I put the drive shaft back on. Check your torque to make sure it is correct. I have been meaning to do this for a few days, and it bit me in the ass. Dont let it happen to you (IMG:style_emoticons/default/slap.gif)
yellowFV
post Jul 26 2004, 08:28 PM
I just pulled my cv joints on my 75 914 1.8 liter car today.... The bolts on my cv joints are an 8 mm spline internal wrenching type bolt...
Could the head of the bolt be safely drilled to accept a ss safety wire... I thought I could run safety wire through the first bolt head and then accross to it's pair.
My original question for the evening was gonna be how do you remove the flanged hub that carries the brake rotor from the control arm / wheel bearing area.
I was gently banging on them with a brass hammer and they were not moving so I backed off.
rob
ChrisReale   Check your CV bolts   Jul 12 2004, 10:41 PM
trekkor   What torque on those little bolts? KT   Jul 12 2004, 10:52 PM
jkeyzer   Heh heh heh. http://www.914world.com/bbs2/index....   Jul 12 2004, 11:57 PM
SirAndy   seems like it's CV joint separation summer ......   Jul 13 2004, 12:17 AM
Britain Smith   I actually picked up a 8mm Allen socket to allow m...   Jul 13 2004, 12:40 AM
airsix   <...   Jul 13 2004, 12:42 AM
tdgray   Obviously there has been quite a bit of this latel...   Jul 13 2004, 05:47 AM
synthesisdv   anyone got a picture of the cv bolts safety wired?...   Jul 13 2004, 06:17 AM
ClayPerrine     Jul 13 2004, 06:19 AM
thomasotten   It happened to me once and hit my transmission and...   Jul 13 2004, 06:48 AM
DNHunt   Between being so tight you can't break them lo...   Jul 13 2004, 07:36 AM
davep
  Jul 13 2004, 11:14 AM
Martin Baker   I believe we should go with an "Emergency Action T...   Jul 13 2004, 11:17 AM
Porsche Rescue   Is everybody using the OE "schnorr" lock washers? ...   Jul 13 2004, 03:38 PM
Zeke   It's not easy to assemble the CV and not get g...   Jul 13 2004, 09:17 PM
RAR   I couldn't get the bolts tight enough not to l...   Jul 13 2004, 09:57 PM
Kerrys914   WOW..what a nasty feeling when this happens. My f...   Jul 18 2004, 08:19 PM
nine14cats   my cv's are safety wired. I realize my car is...   Jul 18 2004, 08:31 PM
aircooledboy   <...   Jul 18 2004, 08:39 PM
Ctrout   Safety wiring is easy. The tricks are not to over...   Jul 18 2004, 09:08 PM
!   Ayupers....me seven....happened on Wyld Thang. Di...   Jul 18 2004, 09:45 PM
Ctrout   This   Jul 19 2004, 07:05 PM
Ctrout   And this   Jul 19 2004, 07:07 PM
Porsche Rescue   That gives me a headache. I think I'll stay wi...   Jul 19 2004, 07:18 PM
Mueller
  Jul 19 2004, 07:22 PM
914forme   Saftey wire is king here guys, it is easy to work ...   Jul 24 2004, 06:38 AM
914forme   Forgot two things! 1. I can't spell, this...   Jul 24 2004, 06:43 AM
maf914   Due to the angles involved with the rear axles, ge...   Jul 24 2004, 06:51 AM
synthesisdv     Jul 24 2004, 06:53 AM
Brad Roberts   Mike, I do the exact opposite of dr. No extention...   Jul 24 2004, 11:32 AM
J P Stein   <...   Jul 26 2004, 01:46 PM
yellowFV   I just pulled my cv joints on my 75 914 1.8 liter ...   Jul 26 2004, 08:28 PM
maf914   <...   Jul 27 2004, 06:57 AM
jfort   you guys are scaring the hell out of me. could so...   Jul 27 2004, 09:39 AM
!   One of the big reasons for these loosening up is h...   Jul 27 2004, 09:47 AM
- Lo-Fi Version Time is now: 2nd April 2026 - 02:21 PM
