| nolift914 |
Sep 17 2013, 06:36 PM
Autoxer ![]() ![]() Group: Members Posts: 186 Joined: 24-May 09 From: Rockaway Beach NY Member No.: 10,399 Region Association: None |
Is my Autox 914 too stiff?
I am currently running the PO setup, the 914 was set up for club racing with front and rear coil overs. The front is at 330lbs/in which I believe is the equivalent to 25MM torsion bars and the rear is at 230. The 914 is a 4 weighting approx 1780lbs with bias ply slicks. I plan on switching to Dot-R radials. I have always thought for autox go soft on springs and big on bars. Does the paddock crowd have any suggestions for a setup. The autox sites in NYC tend to be on the rough side. I was thinking either 175 lbs/in in front and 140 lbs/in rear or 200 lbs/in front and 180 lbs/in rear. |
| J P Stein |
Sep 26 2013, 09:53 AM
Irrelevant old fart ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 8,797 Joined: 30-December 02 From: Vancouver, WA Member No.: 45 Region Association: None |
When administrating the "butt test", I weighed 175 lbs. When I plopped my ass on the front fender of my 914 W/21mm T bars, it went down about 1/4" inch.
Had it gone down about 1 inch, that would have made the 173s inch pound pretty close.........can you skull this out? So much for THAT chart. Dial in all the wheel rate vs spring weights you want......still don't work. Sometimes KISS (& common sense)counts. |
| nolift914 |
Sep 27 2013, 08:00 AM
When administrating the "butt test", I weighed 175 lbs. When I plopped my ass on the front fender of my 914 W/21mm T bars, it went down about 1/4" inch. Had it gone down about 1 inch, that would have made the 173s inch pound pretty close.........can you skull this out? So much for THAT chart. Dial in all the wheel rate vs spring weights you want......still don't work. Sometimes KISS (& common sense)counts. Setting all the sand filled butt tests aside, I am retaining the 230lb rear springs and going start with 200lb front springs. In addition I have found a set of Hoosier R35 take offs from the SCCA runoffs. Thanks for all the information and setup advice. |
| ChrisFoley |
Sep 27 2013, 10:31 AM
I am Tangerine Racing ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 8,016 Joined: 29-January 03 From: Bolton, CT Member No.: 209 Region Association: None
| J P Stein |
Sep 27 2013, 12:12 PM
... I am retaining the 230lb rear springs and going start with 200lb front springs. In addition ... I predict that will make the car loose. Could be, but loose is what you want at AX. The adjustable front AR bar is to control "How loose". I predict a lift of the inside rear tire. |
| nolift914 |
Nov 12 2013, 07:32 AM
... I am retaining the 230lb rear springs and going start with 200lb front springs. In addition ... I predict that will make the car loose. Could be, but loose is what you want at AX. The adjustable front AR bar is to control "How loose". I predict a lift of the inside rear tire. I haven't changed the springs need to confirm the actual rates on the car currently, after running the last event of the season with a good set of Hoosier R35's I believe most of my handling issues were as a result of my tires not suspension. The R35's have enough grip to the awaken the suspension. I finished 2nd overall out of 63 cars only .4 sec behind a very fast well setup 911 GT3. I was 1st in PAX (IMG:style_emoticons/default/smilie_pokal.gif) (IMG:http://www.914world.com/bbs2/uploads_offsite/scontent-b-iad.xx.fbcdn.net-10399-1384263372.1.jpg) |
nolift914 Autox Spring rate help Sep 17 2013, 06:36 PM
Randal
I am currently running... Sep 17 2013, 09:23 PM
J P Stein MY 914 weighed 1700 to 1780 lbs depending on balla... Sep 18 2013, 06:00 AM
Woody My current AX setup is similar to what JP used to ... Sep 18 2013, 06:18 AM
J P Stein There are some mine fields with a suspension set ... Sep 18 2013, 07:56 AM
nolift914
[quote name='nolift914' post='1927965' date='Sep ... Sep 18 2013, 03:26 PM
mskala I believe your chart is accurate from my memory of... Sep 18 2013, 04:43 PM
nolift914
I believe your chart is accurate from my memory o... Sep 18 2013, 05:24 PM
Randal Right, no soft compounds with Canti's.
Befor... Sep 19 2013, 10:21 AM
nolift914
Befo... Sep 19 2013, 11:47 AM
Randal
Bef... Sep 19 2013, 09:47 PM
J P Stein There are several spring rate for torsion bar char... Sep 18 2013, 07:53 PM
J P Stein R35 Hoosiers always worked for me. There was most ... Sep 19 2013, 12:27 PM
nolift914
R35 Hoosiers always worked for me. There was most... Sep 19 2013, 12:48 PM
Downunderman With 330 on the front and 230 on the back the thin... Sep 19 2013, 01:29 PM
Racer Chris
With 330 on the front and 230 on the back the thi... Sep 20 2013, 04:56 AM
J P Stein Next time some expert tells you what spring rate y... Sep 20 2013, 08:53 AM
nolift914 I guess my question is what spring rate is equival... Sep 20 2013, 09:03 AM
J P Stein Looking at the supplied chart the answer would 21m... Sep 21 2013, 08:05 AM
nolift914
Looking at the supplied chart the answer would 21... Sep 22 2013, 08:41 AM
mskala
I have been AutoX for 25 years but the last 15 ha... Sep 22 2013, 03:04 PM
Randal
Looking at the supplied chart the answer would 2... Sep 22 2013, 07:16 PM
Randal Speaking of research, have you asked Tom Provasi h... Sep 21 2013, 08:42 AM
Woody :agree: Sep 22 2013, 04:22 PM
J P Stein First let me say there are MAYBE 6-8 truly fast 91... Sep 23 2013, 07:22 AM
nolift914 Lesson learned, do not reply to a post after 14hr ... Sep 25 2013, 07:43 AM
Randal
Lesson learned, do not reply to a post after 14hr... Sep 25 2013, 08:25 PM
J P Stein Coil overs intrude on the space for tires.
Using s... Sep 25 2013, 09:31 AM
Woody Awesome. Did you get a video? Nov 12 2013, 09:27 AM
nolift914
The battery in my ... Nov 12 2013, 03:07 PM
ChrisNPDrider OMG isn't it always about the tires? <_... Nov 13 2013, 10:45 AM
nolift914
OMG isn't it always about the tires? <_... Nov 13 2013, 02:55 PM
sean_v8_914 lots of great recommendations from very experience... Nov 15 2013, 01:19 PM
nolift914
lots of great recommendations from very experienc... Nov 15 2013, 07:16 PM
Woody
lots of great recommendations from very experien... Nov 15 2013, 07:53 PM
Randal
[quote name='nolift914' post='1957411' date='Nov ... Nov 16 2013, 10:55 AM
dlestep Use charts as reference to get yourself in the nei... Nov 16 2013, 01:15 PM
Randal
If you think tires are important, try asking som... Nov 16 2013, 01:29 PM
Woody I don't run with any of you so this is what I ... Nov 16 2013, 02:39 PM
Randal
I don't run with any of you so this is what I... Nov 16 2013, 02:58 PM
Woody
I don't run with any of you so this is what ... Nov 16 2013, 07:16 PM![]() ![]() |
Lo-Fi Version | Time is now: 17th December 2025 - 02:29 AM |
