> Autox Spring rate help, Too Stiff?
nolift914
post Sep 17 2013, 06:36 PM
Autoxer
Is my Autox 914 too stiff?
I am currently running the PO setup, the 914 was set up for club racing with front and rear coil overs. The front is at 330lbs/in which I believe is the equivalent to 25MM torsion bars and the rear is at 230. The 914 is a 4 weighting approx 1780lbs with bias ply slicks. I plan on switching to Dot-R radials. I have always thought for autox go soft on springs and big on bars. Does the paddock crowd have any suggestions for a setup. The autox sites in NYC tend to be on the rough side. I was thinking either 175 lbs/in in front and 140 lbs/in rear or 200 lbs/in front and 180 lbs/in rear.
Chris Pincetich
post Nov 13 2013, 10:45 AM
B-)
OMG isn't it always about the tires? (IMG:style_emoticons/default/dry.gif) (IMG:style_emoticons/default/biggrin.gif) (IMG:style_emoticons/default/beerchug.gif)
Sounds like you had a great day at the AX races!
nolift914   Autox Spring rate help   Sep 17 2013, 06:36 PM
Randal   Is my Autox 914 too stiff? I am currently running...   Sep 17 2013, 09:23 PM
J P Stein   MY 914 weighed 1700 to 1780 lbs depending on balla...   Sep 18 2013, 06:00 AM
Woody   My current AX setup is similar to what JP used to ...   Sep 18 2013, 06:18 AM
J P Stein   There are some mine fields with a suspension set ...   Sep 18 2013, 07:56 AM
nolift914   [quote name='nolift914' post='1927965' date='Sep ...   Sep 18 2013, 03:26 PM
mskala   I believe your chart is accurate from my memory of...   Sep 18 2013, 04:43 PM
nolift914   I believe your chart is accurate from my memory o...   Sep 18 2013, 05:24 PM
Randal   Right, no soft compounds with Canti's. Befor...   Sep 19 2013, 10:21 AM
nolift914   Right, no soft compounds with Canti's. Befo...   Sep 19 2013, 11:47 AM
Randal   Right, no soft compounds with Canti's. Bef...   Sep 19 2013, 09:47 PM
J P Stein   There are several spring rate for torsion bar char...   Sep 18 2013, 07:53 PM
J P Stein   R35 Hoosiers always worked for me. There was most ...   Sep 19 2013, 12:27 PM
nolift914   R35 Hoosiers always worked for me. There was most...   Sep 19 2013, 12:48 PM
Downunderman   With 330 on the front and 230 on the back the thin...   Sep 19 2013, 01:29 PM
Racer Chris   With 330 on the front and 230 on the back the thi...   Sep 20 2013, 04:56 AM
J P Stein   Next time some expert tells you what spring rate y...   Sep 20 2013, 08:53 AM
nolift914   I guess my question is what spring rate is equival...   Sep 20 2013, 09:03 AM
J P Stein   Looking at the supplied chart the answer would 21m...   Sep 21 2013, 08:05 AM
nolift914   Looking at the supplied chart the answer would 21...   Sep 22 2013, 08:41 AM
mskala   I have been AutoX for 25 years but the last 15 ha...   Sep 22 2013, 03:04 PM
Randal   Looking at the supplied chart the answer would 2...   Sep 22 2013, 07:16 PM
Randal   Speaking of research, have you asked Tom Provasi h...   Sep 21 2013, 08:42 AM
Woody   :agree:   Sep 22 2013, 04:22 PM
J P Stein   First let me say there are MAYBE 6-8 truly fast 91...   Sep 23 2013, 07:22 AM
nolift914   Lesson learned, do not reply to a post after 14hr ...   Sep 25 2013, 07:43 AM
Randal   Lesson learned, do not reply to a post after 14hr...   Sep 25 2013, 08:25 PM
J P Stein   Coil overs intrude on the space for tires. Using s...   Sep 25 2013, 09:31 AM
J P Stein   When administrating the "butt test", I w...   Sep 26 2013, 09:53 AM
nolift914   When administrating the "butt test", I ...   Sep 27 2013, 08:00 AM
Racer Chris   ... I am retaining the 230lb rear springs and goi...   Sep 27 2013, 10:31 AM
J P Stein   ... I am retaining the 230lb rear springs and go...   Sep 27 2013, 12:12 PM
nolift914   [quote name='Racer Chris' post='1932693' date='Se...   Nov 12 2013, 07:32 AM
Woody   Awesome. Did you get a video?   Nov 12 2013, 09:27 AM
nolift914   Awesome. Did you get a video? The battery in my ...   Nov 12 2013, 03:07 PM
ChrisNPDrider   OMG isn't it always about the tires? <_...   Nov 13 2013, 10:45 AM
nolift914   OMG isn't it always about the tires? <_...   Nov 13 2013, 02:55 PM
sean_v8_914   lots of great recommendations from very experience...   Nov 15 2013, 01:19 PM
nolift914   lots of great recommendations from very experienc...   Nov 15 2013, 07:16 PM
Woody   lots of great recommendations from very experien...   Nov 15 2013, 07:53 PM
Randal   [quote name='nolift914' post='1957411' date='Nov ...   Nov 16 2013, 10:55 AM
dlestep   Use charts as reference to get yourself in the nei...   Nov 16 2013, 01:15 PM
Randal   If you think tires are important, try asking som...   Nov 16 2013, 01:29 PM
Woody   I don't run with any of you so this is what I ...   Nov 16 2013, 02:39 PM
Randal   I don't run with any of you so this is what I...   Nov 16 2013, 02:58 PM
Woody   I don't run with any of you so this is what ...   Nov 16 2013, 07:16 PM
- Lo-Fi Version Time is now: 17th December 2025 - 02:29 AM
