Throttle sticking - Fixed thanks to the World, Could this be the distributor? |
wndsnd |
Nov 16 2013, 04:19 PM
You wanted a horse, but got a goat. Nobody wants a goat.... Group: Members Posts: 2,861 Joined: 12-February 12 From: North Shore, MA Member No.: 14,124 Region Association: North East States |
I checked the throttle cable and I can see it is not wrapped.
All the linkage seems fine, and I have the idle screws all the way out. I am even running an extra spring on the throttle bar to ensure that I get full return. Nothing seems to be binding. I am running an old original distributor with the injection point set removed, and the vacum advance disabled. Am I wasting time chasing throttle cable functions or is it just the stinking distributor? |
Mike Bellis |
Nov 16 2013, 07:07 PM
Resident Electrician Group: Members Posts: 8,345 Joined: 22-June 09 From: Midlothian TX Member No.: 10,496 Region Association: None |
Dave meant to check for vacuum leaks at the carb mounting gaskets. A vacuum leak under the carbs will raise the idle. It's easy to find with some carb cleaner. With the engine running, spray some cleaner at the base of the carbs and manifolds. if the idle changes, you have a leak.
wndsnd |
Nov 16 2013, 07:09 PM
Dave meant to check for vacuum leaks at the carb mounting gaskets. A vacuum leak under the carbs will raise the idle. It's easy to find with some carb cleaner. With the engine running, spray some cleaner at the base of the carbs and manifolds. if the idle changes, you have a leak. I will try that. Thank you. |
Lo-Fi Version | Time is now: 2nd June 2024 - 05:47 PM |
