Throttle sticking - Fixed thanks to the World, Could this be the distributor? |
wndsnd |
Nov 16 2013, 04:19 PM
You wanted a horse, but got a goat. Nobody wants a goat.... Group: Members Posts: 2,861 Joined: 12-February 12 From: North Shore, MA Member No.: 14,124 Region Association: North East States |
I checked the throttle cable and I can see it is not wrapped.
All the linkage seems fine, and I have the idle screws all the way out. I am even running an extra spring on the throttle bar to ensure that I get full return. Nothing seems to be binding. I am running an old original distributor with the injection point set removed, and the vacum advance disabled. Am I wasting time chasing throttle cable functions or is it just the stinking distributor? |
wndsnd |
Nov 16 2013, 06:43 PM
Like this
Do you need this? (IMG:style_emoticons/default/blink.gif) (IMG:style_emoticons/default/idea.gif) (IMG:style_emoticons/default/huh.gif) |
JamesM |
Nov 16 2013, 10:16 PM
Senior Member Group: Members Posts: 1,915 Joined: 6-April 06 From: Kearns, UT Member No.: 5,834 Region Association: Intermountain Region |
Like this Do you need this? (IMG:style_emoticons/default/blink.gif) (IMG:style_emoticons/default/idea.gif) (IMG:style_emoticons/default/huh.gif) If you pulled the vacuum can and didn't do anything to lock the plate it will be free to move. You need to either lock the advance plate somehow or re-attach the vacuum can to the place and just leave the no vacuum lines hooked up, this will at least hold the plate in place. |
wndsnd |
Nov 16 2013, 10:25 PM
Like this Do you need this? (IMG:style_emoticons/default/blink.gif) (IMG:style_emoticons/default/idea.gif) (IMG:style_emoticons/default/huh.gif) If you pulled the vacuum can and didn't do anything to lock the plate it will be free to move. You need to either lock the advance plate somehow or re-attach the vacuum can to the place and just leave the no vacuum lines hooked up, this will at least hold the plate in place. If plate floats on its own then idle would fluctuate? I was trying for no advanve initially. Sound like a good thing to check. It could be rotating on its own |
Lo-Fi Version | Time is now: 2nd June 2024 - 01:48 PM |
