> Tire wear pattern
wndsrfr
post Nov 18 2013, 08:13 PM
Check out the pattern of the rubber on my RA1's. I did DE's at VIR, Watkins Glen and Summit point since flipping them mid season, so have about 400 miles on track, 15 heat cycles since flipping. These are the fronts....the rears are much more uniform without a buildup of "worms". The buildup is on the inside edges. I'm guessing that it's indicating that I need more camber but I'm maxed out already. Ideas?
BTW, total mileage on track with these tires since new in March is about 1700 with 61 heat cycles & no sign of cording anywhere yet.
Woody
post Nov 18 2013, 09:17 PM
Sandbox Rabblerouser and head toilet scrubber
Kind of hard to tell with all the opr buildup. What alignment settings are you running now? Is the tire rolling over on the outside?
wndsrfr
post Nov 20 2013, 04:17 PM
OK, Just measured the camber.....3/4" on a 16" rim gives 2.7 degrees negative camber. I'm inclined to go with Andy's assessment of too much camber along with my skill level not likely pushing the car hard enough also. I mean, something like 1000 miles and no spins....gotta turn up the heat, eh?
So, I'll back off the camber a bit, swap the backs to the front and see what I get at Roebling next month. Bob Woodman has a track day there ahead of the Florida Crown DE & I should be able to get temperature readings from his crew to figure out the setup. I'm sure he'll take one look and then sell me a new set of tires before it's all over.....
Any input on the camber to shoot for on road courses other than the "max it out" adage?
- Lo-Fi Version Time is now: 1st July 2025 - 03:11 PM
