| '70PVW914 |
Nov 11 2013, 12:07 AM
Newbie ![]() Group: Members Posts: 29 Joined: 1-November 13 From: Boulder, Co Member No.: 16,594 Region Association: Rocky Mountains |
Hey folks. I just rebuilt the weber IDF 44 carbs on my 914-2.0 because I was experiencing hiccups/stutters in acceleration from idle to about 3k rpm. Also, the car would idle very low, and then die if you did not give it a good amount of revs after starting. I figured my idle jets were clogged, and since the carbs had not EVER been rebuilt, I re-gasketed, and rejetted them.
Just finished that today, put in new fuel line to the carbs, changed the fuel filter, and troubleshot a strange problem where my accelerator cable seemed to wrap its way around the clutch cable and bind. :headbanger After all of that.....my car is STILL acting very strange; in some ways things are better, and in some, things are worse! NOW: The car seems to idle just fine at a very nice 900rpm after adjusting the idle and throttle body.----SWEET! The accelerator cable seems to stick slightly, also, the ball joint for my accelerator pedal seems to keep popping off of the pivot point (Is there a trick to this, or is the ball joint just shot?!) Seem to have it on there now, but now guarantees! ---LESS SWEET Still seems to stutter when reving in gear b/w idle and 2.5k rpm...same as before I rejetted and cleaned (IMG:style_emoticons/default/dry.gif) Shudders and looses power at 4k rpm in every gear...this thing had crazy power after 4k before I messed with anything. (IMG:style_emoticons/default/mad.gif) When I replaced the float needles and seats that came with the rebuild kit, I noticed the seats were way smaller on the rebuild. I DID NOT adjust the float level....my first culprit for this less than stellar performance. After reading some posts on here, it sounds like the float should be at between 12.5mm and 13mm from the upper face of the carb. Would this solve these problems? Also, I DID remove the throttle valves for a clean and inspection when rebuilding...I am hoping this is not the root of the problem, as they do not seem as smooth as they once were. Don't think its the resize in jets, as I just changed idles from .45 to .55, and air corrections from 200 to 190 as per recommendation. Where should I start here!!!????? I figure I will measure and adjust the float tomorrow, after I remove the carbs again (damnit). But if that doesn't work...what should I be trying?.....Damn weber book didn't get here in time and I am not the most patient..... |
| stugray |
Nov 22 2013, 03:36 PM
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 3,825 Joined: 17-September 09 From: Longmont, CO Member No.: 10,819 Region Association: None |
Any luck?
Something I forgot to mention. I stumbled across my aluminum solder rods last night. You could build up that area with Aluminum solder and then redrill that hole. If it doesnt work, that just means you couldnt get the solder to stick, so no harm done. It would be nice to try on something other than the real part. |
'70PVW914 Help! Rebuilt Carbs, Now Engine Car Shudders at 4k RPM Nov 11 2013, 12:07 AM
ThePaintedMan 4K indicates something more towards the top-end of... Nov 11 2013, 06:48 AM
wndsnd Not an expert on the carbs yet. Mine are brand ne... Nov 11 2013, 07:04 AM
Razorbobsr
Not an expert on the carbs yet. Mine are brand n... Nov 11 2013, 07:10 AM
rhodyguy confirm the throttle plates are installed with the... Nov 11 2013, 07:52 AM
'70PVW914 So, in order to sync the carbs, I need to get a sy... Nov 11 2013, 07:54 PM
stugray I am local.
Work in Boulder, Live in Longmont.
If ... Nov 11 2013, 09:47 PM
'70PVW914
I am local.
If... Nov 12 2013, 08:36 PM
rhodyguy i misspoke with the degree number i guess. at leas... Nov 12 2013, 07:33 AM
Racer Chris
i misspoke with the degree number i guess...
I b... Nov 12 2013, 08:18 AM
rhodyguy edit. too early. Nov 12 2013, 08:42 AM
'70PVW914 Ok guys....bad news. I woke up this morning psyche... Nov 17 2013, 01:18 PM
'70PVW914 That was a joke about the jb weld.... Nov 17 2013, 01:26 PM
wndsnd I hope you found the piece in the bowl... Nov 17 2013, 04:04 PM
brant I actually have seen and used in weld in different... Nov 17 2013, 04:19 PM
brant You might even be able to safety wire that Nov 17 2013, 04:20 PM
Dr Evil Is that not an integral part of the float? Get a n... Nov 17 2013, 04:43 PM
euro911 It's a broken split tab, Mike - but repairable... Nov 17 2013, 06:36 PM
Dr Evil I am used to mikuni, bing, etc, where that piece i... Nov 17 2013, 06:55 PM
Dr Evil Ya, a new float will have that tab. This is what I... Nov 17 2013, 06:56 PM
ThePaintedMan That's a very common problem with Webers. Thos... Nov 17 2013, 07:00 PM
rhodyguy is this the set you were sent to replace the first... Nov 17 2013, 07:01 PM
euro911 On Webers, the tabs that the float pivot rod slide... Nov 17 2013, 07:13 PM
Dr Evil
On Webers, the tabs that the float pivot rod slid... Nov 17 2013, 07:58 PM
'70PVW914 Thats the spot....theres also this, i posted to th... Nov 17 2013, 07:50 PM
Racer Chris The broken leg is a bit too delicate to weld back ... Nov 18 2013, 05:59 AM
'70PVW914
The broken leg is a bit too delicate to weld back... Nov 19 2013, 07:02 PM
brant be careful where you take that for welding
its a ... Nov 19 2013, 07:11 PM
Racer Chris
its a... Nov 19 2013, 07:44 PM
brant There is a certified aluminum welder in longmont..... Nov 19 2013, 08:06 PM
stugray Dont know if blurry pics help but this is a view o... Nov 19 2013, 08:43 PM
somd914 Not sure if you've been able to get your float... Nov 23 2013, 10:53 AM
'70PVW914 Hey folks,
Got the repair done to the pivot leg a... Nov 23 2013, 10:10 PM
euro911 Very good :thumbsup: Nov 23 2013, 10:33 PM![]() ![]() |
Lo-Fi Version | Time is now: 2nd April 2026 - 09:48 AM |
