Oil Pressure Control Valve, Reinstall spring? |
MichaelB |
Nov 23 2013, 05:17 PM
Newbie Group: Members Posts: 23 Joined: 24-June 12 From: Wisconsin Member No.: 14,598 Region Association: None |
I'm rebuilding a GA case 2.0 L motor that a PO had put hydraulic cam and lifters in. I'm removing the hydraulics and cam and putting in the Raby 9590 cam kit with solid lifters. While prepping the case I pulled out the oil pressure control valve (the second valve on the flywheel end) expecting a spring and piston but found what appears to be a copper plunger with no travel (essentially a plug).
Based on reading recent threads I suspect it is ok to leave it this way, but was wondering if that is any advantage to reverting to the original spring and piston? |
Lo-Fi Version | Time is now: 9th June 2024 - 05:13 AM |
