> Rear brake pressure regulator valve, Brake repair
DamonsCarrera
post Nov 24 2013, 06:26 PM
The brake pedal on my 914-6 is very spongy, even after repeated bleeding with a pressure bleeder. I isolated the problem to the brake-proportioning valve or pressure regulator. I cannot seem to get the brakes properly bled with this valve in the system.
I've read other posts by some here and it seems this valve is a source of some debate . Is there some trick to bleeding the brakes with it? Do I need to bleed the brakes the old-fashioned way, have someone push on the brake pedal?
toolguy
post Nov 24 2013, 06:40 PM
No trick concerning the proportioning valve. . . all that is inside of it is a sliding piston and a big spring. . . the piston moves and cuts off brake fluid to the rear calipers when a preset pressure is exerted. .
When I redid my entire brake system, I couldn't successfully bleed it with a pressure or vacuum single person system even after a dozen tries. . . . finally had a friend come over and and we did it the old way still took going all the way around 4 times to get a rock solid pedal. .
What I finally figured out was when cracking the bleeders loose to bleed, air was seeping back into the calipers from the bleeder threads. .
DamonsCarrera   Rear brake pressure regulator valve   Nov 24 2013, 06:26 PM
toolguy   No trick concerning the proportioning valve. . . a...   Nov 24 2013, 06:40 PM
DamonsCarrera   Thanks for your input toolguy. I guess I will try...   Nov 24 2013, 07:17 PM
nine9three   Everybody needs these: http://speedbleeder.com/   Nov 24 2013, 08:44 PM
toolguy   Air seeping past the bleeder threads on the calipe...   Nov 24 2013, 08:46 PM
914_teener   :agree: +1   Nov 24 2013, 08:47 PM
gothspeed   :agree: +1 +2 .... :agree:   Nov 24 2013, 09:37 PM
Mark Henry   If you don't mind the super-fund clean-up mess...   Nov 24 2013, 08:56 PM
barefoot   If you don't mind the super-fund clean-up mes...   Jan 25 2014, 12:01 PM
ConeDodger   Don't remove the valve. You will eventually co...   Nov 24 2013, 09:05 PM
walterolin   Speed bleeders (above). I did my '70 4 cyl la...   Nov 24 2013, 09:29 PM
r_towle   After you think you are done, drive it and slam th...   Nov 24 2013, 09:47 PM
DamonsCarrera   Thanks for all the advice guys. Mark, besides b...   Nov 25 2013, 05:56 AM
Eric_Shea   There is no aftermarket valve. It is a "pres...   Nov 25 2013, 05:24 PM
DamonsCarrera   I think there are other aftermarket valves availab...   Nov 25 2013, 07:47 PM
Racer Chris   There is nothing about the pressure regulator whic...   Nov 25 2013, 11:32 PM
Racer Chris   There is nothing about the pressure regulator whi...   Dec 22 2013, 10:31 PM
Eric_Shea   There's 100's of bias proportioning valv...   Nov 27 2013, 04:24 PM
DamonsCarrera   Sorry for the late response. Work has been a bear...   Dec 21 2013, 03:51 PM
GeorgeRud   I wonder if an additional bleeder at the highest p...   Dec 21 2013, 05:41 PM
DamonsCarrera   The highest point would probably be the at the top...   Dec 21 2013, 08:51 PM
DamonsCarrera   I've decided for now to replace the factory pr...   Dec 22 2013, 01:13 PM
r_towle   The brake pedal on my 914-6 is very spongy, even ...   Dec 22 2013, 04:24 PM
Eric_Shea   Wrong move. All the Tilton can do is reduce fluid ...   Dec 22 2013, 11:48 PM
SirAndy   Wrong move. All the Tilton can do is reduce fluid ...   Dec 23 2013, 03:15 AM
Racer Chris   Wrong move. All the Tilton can do is reduce fluid...   Dec 23 2013, 08:30 AM
Jeff Hail   [quote name='Eric_Shea' post='1973906' date='Dec ...   Dec 23 2013, 03:29 PM
Eric_Shea   I disagree. ;)   Dec 23 2013, 02:22 PM
Eric_Shea   You boys have fun... I agree on the pressure aspec...   Dec 23 2013, 04:27 PM
DamonsCarrera   Don't know what the argument is about. It see...   Dec 25 2013, 03:25 PM
DamonsCarrera   Well, in case anybody is following this thread ......   Jan 24 2014, 09:39 PM
Bob L.   So next on the agenda, after making a permanent ...   Jan 25 2014, 04:29 PM
914_teener   I would think your next move is..... if you want t...   Jan 24 2014, 10:23 PM
DamonsCarrera   Yes, true. I set the valve according to the chart...   Jan 25 2014, 10:10 AM
stugray   Which model tilton did you get? Did it fit easily ...   Jan 25 2014, 11:20 AM
DamonsCarrera   @barefoot I think Mark was referring to cracki...   Jan 25 2014, 12:23 PM
914_teener   I have re-read your posts and I have a few questio...   Jan 25 2014, 02:54 PM
DamonsCarrera   @ 914 teener The difference between a static valv...   Jan 25 2014, 05:40 PM
914_teener   Ok....so if it is static then the output will be l...   Jan 25 2014, 06:05 PM
DamonsCarrera   @ 914 teener I'm not sure how you mean to use...   Jan 25 2014, 08:03 PM
flypfi   DamonsCarrera - I realize this is an old post, but...   Nov 21 2016, 04:12 PM
- Lo-Fi Version Time is now: 2nd April 2026 - 01:08 PM
