Ground Wire, Battery |
Razorbobsr |
Dec 1 2013, 07:45 AM
Member Group: Members Posts: 282 Joined: 6-June 10 From: Terre Haute Ind Member No.: 11,813 Region Association: Upper MidWest |
I was getting my herd of cars ready for winter yesterday and remembered that my 914 had a very dull glow from the alt light, time to look see. The battery ground had some crud, as did the post, but want came to light under the sun was the 'Green Crud' in the bundle of wires that make up the ground, under the plastic covering. Any chance this is causing the dull glow of my alt light? Does this 'Green Crud' infection, fatal? Serious note: How long a ground wire do I need to buy? Is there a battery clamp that would allow me another hook up for my MSD? Same question for the hot side? Bob
Mike Bellis |
Dec 1 2013, 09:19 AM
Resident Electrician Group: Members Posts: 8,345 Joined: 22-June 09 From: Midlothian TX Member No.: 10,496 Region Association: None |
If you can see the corrosion, it's time for a new cable. The corrosion causes a voltage drop on the system. I can contribute to poor charging and poor starting.
I once saw a guy that changed his Starter, Alternator & battery only to find out he had bad battery cables. All that money wasted before a $10 CABLE WAS REPLACED... |
Lo-Fi Version | Time is now: 6th June 2024 - 04:08 AM |
