> OT: 2003 Boxster S engine replacement
jesiv
post Dec 3 2013, 10:23 PM
Don't flame me for the Boxster post please! I have a 1975 914 just looking for advice. I am thinking there are more experienced Boxster owners here than most sites.
I am having my 2003 Boxster S towed to the dealership tomorrow. I replaced the IMS with the LN bearing last year as an FYI. On the way home from work last night my idle was rough. The highway was normal and spirited! With no problems. However when I started the car after leaving the grocery store. Smoke was apparent thru the rear window. I couldn't tell if it was white or any other color as it was dark. The car ran fine but had a rough idle in the driveway prior to shutoff. I didn't feel good about how things were going! The next morning when I started the car no smoke but rough idle! I didnt see any reason to push the situation so I stopped the engine. I have no check engine light!!
I don't think the engine is blown but it has me thinking... I could hear from the dealer I need a new engine!
So what I would like is your suggestions on is... other than a 25k porsche crate motor... What would you do? The car is perfect otherwise!
I should add this is a daily driver. No track. Like I said it is perfect otherwise
Thanks for the help!!
Regards
James
DRPHIL914
post Dec 3 2013, 10:48 PM
Dr. Phil
Could be something simple like the Oil/air separator. I had the same issue nor long after I bought my car. Had to pull the MAP sensor and clean it too, replaced the o/a and put in new O2 sensors and no issues since. O/A will fail and be the cause of the white smoke at start up.
Before you spent $500-$1000 at the dealer think about what you can do yourself.
Look on pelican site for the tech articles that will show you how to do this. And post on the 986forum.com there are quite a few there that call assist on this as well. Others may chime in here too .
Welcome and post an few pics of the 914 and boxster too
Good luck.
jesiv   OT: 2003 Boxster S engine replacement   Dec 3 2013, 10:23 PM
McMark   Used motor or new car. :( Boxsters have dropped ...   Dec 3 2013, 10:27 PM
ConeDodger   I seem to recall something called an air/oil separ...   Dec 3 2013, 10:30 PM
Philip W.   :wttc: Could be something simple like the Oil/ai...   Dec 3 2013, 10:48 PM
rick 918-S   Ya, I recall something about that air, oil thing t...   Dec 3 2013, 10:55 PM
ThePaintedMan   Don't have a whole lot of experience with Boxs...   Dec 3 2013, 11:06 PM
Mike Bellis   I was thinking donor car! :Qarl: :Qarl: :Qar...   Dec 3 2013, 11:36 PM
Cap'n Krusty   Any decent P-car shop can fix this, IMO. Likely t...   Dec 3 2013, 11:39 PM
speed metal army   http://www.youtube.com/watch?v=P67OSN2DqAE The fix...   Dec 4 2013, 12:28 AM
Woody   Yeah its the oil seperator. Its basically the PCV ...   Dec 4 2013, 06:30 AM
Philip W.   Yeah its the oil seperator. Its basically the PCV...   Dec 4 2013, 06:54 AM
Philip W.   FYI**** the lab i mentioned in the previous post f...   Dec 4 2013, 07:34 AM
jesiv   Well the verdict is in looks like at a minimum a b...   Dec 4 2013, 06:21 PM
timothy_nd28   Well the verdict is in looks like at a minimum a ...   Dec 6 2013, 09:40 AM
rick 918-S   Get a second opinion. I haven't heard of a hea...   Dec 4 2013, 06:29 PM
ThePaintedMan   Get a second opinion. I haven't heard of a he...   Dec 4 2013, 07:18 PM
timothy_nd28   You could do a 2nd opinion yourself. Obtain a com...   Dec 4 2013, 06:36 PM
jesiv   I hear what you are saying regarding the head gask...   Dec 4 2013, 07:59 PM
jimkelly   there is an LS1 motor in the classifieds right now...   Dec 4 2013, 08:15 PM
Jake Raby   The M96 engines DO NOT blow head gaskets. Period...   Dec 4 2013, 08:25 PM
Woody   You need someone with a clue about M96 engines t...   Dec 4 2013, 09:13 PM
Jake Raby   Now.. Wonder how I guess about your failed water p...   Dec 4 2013, 09:57 PM
timothy_nd28   Even stand up guys can fall behind on rent   Dec 4 2013, 08:31 PM
396   Even stand up guys can fall behind on rent OT,...   Dec 6 2013, 11:19 AM
jesiv   Jake Thank you for your response! A wealth of...   Dec 4 2013, 09:11 PM
Woody   Ive done over 100 water pumps on m96 and 97 engine...   Dec 4 2013, 10:14 PM
Jake Raby   Ive done over 100 water pumps on m96 and 97 engin...   Dec 4 2013, 10:27 PM
Woody   Have had plenty with broken or missing blades and ...   Dec 4 2013, 10:35 PM
Jake Raby   Have had plenty with broken or missing blades and...   Dec 4 2013, 10:50 PM
rick 918-S   Very interesting Jake. Thanks for sharing that inf...   Dec 4 2013, 11:29 PM
Jeff Bowlsby   Suby time?   Dec 5 2013, 12:16 AM
Jake Raby   Where the debris ends up there's no way to rem...   Dec 5 2013, 05:39 AM
Philip W.   Jake, this brings up the question of when should w...   Dec 5 2013, 05:44 AM
jimkelly   woody, pls tell us more about these engines. my im...   Dec 5 2013, 06:05 AM
Woody   woody, pls tell us more about these engines. my i...   Dec 5 2013, 06:14 AM
ThePaintedMan   Seems I wasn't as far off base as it might hav...   Dec 5 2013, 08:20 AM
Woody   Again, doubtful that Porsche will do that since t...   Dec 5 2013, 09:06 AM
ThePaintedMan   This is another bit of miss-information. Porsche...   Dec 5 2013, 09:36 AM
Woody   This is another bit of miss-information. Porsch...   Dec 5 2013, 12:33 PM
Jake Raby   Do you have the VINs for those cars. If so I...   Dec 5 2013, 08:25 AM
Woody   Do you have the VINs for those cars. If so I...   Dec 5 2013, 09:07 AM
Jake Raby   Thats why I am writing the book on it. Full docu...   Dec 5 2013, 11:02 AM
Philip W.   Jake, this brings up the question of when should ...   Dec 5 2013, 11:04 AM
Jake Raby   If you query the owners of the cars we have had to...   Dec 5 2013, 11:35 AM
jesiv   Jake I live in the San Francisco Bay Area. Who wo...   Dec 5 2013, 12:48 PM
Jake Raby   Jake I live in the San Francisco Bay Area. Who w...   Dec 5 2013, 03:41 PM
ThePaintedMan   Two different dealers and two other shops told h...   Dec 5 2013, 03:55 PM
Woody   Two different dealers and two other shops told ...   Dec 5 2013, 04:20 PM
ThePaintedMan   As far as other dealers practices I really can...   Dec 5 2013, 04:28 PM
Woody   As far as other dealers practices I really can...   Dec 5 2013, 04:48 PM
bam914   Every car that comes in the shop with inter mix he...   Dec 5 2013, 12:51 PM
jesiv   God I wish someone would have explained what would...   Dec 5 2013, 12:58 PM
timothy_nd28   Hey, how do you repair these cracks? Do you v-not...   Dec 5 2013, 03:48 PM
Jake Raby   Hey, how do you repair these cracks? Do you v-no...   Dec 5 2013, 03:51 PM
HAM Inc   Pretty lively discussion about intermix for a airc...   Dec 5 2013, 05:39 PM
r_towle   Well, you gotta figure that when the fan blows up,...   Dec 5 2013, 05:56 PM
Jake Raby   Hell, just don't worry about it... its only c...   Dec 5 2013, 06:13 PM
HAM Inc   [b]Hell, just don't worry about it... its on...   Dec 5 2013, 07:06 PM
stugray   Part of the reason is that dissimilar metals in ...   Dec 5 2013, 06:26 PM
HAM Inc   In relation to the O.P.'s concern that he...   Dec 5 2013, 07:04 PM
r_towle   Honestly, we replaced water pumps every 60k on Ame...   Dec 5 2013, 07:16 PM
ThePaintedMan   Nothing has magically changed about a water pump,...   Dec 5 2013, 07:28 PM
Woody   I have been doing this for awhile now. I am in sou...   Dec 5 2013, 07:21 PM
HAM Inc   I do sympathize with the mechanic's position o...   Dec 5 2013, 07:34 PM
jesiv   Obviously inspecting the water pump on a Boxster i...   Dec 5 2013, 09:49 PM
Dr Evil   Wonderfully informative :thumbsup: :popcorn:   Dec 5 2013, 11:51 PM
ThePaintedMan   :agree: This is one topic about the M96 that doesn...   Dec 6 2013, 07:53 AM
mepstein   Jake, Woody - I wonder if it's possible each o...   Dec 6 2013, 07:57 AM
Woody   Jake, Woody - I wonder if it's possible each ...   Dec 6 2013, 08:04 AM
walterolin   Excellent thread, I think a number of us are activ...   Dec 6 2013, 08:54 AM
jesiv   I received more info on options/pricing Independen...   Dec 6 2013, 10:01 AM
Woody   I received more info on options/pricing Independe...   Dec 6 2013, 10:10 AM
jesiv   I purchased the car from the dealership with the P...   Dec 6 2013, 10:23 AM
ThePaintedMan   I purchased the car from the dealership with the ...   Dec 6 2013, 10:35 AM
HAM Inc   I purchased the car from the dealership with the...   Dec 6 2013, 01:27 PM
Woody   I purchased the car from the dealership with the ...   Dec 6 2013, 11:45 AM
rfuerst911sc   Here's a scary thought. Lets say you purchase ...   Dec 6 2013, 10:37 AM
jesiv   Who is Len at HAM? If I am paying the full ride I ...   Dec 6 2013, 10:46 AM
Randal   Who is Len at HAM? If I am paying the full ride I...   Dec 6 2013, 11:03 AM
pt_700   many thanks to jake and woody for their contributi...   Dec 6 2013, 11:23 AM
DBCooper   I've never heard of this either, and suspect i...   Dec 6 2013, 12:03 PM
gandalf_025   I would start by asking the dealership for contact...   Dec 6 2013, 12:25 PM
TCallas   I have been watching this thread, early on with fr...   Dec 6 2013, 01:50 PM
ThePaintedMan   James, did you get that? Len Hoffman is HAM Inc, w...   Dec 6 2013, 02:21 PM
jesiv   So what are your thoughts of only doing a top end ...   Dec 6 2013, 02:22 PM
jesiv   George I sent HAM an email. I am looking forward t...   Dec 6 2013, 02:27 PM
euro911   ... Wow, now Tony Callas weighed in here too? This...   Dec 6 2013, 02:42 PM
Jake Raby   Tony and I work together and talk about things all...   Dec 6 2013, 04:16 PM
HAM Inc   If you guys had any idea how many M96/97 engines J...   Dec 6 2013, 04:50 PM
HAM Inc   I sometimes lay awake at night wondering what I d...   Dec 6 2013, 04:56 PM
Jake Raby   We were doing it well before anyone even knew it...   Dec 6 2013, 07:27 PM
ChrisNPDrider   Nice smile Jake! :beer2: For some reason I a...   Dec 6 2013, 08:09 PM
Jake Raby   Nice smile Jake! :beer2: For some reason I ...   Dec 6 2013, 08:21 PM
jesiv   I sure wish I still lived in Alabama much closer t...   Dec 6 2013, 08:51 PM
Jake Raby   I have more M96 powered cars here from California ...   Dec 6 2013, 09:52 PM
HAM Inc   Damn! I need to get one of those lenses! ...   Dec 7 2013, 09:34 AM
HAM Inc   Off topic, but thought it worth while since this i...   Dec 7 2013, 10:02 AM
Jake Raby   Off topic, but thought it worth while since this ...   Dec 7 2013, 10:15 AM
malcolm2   No similarity to the "bug me" video and ...   Dec 7 2013, 10:44 AM
Jake Raby   No similarity to the "bug me" video and...   Dec 7 2013, 12:08 PM
3 Pages V  1 2 3 >
- Lo-Fi Version Time is now: 25th November 2026 - 09:16 PM
