My Bumblebee Electric, upgrading from DC to AC |
palmer_md |
Dec 5 2013, 03:17 PM
Member Group: Members Posts: 106 Joined: 15-November 10 From: Hermosa Beach, CA Member No.: 12,389 Region Association: Northern California |
Hello all,
I'm a long time lurker here, and I've posted a few times, but I'm starting this thread to discuss the upgrade I'm doing to my 74 bumblebee LE. I converted the car to electric drive starting in 1995. I purchased the car in 1994 with the intention of putting in a chevy v8 or something, but after looking at what that would take I opted to put in an electric drive train. The car was sitting in a field with weeds all around and no interior, engine, transmission or anything. It took a few years to just get the car restored before I could put in the electric drive. I got the car on the road as an electric in 1997. It has been a fantastic car for commuting and it is a lot of fun to drive, but with all the lead in the car it was a bit heavy. I decided last year that I was going to upgrade the car to lithium power which will remove about 700lbs of battery and give me more power and more range at the same time. I purchased a gearbox (BorgWarner 31-03) that is the same as a Tesla Roadster, and I got a Siemens induction motor and inverter that will give me almost as much power as the Roadster. I should end up with a little less weight than the Roadster which should allow me to have similar performance numbers...assuming I can get enough grip from the tires. In order to fit this motor and gearbox under the hood, I'm going to have to remove the firewall between the trunk and the motor bay. The gearbox sits between the axles (obviously) and the motor will sit above it (hence the space time conflict with the firewall). This is not a problem since I've seen posts with this firewall and trunk floor removed and then triangulating by putting a bar between the strut towers and then two more from the towers down to the rear trans cross bar in the trunk. This part of the build is all pretty clear in my mind. The connection between the strut towers works perfect as an upper mounting point for the motor and gearbox. Existing motor and trans mounting locations work for the lower support. The area where I have a question is with regard to the gearbox location. In order to put the gearbox and electric motor in the car, it installs like a transverse motor in a FWD vehicle. The gearbox is mounted slightly to the driver side of the vehicle and the motor is to the passenger side. So instead of the existing 901 getting installed exactly in the center between the two wheels, I'll have to mount the eGearDrive about 5" toward the driver side of the car comparatively, and then I'll have to put in an intermediate half shaft on the passenger side to allow for the articulating portion of the axles to both be equal length (about 5" shorter than stock). Anyhow, this is my question, and one that I thought I'd ask for help here first before heading to a drive shaft shop to get opinions. Will the suspension work well with 5" shorter drive axles. It means probably steeper angles as the suspension articulates, but I think it should work. I just don't have any experience in this area and I'm going to have to get some help with this decision before I start cutting the trunk apart to install all of it. If it does not look like it is going to work I'll have to come up with a plan "B". I'll post some pictures in a later post, but I wanted to get the question about the drive shafts out there since I need that answered. Thanks, Michael |
Chris Pincetich |
Dec 6 2013, 08:26 PM
B-) Group: Members Posts: 2,082 Joined: 3-October 05 From: Point Reyes Station, CA Member No.: 4,907 Region Association: Northern California |
Does anyone have any specifications for rear suspension wheel travel on the 914? A quick google did not turn up anything, but I'll keep looking. OR, use the rear shock insert range of motion length and adjust per the difference in suspension mounting point of rear axle vs shock mount. Your suspension shouldn't travel outside the range the shock insert will let it. Some race 914s use a nylon webbing strap to limit the overall suspension drop: these cars are tightly sprung and low and do it so springs don't shift in their seats when frequent lifting to change wheels occurs. So, that's not a fix for driving, but food for thought. GOTS TO ASK - how much $$$ for the new set-up??? (IMG:style_emoticons/default/dry.gif) I too originally bought my 914 for an EV, but am having too much fun trying to expire my 1.7 TIV while saving $$$. The kits I've seen for the conversion are $8k-12k total, w $1k-3k for motors and $2k-3k for lead acid batteries. It's been a few years since I looked up prices...BUT I recently saw a guy selling "rebuilt" Prius batteries!! Good luck! I'll be watching for updates (IMG:style_emoticons/default/beerchug.gif) |
palmer_md |
Dec 7 2013, 12:21 AM
I had about $10k into the original conversion parts back in the 90's. That did not include all the expenses that went into the restoration of the car before I put in the electric drivetrain. I had to purchase a 901 tranny and a complete interior for the car as well as countless small parts that were missing, paint, body, suspension, drivelines, etc. I really have no idea how much I spent on this car, but I did not choose to work on this car because it was going to be a big money maker for me, I chose to work on it because it is such a fun project car and a blast to drive. Once I got it going on the road I was hooked. It started to get a little boring so that is why I decided to spice the car back up again. I'm probably going to spend much more on this upgrade than I did on the original conversion. Already spent $9k on lithium batteries and $5k on the motor, gearbox and inverter. Probably gonna be another $1k on just getting the drive-lines connected. But the fun part of the project is all the "free" labor that goes into it. The car will never pay for itself...actually I get payed back handsomely the day I get it back on the road and feel the pride of accomplishment. It felt great the first time and I'm betting it will feel good this second time as well. With regard to the limiting. I installed the AutoAtlanta economy suspension kit 20 years ago and I don't remember any limiting components. I'm sure there must be something, but I've not taken a close look. When I head out to the garage tomorrow to work on the car I'll take a look. |
Lo-Fi Version | Time is now: 10th June 2024 - 09:40 AM |
