> New chasis - Broad overview to Swap Everything from Parts Car
ky914
post Sep 1 2013, 07:20 AM
New member but long time lurker. I have been given a 1973 914 with a 1.7 engine. Unfortunately, it is too far gone due to rust. I know the engine and trans were good when it was last driven over 5 years ago. It has been converted to dual Weber 40's. It hasn't been driven more than 50 miles in the last 20+ years.
For the last 3 years I have been looking for a chassis that is local, cheap, and rust free. I knew this was impossible. However, it looks like I just found what I was looking for. I am buying an abandoned project and getting the 74 chassis. The floor pans have already been replaced. Hell hole looks ok from the pics. Long's are said to be solid with some pitting. My fingers are crossed it is as good as it looks. Regardless, the price was right. I will be picking it up next Sunday and will post pics when they are available.
I know a ground up restoration is huge, expensive and potentially cause for divorce. Can some of the experienced people on here give me a broad overview of the reasonable steps to transfer everything from my parts car to the new chassis?
I assume I need to get the all of the body panels prepped and ready so I can paint before putting on all of the other parts. After it is painted and glass is reinstalled, I assume I will need to deal with getting the suspension and brakes in shape. After that, engine and transmission, etc...
Let me know what you think the proper broad steps are that need to be done. I am assuming the car doesn't need additional work to repair rust damage. What are the big items I have to buy? Do you think I need a complete rubber kit?
What things are necessary to buy?
What things should be bought and why?
Thanks,
Michael
post Dec 8 2013, 04:19 PM
914-6 GT in waiting
You also need to check out the passenger side rear suspension console. A known weak spot on these cars. They rust from the inside out so go hot and heavy with a big metal pick or screwdriver and flush out any weak spot. Failure of this piece will cause the rear wheel to lean in and fall off. Also check out the pedal reinforcement under the pedal cluster.
ky914   New chasis - Broad overview to Swap Everything from Parts Car   Sep 1 2013, 07:20 AM
bulitt   Early 73 or Late? Harnesses in both cars? Sway bar...   Sep 1 2013, 07:58 AM
jimkelly   you are bound to end up with some messed up hard b...   Sep 1 2013, 08:14 AM
Spoke   Nothing to add except :wttc:   Sep 1 2013, 08:40 AM
Jeffs9146   Lennies914 and I did this on his car swapping from...   Sep 1 2013, 08:51 AM
ky914   Here is what I am picking up: http://www.914world...   Sep 1 2013, 11:09 AM
SirAndy   Here is what I am picking up: That car had some m...   Sep 1 2013, 01:59 PM
ky914   That was my major concern. Seller stated that t...   Sep 1 2013, 02:44 PM
SirAndy   Seller stated that the Long's haven't been...   Sep 1 2013, 03:35 PM
rick 918-S   Seller stated that the Long's haven't bee...   Sep 2 2013, 04:37 PM
ky914   I picked up the car this weekend. After some meas...   Sep 9 2013, 06:11 AM
Java2570   For $250 you got a great deal! Keep post...   Sep 9 2013, 06:48 AM
ky914   We will see if it was a good buy or not over time....   Sep 9 2013, 06:51 PM
ky914   I would like some comments on the condition of my ...   Sep 12 2013, 11:07 AM
jimkelly   aside from the home made rear trunk pan - the hell...   Sep 12 2013, 11:27 AM
marksteinhilber   aside from the home made rear trunk pan - the hel...   Jan 17 2018, 02:32 PM
Vacca Rabite   Just go buy a mig welder and an angle grinder tomo...   Sep 12 2013, 12:56 PM
ky914   If I start cutting out everything that looks a lit...   Sep 12 2013, 01:17 PM
boogie_man   :agree: Do not like that rear floor pan at all bu...   Sep 12 2013, 01:24 PM
ChrisNPDrider   welcome to the madness :beer2: :wttc:   Sep 12 2013, 01:37 PM
ky914   I found some time over Thanksgiving to visit my do...   Dec 8 2013, 04:03 PM
mepstein   You also need to check out the passenger side rear...   Dec 8 2013, 04:19 PM
PanelBilly   I'd mount the doors and see if the body lines ...   Dec 8 2013, 04:25 PM
FourBlades   I'd mount the doors and see if the body lines...   Dec 8 2013, 08:34 PM
scotty b   You've got a lot of metal work ahead of you in...   Dec 8 2013, 04:53 PM
Spoke   I don't have a good feeling about the donor ca...   Dec 8 2013, 07:02 PM
walterolin   Don't know if this is still for sale: http://...   Dec 8 2013, 10:11 PM
ky914   Ok. I have heard enough concerns at this point. ...   Dec 9 2013, 08:12 AM
ky914   I can't listen to any of the experts. I am de...   Jan 11 2018, 09:31 AM
ky914   As a way to document my process, I started removin...   Jan 15 2018, 08:09 PM
ky914   Day 2 and The following was done. 1. Headlight mo...   Jan 17 2018, 06:58 AM
Jamie   Day 2 and The following was done. 1. Headlight m...   Jan 17 2018, 08:38 PM
Vacca Rabite   Did you ever do any of the metal remediation on th...   Jan 17 2018, 09:20 AM
bbrock   Did you ever do any of the metal remediation on t...   Jan 17 2018, 10:33 AM
ky914   Day 3 was spent primarily removing the dash and wi...   Jan 20 2018, 09:22 AM
mepstein   This   Jan 20 2018, 09:37 AM
ky914   I like that idea. Wish I had more wall space.   Jan 20 2018, 09:41 AM
mepstein   "If I start cutting out everything that looks...   Jan 20 2018, 09:42 AM
ky914   "If I start cutting out everything that look...   Jan 20 2018, 10:19 AM
ky914   By the way, an appliance dolly is the perfect tool...   Jan 20 2018, 09:45 AM
ky914   Here is the engine and trans on a furniture dolly....   Jan 20 2018, 10:44 AM
ky914   Some more pictures just for fun. http://www.914wo...   Jan 20 2018, 10:54 AM
- Lo-Fi Version Time is now: 15th September 2026 - 11:23 PM
