more heat duct questions |
rosenfe |
Dec 8 2013, 01:04 PM
Senior Member Group: Members Posts: 556 Joined: 14-October 13 From: northern california Member No.: 16,512 Region Association: None |
on my 73 2liter .so i understand that on the 73 passenger side heat ducts are closed off and only drivers side is used.is this correct.?i have a splitter for blower and have gotten l+r s curve pieces, j tube and flapper boxes-used, from a forum member,but passenger side s duct is larger-is that correct,or are they supposed to be the same size?hard to see it all line up without lift .
rmdinmd |
Dec 8 2013, 02:42 PM
Member Group: Members Posts: 488 Joined: 30-October 13 From: Greeneville,Tn Member No.: 16,585 Region Association: South East States |
I am sorry if I was less then clear. what I was saying is you could connect the blower to both sides where the down pipes come up through the tins. the blower I got to put in my 74 splits to hook up to both sides.
rosenfe |
Dec 8 2013, 02:53 PM
I am sorry if I was less then clear. what I was saying is you could connect the blower to both sides where the down pipes come up through the tins. the blower I got to put in my 74 splits to hook up to both sides. i understand about hooking blower up to both sides,i have a splitter for the blower.need to know orientaion of arms that control flapper opening and closing.they can go in with arms on top towards underside of car or towards the ground,which way is correct? |
saigon71 |
Dec 8 2013, 07:19 PM
Advanced Member Group: Members Posts: 2,000 Joined: 1-June 09 From: Dillsburg, PA Member No.: 10,428 Region Association: MidAtlantic Region |
I am sorry if I was less then clear. what I was saying is you could connect the blower to both sides where the down pipes come up through the tins. the blower I got to put in my 74 splits to hook up to both sides. i understand about hooking blower up to both sides,i have a splitter for the blower.need to know orientaion of arms that control flapper opening and closing.they can go in with arms on top towards underside of car or towards the ground,which way is correct? I am pretty sure I installed my flapper valves with the arms down. Climb under there with one of the flapper boxes and it should make sense when you see how the cable ends are routed. |
Lo-Fi Version | Time is now: 29th May 2024 - 05:43 AM |
