request a lesson on engine timing |
type47 |
Dec 8 2013, 08:09 AM
Viermeister Group: Members Posts: 4,254 Joined: 7-August 03 From: Vienna, VA Member No.: 994 Region Association: MidAtlantic Region |
I'd like to know on what parameters does the timing of an engine depend: induction? cam? I am resurrecting a 2L with a carb cam and installing a CIS basic system. We started the engine at the ECC in Oct and am progressing very slowly. I think the engine has an 009 dizzy (engine is still at ECC site so can't check now); at least it has a non-vacuum advance dizzy. I have a 2L D-Jet dizzy ready to install and that will probably be one of the next steps. When we started the engine, it did not sound smooth running but it started and that was the intent at the time,
http://www.youtube.com/watch?v=gRLyDnp7G_0#t=15 but there could be other things that caused that. My question is really to what specs do I time the engine; 27 degrees @ 3500 rpm like a D-Jet? |
gothspeed |
Dec 8 2013, 09:21 PM
Senior Member Group: Members Posts: 1,539 Joined: 3-February 09 From: SoCal Member No.: 10,019 Region Association: None |
recheck the valve adjustment to make sure they are not too tight (.006" Intake and .008" exhaust, I would err on the loose side, until other things are worked out.). Then vacuum leaks. Your timing at 27° BTDC is close enough that it should not cause as much roughness as in the video. Does the CIS have the 'warm up' enrichment functional?
BTW that CIS installation looks freakin great! (IMG:style_emoticons/default/smile.gif) |
Lo-Fi Version | Time is now: 4th June 2024 - 03:49 AM |
