idle on a 2056 with 9590 cam |
jmargush |
Dec 12 2013, 03:50 PM
Member Group: Members Posts: 460 Joined: 8-June 04 From: Goshen, IN Member No.: 2,176 |
I am having trouble getting my new 2056 with a 9590 cam to idle. When I start it is idles around 500rpm or lower and I can't speed it up with the by pass screw.
I am running L-jet injection I hear a hissing sound when the engine is idling but I cannot find a vacuum leak, plenum couplers are new and all other hoses are in good shape. I can't find the hissing with a mechanics stethoscope so I was going to try to find a leak with propane but it has been too cold to work on it lately. The idle does seem to get a little better after it has warmed up a bit I think, it has been several weeks since I have had it out. One question I had is does the new cam require any change to the mixture? if so how do I go about adjusting the mixture? Thanks in advance for any input |
jmargush |
Dec 12 2013, 06:13 PM
Yes
One question though, when I set the timing I set it to 900 rpm after the vacuum advance lines are removed and plugged correct or set it while they are connected and then remove? with thee lines plugged should the idle change as the distributor is rotated? If so rotate it till it is 7.5 degrees BTDC and then lower the idle with the idle adjustment screw? |
Lo-Fi Version | Time is now: 1st June 2024 - 07:52 PM |
