> Weld porosity HELP...
ONTHEGRIND
post Dec 16 2013, 09:15 PM
So I have a Lincoln hd 3200 mig that hasn't been used in a year or so.. I went and got a bottle filled last week argon co2 mix using solid .025 wire with the correct brand new tip welded on brand new steel tried the l/min from very low to very high always welds the same. I can here gas exiting the gun ground is clean here is a photo of what im working with.. The welds are very black be a wire brush on a die grinder makes a pass over them..
The top weld is c 5 settting what it recommends bottom is b5
(IMG:http://www.914world.com/bbs2/uploads_offsite/img.photobucket.com-9738-1387250279.1.jpg)
Dr Evil
post Dec 16 2013, 11:14 PM
Send me your transmission!
Great pointers here for us amateurs (IMG:style_emoticons/default/popcorn[1].gif)
ONTHEGRIND   Weld porosity HELP...   Dec 16 2013, 09:15 PM
gothspeed   Looks terrible :( ..... Can you hear / feel the sh...   Dec 16 2013, 09:18 PM
ONTHEGRIND   I can here gas.. Think it was a bad tank the gu...   Dec 16 2013, 09:22 PM
rick 918-S   Check the regulator and the hose. What do you have...   Dec 16 2013, 09:23 PM
McMark   :agree: with gas flow. What about polarity? Doub...   Dec 16 2013, 09:23 PM
ONTHEGRIND   Blows out a lighter   Dec 16 2013, 09:26 PM
ONTHEGRIND   Yup checked polarity and even replaced the spo...   Dec 16 2013, 09:27 PM
injunmort   the row on the bottom definitely looks like flux c...   Dec 16 2013, 09:27 PM
stugray   Could be too much flow. Are you using a FLOW mete...   Dec 16 2013, 09:28 PM
ONTHEGRIND   Just a pressure meter.. I tried high and low...   Dec 16 2013, 09:32 PM
gothspeed   Sounds like it may be contaminated gas ...... mayb...   Dec 16 2013, 09:36 PM
914_teener   You are using a high pressure regulator instead of...   Dec 16 2013, 09:42 PM
ONTHEGRIND   Its the reg that came with the unit.. It reads ...   Dec 16 2013, 09:51 PM
gothspeed   I think 75% Argon/ 25% Co2 ...... is what I have u...   Dec 16 2013, 10:00 PM
914_teener   My bad sorry..... tri mix is for stainless... Ar...   Dec 16 2013, 10:06 PM
914_teener   That puddle is cold too.....   Dec 16 2013, 10:07 PM
rick 918-S   Is your wire rusty? How old is the wire spool? It ...   Dec 16 2013, 10:09 PM
toolguy   Bad ground connection. . . rusty wire. . not hot ...   Dec 16 2013, 10:27 PM
ONTHEGRIND   Wire is new just unpackaged today tried differen...   Dec 16 2013, 10:42 PM
McMark   Perhaps clean the main connections in the box.   Dec 16 2013, 10:49 PM
ONTHEGRIND   I will also checked that.. Looked good when I chec...   Dec 16 2013, 10:59 PM
Dr Evil   Great pointers here for us amateurs :popcorn:   Dec 16 2013, 11:14 PM
Jeff Hail   Oh boy! So much for aiming for a stack of dime...   Dec 17 2013, 01:24 AM
bulitt   correct liner for .025? Using an extension cord? ...   Dec 17 2013, 01:57 AM
MMW   Start at beginning. Did the welder work fine when...   Dec 17 2013, 08:39 AM
ONTHEGRIND   The only thing the changes was the bottle since it...   Dec 17 2013, 09:02 AM
falcor75   Whats your power supply? I'm not familliar wit...   Dec 17 2013, 09:03 AM
Bartlett 914   I would agree that it appears to be bad gas. Are a...   Dec 17 2013, 09:23 AM
toolguy   For what it's worth, for mig / steel, I use st...   Dec 17 2013, 10:20 AM
MMW   I would try a different bottle of gas to eliminate...   Dec 17 2013, 12:35 PM
Downunderman   I see your flow meter is metric. 5 to 7 L per min...   Dec 17 2013, 12:48 PM
Jon H.   I once bought some budget wire from Tractor Supply...   Dec 17 2013, 04:45 PM
76-914   :agree: I had some flux core from HF that was :st...   Dec 17 2013, 06:19 PM
Travis Neff   What kind of wire are you using? ERS70-6 would be...   Dec 17 2013, 09:50 PM
walterolin   Ditto on the cheap flux core. I pay for the Lincol...   Dec 17 2013, 10:22 PM
toolguy   What kind of wire are you using? ERS70-6 would b...   Dec 17 2013, 11:54 PM
bulitt   Forget to ask, are you welding outside in the bree...   Dec 18 2013, 08:05 AM
ONTHEGRIND   It was bad gas...swapped bottle and look at the di...   Dec 18 2013, 03:30 PM
gothspeed   Congrats!!! :beer2: Now that is a ...   Dec 18 2013, 03:35 PM
Jeff Hail   I admit when I am wrong. :D Glad you got it sort...   Dec 18 2013, 04:52 PM
stugray   Sounds like your gas guy turned the wrong knob whi...   Dec 18 2013, 05:32 PM
bulitt   Nice! Good thing you didn't go up like th...   Dec 18 2013, 05:42 PM
- Lo-Fi Version Time is now: 12th July 2025 - 04:23 PM
