ONTHEGRIND |
Member ![]() ![]() Group: Members Posts: 286 Joined: 10-November 08 From: California Member No.: 9,738 Region Association: None ![]() |
So I have a Lincoln hd 3200 mig that hasn't been used in a year or so.. I went and got a bottle filled last week argon co2 mix using solid .025 wire with the correct brand new tip welded on brand new steel tried the l/min from very low to very high always welds the same. I can here gas exiting the gun ground is clean here is a photo of what im working with.. The welds are very black be a wire brush on a die grinder makes a pass over them..
The top weld is c 5 settting what it recommends bottom is b5 (IMG:http://www.914world.com/bbs2/uploads_offsite/img.photobucket.com-9738-1387250279.1.jpg) |
Bartlett 914 |
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 2,218 Joined: 30-August 05 From: South Elgin IL Member No.: 4,707 Region Association: Upper MidWest ![]() |
I would agree that it appears to be bad gas. Are all the lines tight? A loose hose connection could be allowing atmosphere gas to enter the system. Another thought is something happened to the rectifier in your welder and you are putting out AC instead of DC
Lo-Fi Version | Time is now: 12th July 2025 - 04:33 PM |
