ONTHEGRIND |
Member ![]() ![]() Group: Members Posts: 286 Joined: 10-November 08 From: California Member No.: 9,738 Region Association: None ![]() |
So I have a Lincoln hd 3200 mig that hasn't been used in a year or so.. I went and got a bottle filled last week argon co2 mix using solid .025 wire with the correct brand new tip welded on brand new steel tried the l/min from very low to very high always welds the same. I can here gas exiting the gun ground is clean here is a photo of what im working with.. The welds are very black be a wire brush on a die grinder makes a pass over them..
The top weld is c 5 settting what it recommends bottom is b5 (IMG:http://www.914world.com/bbs2/uploads_offsite/img.photobucket.com-9738-1387250279.1.jpg) |
toolguy |
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,276 Joined: 2-April 11 From: San Diego / El Cajon Member No.: 12,889 Region Association: Southern California ![]() ![]() |
For what it's worth, for mig / steel, I use straight co2. . .
Back to basics, , when welding does it sound like frying bacon or is it spitting any sputtering ?? Is the metal absolutely clean, and are you sure it's steel and not some alloy. It still looks like either no gas or the settings are wrong . . Something in the welder could have deteriorated while setting. . ie capacitors. |
Lo-Fi Version | Time is now: 12th July 2025 - 04:37 PM |
