Electical Draw ? Lowers RPM ? 914 and 912E, Pull light switch and drops RPMs? |
thompson-mfr |
Dec 17 2013, 02:20 PM
Thompson, Ryan Group: Members Posts: 198 Joined: 30-September 08 From: Silverton, OR Member No.: 9,598 Region Association: Pacific Northwest |
Hi All,
Finally got my car running better 74 914 2L FI. Thanks to all for suggestions. It turns out it was most likely the main power wires loose to my battery (fixed). Fuel was on and off. I noticed something else when setting my idle. When I turn on my headlights my RPM's drop. I recently acquired a 912E and it does the same thing, though not quite as much. I attached some pictures, just because I like threads with pictures better. A. Could this be my Battery? B. Grounds? C. All the above? D. Other_________? |
jim_hoyland |
Dec 17 2013, 05:21 PM
Get that VIN ? Group: Members Posts: 9,319 Joined: 1-May 03 From: Sunset Beach, CA Member No.: 643 Region Association: Southern California |
Had the same problem. Like Mike says, clean all the grounds, replace where necessary. I also added a second battery ground cable from the - battery post to the engine. RPMs have never dropped with lights, blower, or amp... (IMG:style_emoticons/default/smile.gif)
thompson-mfr |
Dec 17 2013, 06:25 PM
Had the same problem. Like Mike says, clean all the grounds, replace where necessary. I also added a second battery ground cable from the - battery post to the engine. RPMs have never dropped with lights, blower, or amp... (IMG:style_emoticons/default/smile.gif) Where did you connect the ground to the motor? |
Lo-Fi Version | Time is now: 9th June 2024 - 05:07 PM |
